Autoland in a Piper
goldeneagle
Autoland in a Piper
Post by goldeneagle »
This is an interesting twist on aircraft automation from Garmin
https://www.youtube.com/watch?v=d-ruFmgTpqA
Bolding is mine.
Emergency Autoland is the latest layer of embedded automation in Garmin's Autonomi family of flight technologies for the G3000 integrated avionics suite. Coupled with an autothrottle, the autopilot's Emergency Descent Mode and Electronic Stability and Protection, the system ultimately puts the aircraft back on the runway when the pilot can't. With final FAA certification pending, Autloland is expected to be included in the production type certificates for the 2020 Piper M600 turboprop single and the Cirrus Vision Jet. AVweb contributor and Aviation Consumer magazine Editor-in-Chief Larry Anglisano flew with Garmin's full Autonomi system in both aircraft and prepared this field report.
Victory
Re: Autoland in a Piper
Post by Victory »
$3 million airplane and they are still using the same crappy textured plastic from the 60's on the center pedestal.
youhavecontrol
Post by youhavecontrol »
Really impressive technology.
Victory wrote: Thu Oct 31, 2019 9:45 am $3 million airplane and they are still using the same crappy textured plastic from the 60's on the center pedestal.
Why stop there?
Buy a King Air and you can have the same for 8 million.
Buy a 737 and you can have same for 80 million.
It says this is for emergency use only. Better than nothing.
valleyboy
Post by valleyboy »
Ah the sign of the times. The era of dumbing down of everything - scary shit
It will also give an excuse for law suits when it doesn't save someone's ass.
http://www.blackair.ca
Cliff Jumper
Post by Cliff Jumper »
Hate to nitpick, but i wonder why the computer didn't seem to care that it was so far right of centerline. You can see on the synthetic vision that it knew it was right, but made no effort to correct. Then again, I've seen hundreds of real live pilots do exactly the same thing.
Cliff Jumper wrote: Thu Oct 31, 2019 6:04 pm Hate to nitpick, but i wonder why the computer didn't seem to care that it was so far right of centerline. You can see on the synthetic vision that it knew it was right, but made no effort to correct. Then again, I've seen hundreds of real live pilots do exactly the same thing.
My guess is that if the “centreline” tolerance is tightened up, it’s hard to keep the aircraft from oscillating side to side, on short final, in gusty conditions.
Very cool.
The interesting thing is that every plane with a modern autopilot should be able to do this. It should all just be software at this point. If this is a success, I wouldn't be surprised if every newly produced autopilot equipped plane will have this as a standard feature within 5 years.
You need FADEC, and this aircraft had servos on the brakes too. How about digital flaps?
Oh right, some kind of throttle automation would be necessary. Brakes would be nice but not required for emergency landings. You could switch off the engine and coast once landed.
broken_slinky
Post by broken_slinky »
valleyboy wrote: Thu Oct 31, 2019 2:56 pm Ah the sign of the times. The era of dumbing down of everything - scary shit
My first thought on it was if the pilot is incapacitated and the body occupying the co-pilot seat has very little to no flight training. Be an "easy" way to get the plane on the ground and potentially save lives. Especially when it comes to aircraft like the M600 and SF50 where you're dealing with a lot more complex systems and coming in a lot faster.
valleyboy
Post by valleyboy »
Only if they can activate the system and get the aircraft configured and lined up.
I already know of guys who have landed, pc 12 for one, on the auto pilot coupled to the GPS and on gravel strips. Sure something to do when you are bored but the auto land system is likely meant for wx and not pilot incapacitation because the lack of auto throttle and such. The system still needs some kind of pilot input.
Like I said, dumbing down and compensating for diminished piloting skills. Automation have eroded stick and rudder skills and is going to continue to do so. It is the primary concern of pilot organizations like ALPA. It will or has surpassed CFIT.
I have even witnessed this first hand as far back as 30 years ago while training pilots who spent most of their time flying auto pilots to an aircraft with non. It was an eye opener.
HiFlyChick
Post by HiFlyChick »
broken_slinky wrote: Fri Nov 01, 2019 5:46 am My first thought on it was if the pilot is incapacitated and the body occupying the co-pilot seat has very little to no flight training. Be an "easy" way to get the plane on the ground and potentially save lives....
But when does that -ever- happen? The more likely scenario will be some turkey with more money than brains up flying when/where he shouldn't, and when he decides that the crosswind is too scary, he hits his good old autoland button. Kind of like when a VFR guy in a cirrus wanders into IMC and pulls the 'chute.... The safety intent is good, but it seems like it just eggs people on to do stupid things because now the machine will get them out of trouble
goldeneagle
valleyboy wrote: Fri Nov 01, 2019 6:56 am but the auto land system is likely meant for wx and not pilot incapacitation because the lack of auto throttle and such. The system still needs some kind of pilot input.
But it does have auto throttle, and flaps, and brakes. Watch the video and that's made pretty clear. Push the big protected button on the panel, computers take over, select an airport, fly the approach, and land on the runway.
C-GGGQ
Post by C-GGGQ »
It even declares an emergency to ATC and stops on the runway. It's only for pilot incapacitation not for cat 3 approach
valleyboy
Post by valleyboy »
Boomers can then fly to an age of 110 :smt040
goldeneagle wrote: Fri Nov 01, 2019 7:53 am
Yes. I was responding to the comment "The interesting thing is that every plane with a modern autopilot should be able to do this."
Only every plane with a modern autopilot PLUS FADEC, and digital flap and brake control will be able to do this. That's absolutely zero light aircraft in the current fleet.
HiFlyChick wrote: Fri Nov 01, 2019 6:58 am
It's not for rich pilots to use, or even to appeal to rich pilots. It's to appease rich pilot's wives so they will allow their rich pilot husbands to buy the airplane. "See, honey? Now you don't need to be frightened to fly with me any more."
