Wrong. In order to calculate the death rate, you have to only take into account closed cases (ie: those that were cured and those that died). There were 91,000 closed cases since the beginning and 8,000 deaths for an 8.8% death rate. By your math, we’re looking at a 3-4% death rate. It is quite high.twa22 wrote: ↑Tue Mar 17, 2020 4:25 pm Because it seems that people have literally no common sense... the virus doesn't appear to be that bad. The current number from confirmed cases and deaths is roughly 4%, which is probably more like 1 to 2% given all the unconfirmed/diagnosed cases due to asymptomatic people...and people are forgetting that the death rate of 4% currently is the elderly... majority over 80, with next highest rate being 70 and above. The death rate for those under 50 is virtual 0
It's contagious which is what is worrisome. I'm not down playing it but jezz this isn't ebola where the case fatality rate is on average 50%
Ebola wasn’t nearly as virulent. There were only 29k cases in the two years it resurged between 14 and 16 and 11k deaths. There are 8k deaths in just a couple of months and there is no sign of slowing down.
