Superior Airways
beech 18
Re: Superior Airways
Post by beech 18 »
January 07, 2019
Superior Airways / Severn Enterprise operation from the late 1960's to 1974.
A bit of additional information about the photo of Cessna 180 CF-LSN that was
posted above on Dec 07, 2018.
In the photo LSN is fitted with Edo 2880 flat top floats.
LSN normally had Edo 2870 round top floats installed. The 2870 round tops were
installed as usual when the aircraft went onto floats in the spring of 1970 in Sioux Lookout.
It then departed for the summer to fly out of the base in Big Trout Lake.
In July or August LSN damaged one of it floats quite badly. The step compartment and
one forward of that were the ones damaged. The aircraft was flown to Sioux Lookout to
have the float repaired. Once there the chief engineer determined that besides the
bottom skin damage the float also required bulkhead repair.
Because the aircraft was needed back in Big Trout Lake it was decided to remove the damaged
set of floats and install a set of Edo 2880 flat top floats that were not being used at the time to
get the Cessna back in service as quickly as possible.
Floats were not something that were just sitting around not being used. The reason the base
had the spare floats was after ski season Cessna 180 CF-JQM was sent to the hangar in Thunder Bay
for some fuselage repairs. Because of that the floats that would have normally been in use were
available. They were installed on LSN and the Cessna 180 returned to Big Trout lake for the
rest of the float season.
beech 18
Post by beech 18 »
Feb 07, 2019
The attached photo was taken at Sioux Lookout in January 1972.
Cessna 180 CF-VGA is taxing off the ice and up the ramp to the maintenance shop
for some winter repairs. Ski operation ran from early December to mid April.
In the photo some of the items used in the winter operation can be seen.
The normal air filter has been removed and a metal plate with a large hole with
a very course screen has been install. The air filter is removed to prevent snow
and ice from clogging it.
The axel on the right leg can be seen. These axels are the heavy duty eight bolt
axels that wrap around the lower leg. These are ski axels only.
The bungees and check cables for the skis are attached as follows.
The forward bungees attach to brackets on the upper fuselage located aft of the
upper engine cowl. The forward check (or backup) cables are connected to brackets
attached to the lower engine mount firewall bolts. The rear check cables and bungees
are connected to brackets located on the lower fuselage area behind the cabin doors.
All the Cessna 180's except for CF-RNF operated on straight skis. As can be seen in
this photo the tail ski on VGA is a straight ski. There were a few of the 180's that had
a tail ski with a wheel sticking though the center of it.
Some operators had the bungee and check cables running to brackets at the top of the
main gear legs. None of the aircraft in Mr. Wieben's fleet used that type of bungee
set up. All bungees and check cables in the fleet connected to the fuselage.
In the background can be seen a Norseman. That Norseman is CF-HQD and belonged to
the original Slate Falls Airways. HQD operated off the ice each winter on wooden skis.
Also in the photo is the roller and Bombardier snow track that Slate Falls used to pack
the snow on the ice in the parking area around their aircraft.
beech 18
Post by beech 18 »
March 07, 2019
This photo was taken in the bay at Sioux Lookout during the winter of 1971.
I don't know who owned this aircraft. The aircraft is straight out from the
Severn Enterprise base and is about to depart from the ice runway. Back then
aircraft of this type were very rare in Sioux. They did show up during the summer
months at the Sioux Lookout air strip when American fisherman came into town,
but in the winter very rare and not on the ice runway .
At the time this photo was taken a Norcanair Bristol Freighter was operating off
the ice from the Severn Enterprise base hauling large items for Selco Exploration.
I don't know if this Cessna had anything to do with that operation or if it just
happened to be on the ice at the same time. Severn Enterprise was providing the
ground support to the Norcanair Bristol Freighter and crew while in Sioux Lookout.
A photo of the Bristol Freighter in Sioux Lookout was posted Jan 07, 2014 on page 7 of
this thread.
This photo was taken looking across the bay in a southern direction.
The Welcome Motel can be seen though the trees on the left side of the picture.
beech 18
Post by beech 18 »
April 07, 2019
DC-3 CF-BKZ was written off in an accident at Wiebenville on Oct 31, 1973.
The aircraft went into the trees during takoff. This DC-3 operated mainly out
of Wiebenville on skis.
Attached is a photo of CF-BKZ taken at Wiebenville in March 1974 approx. four
months after the accident. The DC-3 has been pulled out of the trees and a
number of items have been removed from it to be used on the other aircraft
in the fleet.
CF-BKZ was the first of three DC-3's that I know of that were involved in accidents
at Wiebenville and were written off. The other DC-3 aircraft that were written off
were CF-TTZ in March 1974 and C-GRMH in Feb. 1977.
Chevyman
Post by Chevyman »
Hello Beech 18
I find your stories both valuable and intriguing!
The Saskatchewan Aviation Museum in Saskatoon just resurrected CF-JDO from 56 feet of water in Peter Pond Lake, Saskatchewan. CF-JDO was the
"sister plane" to CF-IRM. Is any information available pertaining to the actual wreckage of CF-IRM that you are aware of?
I have just signed up so am unable to send a personal message.
You can visit the Saskatchewan Aviation Museum and Learning Centre website to view the pics of CF-JDO.
www.saskaviation.ca
Thanks!
Chevyman
beech 18
Post by beech 18 »
Chevyman
Interesting story about the accident and recovery of CF-JDO.
As for CF-IRM I don't know what became of the wreckage after the accident.
Normally Mr. Wieben recovered aircraft involved in an accident, but I can't
confirm he did that with IRM. It would be very unusual for it not to have
been salvaged by the company.
Chevyman
Post by Chevyman »
Thanks for the help.
I have been unable to locate any subsequent registration information on IRM since the accident.
Chevyman
beech 18
Post by beech 18 »
May 07, 2019
This photo is from the Mike Ody collection via George Trussell and is posted here
with permission.
Beech 18 CF-ZMR in Toronto on Feb 05, 1973. I know very little about ZMR other
that it did fly on wheels for the company out of Thunder Bay for a short time.
When this photo was taken in Feb 1973 I don't know if ZMR was still being operated
by Mr. Wieben or if another company was flying it by then.
In the photo the Beech is painted in the Superior Airways / Severn Enterprise paint
scheme. The two vertical stabs are normally painted red and why they aren't in this
photo is unknown.
In the Beech 18 directory, CF-ZMR appears to have left the company in 1972 and flew
for a number of other companies in Canada before crossing the border into the
United States.
ruddersup?
Post by ruddersup? »
I believe that is Carl Millard's hangar in the back ground. We all know the story there, right?
C.W.E.
Post by C.W.E. »
No. can you tell us?
C.W.E.
Post by C.W.E. »
Lets see if we get a strike and a chance to play it. :mrgreen:
ruddersup?
He he, no takers.
beech 18
Post by beech 18 »
AvCanada member - the cool one
I may be having a problem sending a PM back to you.
The PM you send me was received and I replied to it.
Thank you for the information. That was excellent.
beech 18
the cool one
Post by the cool one »
Got it.
I had similar problem sending you a PM.
the cool one
The secrets to success is costancy to purpose.
Benjamin Franklin
beech 18
Post by beech 18 »
June 07, 2019
This photo is from the John Bennett collection and is posted here with permission.
This photo of Beech 18 N9159B was taken at El Mirage Field Adelanto, California on
Nov 21, 2009. This Beech was once operated by Superior Airways as CF-ZMR.
A small bit of the Superior Airways / Severn Enterprise gold and white paint scheme
can still be seen on the nose of the aircraft. It would appear that the flying days
for this aircraft are over.
In the photo a small cockpit side door can be seen. I don't know when that would
have been installed. There were no small side doors in any of the Beech 18's that
Mr. Wieben operated.
In a posting September 13, 2012 on page 5 of this thread I had written that CF-ZMR
may have been involved in an accident in the Ft. Hope area. That was incorrect.
ZMR was sold and after leaving the Superior Airways / Severn Enterprise fleet flew
for a number of years in both Canada and the United States for several different
companies.
The Beech 18 that was involved in an accident returning from Ft. Hope was CF-ZQH.
beech 18
Post by beech 18 »
July 07, 2019
with permission.
Beech 18 CF-ZQH in Thunder Bay in November 1976. Up until September 1974 ZQH
flew out of Sioux Lookout on wheels. Summer off the Sioux air strip and winter off
the ice runway in the bay. The Sioux Lookout base was sold to Patricia Air Transport
(PAT Air) in Sept 1974 and a number of aircraft including ZQH moved to other bases
that were still operated by Mr. Wieben. ZQH being operated on wheels only went to
Thunder Bay.
ZQH looks the same as it did when it was purchased from the RCAF and flown from
Saskatoon to Sioux Lookout. One difference is the right vertical stab has been stripped
of red paint or it had been replaced and not yet painted when the photo was taken.
One other change is the plexi-glass bubble on the top of the fuselage just back of the
cockpit has been removed. When the Beech left Sioux in 1974 the plexi-glass bubble
was still installed.
There's a photo of ZQH with the bubble still installed that was posted Dec 07, 2015 on
page 9 of this thread.
ZQH was involved in an accident while flying from Ft. Hope to Thunder Bay. The aircraft
had an engine failure and ditched in the water approx. 20 miles north of Armstrong.
beech 18
Post by beech 18 »
August 07, 2019
Attached is a photo of Beech 18 CF-WYR that was taken in Sioux Lookout in
August 1970. A framed enlargement of this photo made from the negative was
hanging on the wall in the Severn Enterprise office for a few years.
WYR was flying out of Pickle Lake during the summer of 1970 and had flown into
Sioux Lookout the day before this photo was taken.
A few months earlier in the spring when WYR was finished flying on skis and
before being changed over to floats, the aircraft was repainted. I'm pretty
sure both the white top and the lightning bolt were repainted. The wing tips
and the tail were painted for sure in a Day Glow Orange colour as the top
surfaces had faded badly from the sun. This was done at the water base in
Sioux.
Snoopy was painted on both sides of the nose at the same time.
As can be seen in the photo there is no boat rack installed.
beech 18
Post by beech 18 »
September 07, 2019
Attached is an aircraft accident notification for Beech 18 CF-ZQH. This aircraft
was operated by the company on wheels only. It had no cargo door.
As mentioned in the July 07, 2019 posting located above, ZQH was involved in an
accident while returning to Thunder Bay from Ft. Hope after having an engine failure.
This accident occurred on July 28, 1978 and it is the only information I have
been able to find about it.
beech 18
Post by beech 18 »
October 07, 2019
with permission.
A photo of Beech 18 C-FJIR. This is a Beech 18 that at one time was owned by
Mr. Wieben. I never saw this Beech and I never heard about it when I was employed
by the company. A friend a while back mentioned this aircraft and he was sure it
was at one time Superior Airways Beech 18 CF-AUP.
CF-AUP was found in the Beech 18 directory and was listed as being owned by Superior
Airways at one time. Superior Airways had purchased this Beech 18 from the RCAF.
It was registered as CF-AUP. It was on wheels only and was an aircraft that was placed
in storage by the company and had the registration cancelled.
The Beech 18 was later sold to A. Fecteau Transport and registered as CF-JIR.
The aircraft eventually was sold to an American company where it was registered N792LP.
There it had floats installed along with the roof hatch and cargo door.
This is the only information that I was able to find on this aircraft.
beech 18
Post by beech 18 »
November 07, 2019
Superior Airways / Severn Enterprise operation from the late 1960’s to 1974.
This is a list of some of the aircraft that were owned, leased or operated by
Mr. Wieben over the years starting in the 1940’s. These registrations are from
first hand knowledge, friends, information from former employees, information
found on the internet, books and from Archives Canada. There are aircraft
missing from this list. These are the ones that were found. A few remarks
with each aircraft. If someone sees errors please point them out.
Beech 18
CF-AUP - Wheels only. Stored in Armstrong. Then CF-JIR then N792LP on floats.
CF-CUK - On floats from early to later 1970's.
CF-HVF – May have been the companies first Beech 18 on floats and skis.
CF-PLU – Floats and skis. Cargo door. Written off outside of Pickle Lake.
CF-PRZ - Floats and skis. Removed from service in Armstrong, Ontario in 1974.
CF-RSW – Floats. Leased in the early 1970's. Now parked in the field at Minaki airport.
CF-TBH - Floats. Leased in the early 1970's.
CF-VCE – Last operated on skis at Sioux Lookout before being retired. No spar mode.
CF-WYR – Floats and skis. Cargo door. Snoopy was painted on the nose.
CF-YDV – Floats and skis. Cargo Door.
CF-YQB – Floats only. Was a Sioux Lookout aircraft. Small door.
CF-ZMR – Wheels only. Flew out of Thunder Bay.
CF-ZQF – From the RCAF. Flown from Saskatoon – Sioux Lookout- Armstrong then stored.
CF-ZQG – From the RCAF. Flown from Saskatoon – Sioux Lookout - Armstrong then stored.
CF-ZQH – Wheels only. Flew out of Sioux Lookout for many years.
CF-ZQN – Found on Beech 18 register - Ferried to Armstrong and stored. No C.of A.
CF-ZQR – Floats only. Newest Beech 18 in the fleet. Cargo door.
Beaver
CF-FHO – Red, white and black. Purchased by O.J. Wieben and rebuilt.
CF-GQU – Sioux Lookout aircraft. Red, white and black. Floats and skis.
CF-IVA – Leased aircraft. serial #515
CF-MPN - Red, white and black. Floats and skis.
CF-MXR – Operated in Pickle Lake and later based in Sioux Lookout.
CF-ORC - Serial #1499. Photo on neil aird’s sight with Superior Airways on fuselage
CF-ODD – Ex Lands and Forest a/c. Floats and skis. Sioux Lookout winter of 73/74.
Otter
CF-DDX – Floats and skis. Serial #165. Red, white and black paint.
CF-GBX – Floats and skis. Serial #4 Red, white and black paint.
CF-IKT – Floats and skis. Serial #81 Red, white and black paint.
CF-XJM - Serial #29. Operated by Lamb Air when destroyed by fire on
Dec 09, 1968. Wreckage brought by Superior Airways. Info from
dhc-3 archive web site.
Cessna 180
CF-CJV – Brought as a write off. Infomation from DHC-3 archives - CF-IKT serial #81 history.
CF-DNZ – Brought from Austin Airways after accident at Sudbury. Found in book Austin Airways
CF-DMB - Painted red, white, and black. Only saw a photo of this aircraft. Built 1953.
CF-FYN – This aircraft went though the ice in December 1955. Accident report on file.
CF-HDE – On floats only. Out of Sioux Lookout summer of 1973 - 74. Leased aircraft.
CF-HEQ - Accident Feb 12, 1957 at McKenzie Lake Accident report. Broke a leg.
CF-HVG – Operated in Feb 1974, but can’t ever recall seeing it. Accident report on file.
CF-HZY - Dec 12, 1955 went though ice. Accident report on file.
CF-IRM – Floats and skis. Accident at Kaganagami Lake in Sept. 1970.
CF-ITO – Broken leg Feb 15, 1957. Possibly on wheel/skis. Accident report on file.
CF-IWD- Floats and skis. Flying in the Kenora area today.
CF-IXY - Accident at junction of Ogoki and Dusey Rivers 1966. Accident report on file.
CF-JDH – Floats and skis. Seen at Lac du Bonnet Airport Oct 2019.
CF-JDP – Flew out of Sioux Lookout. Floats and skis. Lost in hangar fire in Ft. William.
CF-JQM - Sioux Lookout based. Severn Enterprise aircraft. Edo 2880 flat top floats.
CF-KHM – Pickle Lake 1974. Joe Leutschaft had operated this a/c in 1972 at Pickle Lake
CF-KJZ – Accident on floats landing at Miniss Lake north of Sioux on Aug 9, 1969
CF-KQP – Red, white and black in colour. Floats and skis.
CF-KVU – Red, white and black in colour. Floats and skis. Flew out of Pickle Lake.
CF-LBR – Sioux Lookout a/c. Purchased 1969. Floats and wheel skis then straight skis.
CF-LBX – Brown or tan in colour. Floats and skis. Seen on wheel skis in photos.
CF-LSN - Spend a lot of time in Big Trout Lake. Severn Enterprise aircraft.
CF-NHL – Overturned while on floats Aug 18, 1961. Accident report on file.
CF-PHL - Leased summer of 1971 on floats. Yellow and white in colour. White floats.
CF-RNF - Based out of Thunder Bay. Wheel skis in winter, floats in the summer.
CF-VGA - Purchased in 1970. Edo float and federal ski. Sioux Lookout based.
CF-VSD – PeeKay 3500 floats and straight skis. White out accident at Wunnumin Lake.
CF-JES - **Found information on this Cessna 180 indicating it was with the company.
Not sure. Photo found on the internet said Superior Airways at Armstrong on floats**.
Cessna 150
CF-VXY – Lakehead Flying School.
CF-WIW - Lakehead Flying School.
CF-XWU - Lakehead Flying School.
Cessna 170
CF-GUG - July 12, 1954 capsized while taxing on floats. Accident report on file.
Cessna 172
CF- SZK - Lakehead Flying School.
CF-VBW - Floats in the summer at Sioux Lookout. Lakehead Flying School in winter.
Cessna 206
CF- E?? – Seen in March 1974 at Sioux Lookout on wheels or maybe wheel skis. Have a photo of it on floats.
Registration not complete. "CF-E--" only.
The DC-3 directory indicates that 15 DC-3 aircraft had operated with the company at one
time or another. Either owned or leased. The aircraft listed below under DC-3 are the
ones that are known to have flown for the company.
Douglas DC-3
CF-ABA – operated by Superior Airways in April 1973.
CF-AOH – Found in the DC-3 directory. Flew for Superior Airways in 1978
CF-AUQ – First DC-3 in the fleet. Operated on wheels and wheel/skis.
CF-BKZ – Takeoff accident in Wiebenville. Went into the trees.
CF-BYK - Airstair door. Gold, black and red stripe. Red tail. White top.
C-FKAZ – Found in the DC-3 directory operated by Superior Airways in 1980.
CF-POY – Found in the DC-3 directory operated by Superior Airways.
CF-TTZ – Into the trees on takeoff at Wiebenville.
CF-XXT – Second DC-3 in the fleet. Written off at Wummumin Lake
C-GRMH – Air Dale aircraft - accident on takeoff at Wiebenville. (may have been flying for Superior Airways ?)
More investigation needed to see who was actually operating C-GRMH when the accident took place.
Beech Baron
CF-FZN - 1964 model operated out of Thunder Bay.
These are all older aircraft that were with the company and have been found through research.
Mainly found in photos, accident reports, on the internet and old magazines.
Noorduyn Norseman
CF-BHV - acquired for parts after burning in Yellowknife Nov 28, 1955.
CF-FCU - serial #837 Superior Airways in April 21, 1954.
CF-FEW – Float and skis. Accident report Jan 1, 1951 while operating on skis.
CF-HFV - serial N29-50. Built from parts. Hangar fire Nov 29, 1957.
CF-HZR - serial #843. Superior Airways then sold to Parsons Airways
CF-JEC - Accident in Sioux Lookout on floats. Serial #469.
CF-PAA - Superior Airways in 1964. Serial #32.
Republic SeaBee
CF-DKR - Photo in book titled Aviation in Thunder Bar
CF-FCD – Now at the Western Canada Museum storage yard. Serial #352
CF-FUA - Accident report Sept 18, 1953 Left wing hit tree taxing Kam River, Ontario
CF-DKU - Accident report Aug 3, 1951 on file.
Cessna T-50 Crane
CF-BLP – Accident in Armstrong April 28, 1948. Operated from 1945 – 51
CF-BTL -
CF-BTN - Photo in book titled Aviation in Thunder Bay. Accident March 11, 1955
CF-BRK -
Waco AQC-6, ZQC-6, CJC
CF-AWB - WACO CJC
CF-BDS - Accident Jan 6, 1951 north of Ft William Engine failure
CF-CCU - Waco ZQC-6 Custom Re-registered CF-ECQ
Bellanca Skyrocket -
CF-DCE -
CF-DCH -
CF-EQP - Rebuilt by Superior Airways after accident in Northwest Territories.
Aeronca 7KAC
CF-BKH - Photo in book titled Aviation in Thunder Bay.
CF-DUX – Hit trees on takeoff. Jan 9, 1951 Accident report on file.
CF-IRY – Accident while landing on skis Mar 22, 1957 Accident report on file.
Cessna C-34 Air Master
CF-BDI
Cessna C-37 Air Master
CF-BHB – Operated this aircraft from 1939 to 1945. Photo in book Aviation in Thunder Bay.
Lockheed 12A
CF-EPF
Vultee BT-13
CF- HJB - stored at St. Andrews airport at WCA Museum.
Stinson Reliant
CF-BAG - Photo in book Aviation in Thunder Bay.
Stinson 108-1 & 2
CF-EYD - Accident Lakehead Airport Jan 2, 1952 Suspect carb icing.
CF-FQU - Capsized while taxing Miminska Lake July 30, 1953. Accident report on file.
Stinson SR10F
CF-FUE – Accident Jan 12, 1953.
Stinson HW-75 Voyager
CF-BST
DH.82C Tiger Moth
CF-BZD
CF-BXT
Harvard
CF-NUQ – Photo in book Aviation in Thunder Bay. Lakehead Flying School on fuselage.
