Vazar Otter external load LSTC
ragbagflyer
Hello, does anybody know of any external load LSTCs to allow carrying 3 canoes on a Vazar Otter at 9000 pounds?
Re: Vazar Otter external load LSTC
If it's an LSTC then it'll be whomever owns the aircraft as they are aircraft specific.
ragbagflyer
They're almost exclusively LSTC's, but the owner or the LSTC can sell the data and a DAR can submit an application to copy the existing LSTC and have it issued to a different registration.
Have you tried air sag or any of the Quebec operators?ragbagflyer wrote: ↑Sat May 04, 2019 10:00 amThey're almost exclusively LSTC's, but the owner or the LSTC can sell the data and a DAR can submit an application to copy the existing LSTC and have it issued to a different registration.
Nesting Canoes is one possibility. I assume that since you are looking for something as specific as a 3 canoe STC, that its something you need to do fairly often? We use to haul 3 nesting Canoes on each side. I do have an LSTC that references dimensions rather then specific numbers of canoes or boats. I am sure you could strap a couple canoes together and it would fall within the dimensions? PM me if you need more info.
