Isn't he an AME?
Experimental parts on certified aircraft
Re: Experimental parts on certified aircraft
An AME is allowed to sign off mods to his own aircraft?
The quote above says there's "no STC" to add the light, and "to hell with the regs," he's doing it anyway. Which suggests that if he's an AME, he knows it's against the regs somehow. And yet, he's doing it anyway. But hey, I guess he can piss in his own cornflakes...
An AME can issue a release for work performed on their own aircraft, sure.
The decision as to whether a modification is minor or major doesn't have to be made by anyone with a particular qualification. An AME might be better placed to make that decision, but at root it's a question of fact and not opinion, like airworthiness. If the modification meets the criteria in CAR571 Appendix A it's minor, and can be supported with "acceptable data". If not, it needs either "approved data" or "specified data". If coreatthermal can find acceptable data (like a similar installation as part of another type certified aircraft) uses standard parts like LED's or bulbs and holders, and performs the work in a standard way like by following the guildelines in AC43.13, then he's good to go.
