Ethiopian Airlines: 'No survivors' on crashed Boeing 737 max
atc_is_god
Re: Ethiopian Airlines: 'No survivors' on crashed Boeing 737 max
Typical macho pilot reply. With 20 years experience in the industry on both sides, I fully agree with the OP. This is not nearly as cut & dried as some people might suggest. Easy to armchair quarterback when you've never been in an emergency scenario I guess.boeingboy wrote: ↑Fri Mar 15, 2019 1:02 pmJEEZ! - you should be a writer for Hollywood.In addition to a fix for the airplane, if they keep the MCAS system (instead of designing a whole new wing or tail for the airplane), they will have to train the pilots who fly it to deal with its failure. Right now, there is not a single Max pilot in the world who has been trained for this failure because - there isn't a single simulator in the world that can replicate it. But when they do, all those pilots that claimed "it's just a trim runaway" are going to have a very eye opening simulator session.
That is such an overdramatized sum of the events. Seriously - you don't think a professional crew can deal with 2 or 3 things that come at them in stages over 13 min? I guess then by your account the crew of Quantas 32 should have met their maker about a hundred times. Prioritize - I don't care what's going on - but if my airplane is trying to trim me into the ground constantly - it would not take very long to realize that is the priority and to disable it. By that time - they had already figured out the stick shaker was a false indication as was the airspeed disagree - so all they had to do was cut out the stab trim when it started running amuck. Instead they spent the next 10 min overriding it with the trim switch - when they should have just isolated it all together. During the whole time they were able to takeoff, climb out, change course, and acknowledge ATC instructions.
Not a fun day at the office - but boys and girls - this is where we make the big bucks.
I wonder if some of you have actually read the Lion air report?
sportingrifle
Hi Boeingboy...
No I am not a Hollywood screenwriter, but I do have a bit of a background in aircraft certification flight testing.
Re: Quantas Flight 32 that you alluded to. The crew were very skilled at handling the multiple issues simultaneously, most of which they had received no training in. But they were also very lucky, and are the first to admit it. Part of the luck was that there were 5 pilots, including 2 check airman available to help solve the problems. Had the airplane been crewed with just 2, the outcome could have been much different. It is also worth noting that after the incident, all the RR powered A380's were grounded.
Cheers Sportingrifle
Huh - I guess my 20+ years dont count for much then - It is pretty cut and dry. I never siad there wasn't a problem that needed attention, just that it doesn't warrent a fleet wide grounding. I can think of many other deadly incidents that never resulted in a grounding.. With 20 years experience in the industry on both sides, I fully agree with the OP. This is not nearly as cut & dried as some people might suggest.
Must be a page taken from your own book. I'm one of the few here who's not armchaie quaterbacking - again this is you more than me. I ask again - have ever read the report? did you even look at the FDR data I posted?Easy to armchair quarterback when you've never been in an emergency scenario I guess.
Good for you - must be very exciting work.No I am not a Hollywood screenwriter, but I do have a bit of a background in aircraft certification flight testing.
Your 100% right about Quantas - Good thing they did have 5 guys in the cockpit because they had something like 10 pages of ECAM warnings....but they got through it because they stayed calm and they followed procedures. These 2 guys had 3 or4 issues....all of which were known and all but the nose down trim were actioned before the the pitching happened....hell they even stopped it numerous times. The previous crew had exactly the same scenario, stayed calm and actioned the NNC before merrily going on their way.
Even if the Ethiopian accident shows the same problem - reports are already coming out that the pilot was panicked. As any instructor will tell you - staying calm in an emergency is vital to a successful outcome. 2 airplanes splashed - no matter the make - is certainly tragic......but if they are downed by pilot error, you cant really blame the machine for that.
jakeandelwood
Well holy heck, to bad for all those poor passengers that the cool, calm, collective and un-panicked Boeing boy wasn't at the controls, he would have saved the day! But then again boeing (the company) is praying it was the "panicked" pilot and his unexperienced FO's fault, so their latest shiny new 737 spinoff won't get blamed.boeingboy wrote: ↑Fri Mar 15, 2019 9:11 pmGood for you - must be very exciting work.No I am not a Hollywood screenwriter, but I do have a bit of a background in aircraft certification flight testing.
Eric Janson
Anyone here who has flown both 737NG and 737MAX?
I understand the "training" on the MAX is just a short powerpoint type presentation.
Apparently at some operators crews were just put on the aircraft with no additional training.
I'm just curious about just how different the 2 variants are.
Boeing doesn't have the common cockpit like airbus.
The Max has a known and acknowledged deadly flaw in the flight control system. Would you suggest that just operating this aircraft in a business as usual manner with the QRH open to the "Runaway Stabilizer" checklist before takeoff is a safer option than grounding? Would you be comfortable putting your family on a Max flight trusting that the crew will be "ready for it" when it happens again? I wouldn't.boeingboy wrote: 2 airplanes splashed - no matter the make - is certainly tragic......but if they are downed by pilot error, you cant really blame the machine for that.
Your awesome piloting skills should be reserved for unknown problems that arise, not known problems!
So yes, you can blame the machine.
- youhavecontrol
Aircraft are designed to eliminate pilot errors as much as possible, so when something like this happens twice, and both times it appears to be due to pilots being unable recover in the same manor, on the SAME type of aircraft, then other pilots come forward with accounts of similar problems... of course it's the machine's fault! An instructor will tell you that. Wait.. I'm an instructor telling you that.
- complexintentions
Agreed for the unknown problems. Which leaves me trying to understand why one needs awesome piloting skills to deal with a known problem? I'm a fairly mediocre pilot but I can flip two guarded switches. Especially if I already have an inkling that there just may be trim control issues. Or maybe there is a B737 pilot alive today who hasn't heard the news? Of course, assuming this will even happen at all disregards the 45,000-odd cycles on the type without incident.Your awesome piloting skills should be reserved for unknown problems that arise, not known problems!
On second thought perhaps it IS best they grounded the whole fleet to cater to the lowest common denominator type of pilot mindset that seems to predominate these days.
Oh yeah, and sorry it that's too macho for the sensitive souls.
Normally I would be the last person on this planet to post a link to a Fox “news” story and I don’t think Sully is a hero but I agree with what he’s saying
https://www.foxnews.com/us/hero-pilot-w ... ines-crash
Old fella
Anything floating about on crew background(outside of media which can be inaccurate). It has been quiet far as I can tell. Probably not surprising due that Ethiopia is more or less an authoritative regime, state run airline and media and its state investigative process probably run by the military or much direct influence by them. Dare I suggest with accidents such as this it is more of a face saving issue with such countries as Ethiopia rather that really getting to the bottom to ensure this type of crash isn’t repeated. The Aviation Safety network data bank doesn’t really paint a rosy picture of EA since 1965. You know the neck of that woods so be interested in hearing your commentary. Certainly PM me if you rather.Eric Janson wrote: ↑Fri Mar 15, 2019 10:49 pm Anyone here who has flown both 737NG and 737MAX?
Cheers.
Eric Janson
I worked over on the other side of Africa sub-contracted to Arik Air.
This was the most dysfunctional Airline I've ever seen - a bush operation with jets!
What always struck me is how delusional their management was - they thought of their company as "The Emirates of Africa!"
One of the things I have seen in the Expat world is a big push to upgrade Locals - usually well beyond their capabilities.
I've seen everything from extremely capable people down to people who had no business in the cockpit of an aircraft. I've seen a number of people who could actually fly the aircraft fail their Command upgrade whilst others with very mediocre skills passed.
Don't know very much about Ethiopian or how much of the above is applicable.
The final report will give some clarity - this is such a high profile accident that there is no chance of anything being covered up imho.
I fly both. I was just given a day of differences training in the classroom. If you take the whole MCAS thing out of the picture (it would have been nice to have been told about that) the differences training was more than adequate. From the cockpit there are very few differences. A few switches removed/added and some new tv screens. It’s not that different. Any 737 pilot is used to cockpit differences. I don’t think Boeing ever made 2 the same.Eric Janson wrote: ↑Fri Mar 15, 2019 10:49 pm Anyone here who has flown both 737NG and 737MAX?
The biggest problem I see is that Boeing made a plane that can overpower the pilots. Certification should require that the pilots always have the final say. It's a double edge sword though as pilots have also made poor choices in hand flying ie. Colgan or af447.
The MAX must have some pretty nasty habits if they thought that there was such a high chance of stalling it to put the mcas in.
Part of the problem here is some of you still don't understand the system and the media is not helping any - grabbing on to any little snippet and twisting things around.then other pilots come forward with accounts of similar problems
One of the reasons I like Boeing over airbus is the fact the pilot is able to override the computer - such as it will in this case. If one were to get into an actual stall condition and MCAS was operating to correct the problem...……. just as in Lion air - the pilot can trim nose up and override MCAS. The plane is simply going to say "hey - Im trying to save you but if you want to plow into the ground - go ahead" you can also stop it by flipping the cutout switches or selecting flaps. Of course - in this case this was a false problem on the computers part. Point is - one can override the flight software. If you look at the data - the lion air pilots were able to override and correct their altitude every time the system pitched them down. They were able to maintain 5000 fairly well through the 10 min they fought with it. I don't know about some of you but after 10 min at some point you would think common sense would kick in and someone would try running a checklist by that point.
The "other instances" are related to the autopilot. The MCAS is inhibited when the autopilot is engaged - so they are not even connected.
Illya Kuryakin
Until something official comes out, I’m advising friends and family members to take another airplane.
- complexintentions
Don't know if you heard, but there was a small thing in the news about the type being grounded worldwide.
But hey, uhhh....great decision?
Sort of the along the lines of the old classic " locking the barn door , after all the horses have escaped"complexintentions wrote: ↑Sat Mar 16, 2019 3:31 pm Don't know if you heard, but there was a small thing in the news about the type being grounded worldwide.
But hey, uhhh....great decision?![]()
I think he was just trying to inject a little calming humor to the discussion.
In other news....The CVR was successfully read out. It has been handed to the investigative team.
TailwheelPilot
I have not seen a definitive answer from Boeing or the FAA. It sounds like MCAS is only required on the MAX because of a regulatory requirement - as the plane approaches the stall the force to pitch up must not decrease. The larger and more forward engine nacelles at high angles of attack cause the force required to pitch up at high angles of attack to decrease.
Nothing to do with poor handling (which is reportedly no different from the NGs in normal operations) or a high chance of stalling.
Very good description of what can happen! Add along with the stick shaker the possible aural alerts yelling at you "Airspeed Low" "Too low Terrain", "Don't Sink", "Obstacle"!sportingrifle wrote: ↑Fri Mar 15, 2019 12:57 am One of the things that drives me nuts is how the airframer sales people sell these airplanes to their airline customers - usually bean counters and MBA's.
"Really easy to fly, no problem bringing low time cadets on board."
" Reduced training costs. All your XXX pilots need is an internet based differences course."
" There is nothing to it, you can covert your XXX pilots with a short course."
But let one of their nearly self driving airplanes create a new underground aluminum deposit and the same airframers say "Not our fault, your guys didn't fly it like our test pilots would have."
Boeing (and many posters) say "Hey, it's just a trim runaway. Do the drill and all is good." But this is not the simple trim runaway that the QRH contemplates. It starts with a stall warning stick shaker shortly after lift off. Close to the ground this will, and should consume both pilots undivided attention. After a number of seconds they realise that the airplane hasn't stalled and they start figuring out that they may have an airspeed and/or AOA problem. This is a second problem to deal with on top of the first. And they can't shut the &%$#@ stick shaker off once they realise that it may be spurious. The PM will be frantically scanning the panel to try and find some clue what is going on. And this whole time, among the din of the stick shaker, crews concern for the airplanes flight path, and the confusing instrument indications, MCAS has been intermittently dialing in nose down trim. Not steadily, in a calm cockpit at altitude like the QRH contemplates. But intermittently in the background of chaos, noise, and confusion. At some point, well past when it would have been timely, the task saturated PF realizes that the trim is working against him/her and the stab cutout switches get turned off. (hopefully)
But the shitshow isn't over. Because of everything else going on, this took too long and the airplane is way out of trim. The Lion Air crew reportedly had 60 KG of back pressure on the yoke. Close to the ground, and relying on the lifting component of the underslung engines to help keep the nose up, the crew do not dare reduce power. Now the crew needs to manually trim the airplane, but the airplane is way, way off its trim speed. The B737 QRH makes reference to the large forces that may be required to break free a servo clutch:
"3 If needed:Use force to cause the disconnect clutch to disengage. Approximately 1/2 turn of the stabilizer trim wheel may be needed.
Note:A maximum two-pilot effort on the trim wheels will not cause a cable or system failure."
Worse, the "Manual Stabilizer Trim" section of the Boeing FCTM talks about the air loads on a grossly out of trim stab requiring a speed change to reduce the force required to manually trim:
"Excessive air loads on the stabilizer may require effort by both pilots to correct mis-trim. In extreme cases it may be necessary to aerodynamically relieve the air loads to allow manual trimming. Accelerate or decelerate towards the in-trim speed while attempting to trim manually."
Sweet Jesus how did this thing get certified? A guy (or petite gal) has a 60 KG+ force on the yoke trying to stop the airplane from impaling itself into the hard ground just a few thousand feet below, and now he/she has to brute force trim the airplane as well, requiring involved coordination with the PM. Still with all the stick shakers, aural warnings, goofy instrument readings, and whatever else is happening to distract the crew and making communication almost impossible. It is not hard to see how quickly it becomes overwhelming.
During all this racket the MCAS can be trimming for 10 seconds covering 2 units of trim. That is 26 turns on the manual trim to get back in trim!
Normal Speed trim and normal pilot actioned trim is 1-2 turns.
Lots of talk about the MCAS system but virtually nothing from Boeing. There is nothing on the MCAS system in the Boeing MAX FCOM.
And yes I fly the MAX. The MAX is grounded because of inaction by Boeing.
Eric Janson
airbus is no different - you can put the aircraft into Direct Law where it becomes a conventional aircraft. Stick deflection will give a proportional flight control deflection and you have to trim manually.
Thanks to a Red Bulletin that came out a few years ago every airbus Pilot knows the steps to disable most of the protections and regain control in the event of uncommanded nose down pitch inputs.
I was surprised to see that the latest versions of the 737 are still equipped with dual everything as opposed to triple redundancy on just about every other aircraft.
The 737 was designed for short flights - not for the flights that are currently being done with it.
@ant_321 - thanks for the insight into transitioning from the NG to the MAX
goingnowherefast
Boeing has no redundancy on some parts. MCAS for example, works with ONLY the left side AOA probe. No comparison, so agreement required, just one prope. Single point of failure.Eric Janson wrote: ↑Sat Mar 16, 2019 10:09 pm I was surprised to see that the latest versions of the 737 are still equipped with dual everything as opposed to triple redundancy on just about every other aircraft.
Still waiting to see if this is what happened to Ethiopian.
Jet Jockey
goingnowherefast wrote: ↑Sun Mar 17, 2019 4:11 amBoeing has no redundancy on some parts. MCAS for example, works with ONLY the left side AOA probe. No comparison, so agreement required, just one prope. Single point of failure.Eric Janson wrote: ↑Sat Mar 16, 2019 10:09 pm I was surprised to see that the latest versions of the 737 are still equipped with dual everything as opposed to triple redundancy on just about every other aircraft.
If this is true about the MCAS, then Boeing deserves a kick in the a$$ big time and the MAX deserves to be grounded.
The fact Boeing makes no or very little reference to the system in any manuals and that no particular training on a possible failure of this system was mandated/required is very surprising.
I'm siding with those that say it is not as clear cut as it seems... There seems to be a possibility of multiple warnings (lost of airspeed indication, stick shaker activation, AOA disagree indications, trim pitching nose down etc...) which could overwhelm the pilots at a crucial phase of flight.
Anything happening at low altitudes that can affect the controllability of an aircraft, in this case MCAS should be thought in class to the pilots.
I would like to know why American and Southwest apparently got extra information/training for their pilots on MCAS. The Brazilian authorities also mandated additional info or training on MCAS be required for their pilots.
Finally I'd like to know why it seems American (and maybe others) felt it necessary and decided to get an additional system installed in their aircrafts (I think it's an additional AOA) because of this MCAS system and whether this is an option available to others and whether it was available from the start of production of the MAX.
