Pilot leaves towbar on runway??
Re: Pilot leaves towbar on runway??
rookiepilot wrote: Wed Jan 29, 2020 12:18 pm
pelmet wrote: Wed Jan 29, 2020 12:17 pm
Based on what I have seen here today...I suspect that all your ranting and raving on other threads(such as St. Catherines) was just pretend-to-care about those people with probably other motives in mind(lawsuits for financial gain?).
Keep going, its amusing.
You've been owned in this whole thread, dude. Keep going, popcorn is hot.
Ok, another example of me being "owned"....
https://generalaviationnews.com/2019/09 ... l-for-two/
Failure to secure fuel cap fatal for two
September 12, 2019 by General Aviation News Staff 9 Comments
After refueling the Beech C35, the pilot and the pilot-rated passenger took off to return to the pilot’s home airport.
During the initial climb, the airplane accelerated to about 67 knots and reached an altitude of about 170′ above ground level before it began to slow and lose altitude, consistent with a loss of engine power.
Although more than 2,300′ of relatively level grassy terrain suitable for an emergency landing remained ahead of the airplane, the pilot made a left turn back toward the departure end of the runway at the airport in Camden, Arkansas.
During the turn, the airplane entered a steep left spiral, hit the ground, and caught fire. Both people on board the plane died in the crash.
The airplane’s left main fuel tank cap was found on the left side of the runway about 1,000′ from the threshold and 4,500′ from the main wreckage. The cap’s locking lever was engaged, and it showed no fire or impact damage.
The fuel selector valve was found positioned to the right main fuel tank feed position.
Flight control continuity was confirmed, and no other preimpact anomalies were found.
According to the pilot operating handbook for the airplane, the fuel selector should be on the left main fuel tank for takeoff. It is likely that the left main fuel tank cap was not secured after the airplane was refueled and fell off the airplane’s left wing onto the runway during the takeoff. Without the cap in place, fuel escaped from the left main fuel tank and subsequently starved the engine of fuel during the climb, resulting in the power loss.
The pilot likely switched the fuel selector to the right main fuel tank in an attempt to restart the engine. When he tried to turn back to the airport, he failed to maintain a safe airspeed, and the airplane exceeded its critical angle of attack and entered an aerodynamic stall.
Probable cause: The pilot’s improper decision to return to the runway instead of landing straight ahead when the engine lost power and his failure to maintain adequate airspeed while maneuvering for an emergency landing, which resulted in an exceedance of the airplane’s critical angle of attack and an aerodynamic stall. Contributing to the accident was the pilot’s failure to properly secure the left main fuel tank cap after refueling, which resulted in a loss of engine power due to fuel starvation during the takeoff climb.
NTSB Identification: CEN17FA364
This September 2017 accident report is provided by the National Transportation Safety Board. Published as an educational tool, it is intended to help pilots learn from the misfortunes of others.
Thank god we have people like you for advice Rookie. Otherwise we would never get our bread buttered(and yes, I did see how you tried to be funny by adding the buttering of bread to your hilarious checklist before you deleted it as seen at 11:17 in this post below).....
viewtopic.php?f=118&t=136967&start=50#p1103077
Child.
Oh, Fatal accidents are never funny. No one is saying that.
Your analysis sure is, though.
Oh; and last I looked, this was the subject of this thread:
"An aircraft towbar was left on a runway by a pilot who had experienced a "close shave" driving to the airport, an investigators' report said.
The Cessna towbar fell onto the runway departing from London Southend Airport on 7 August.
Its pilot said he had been distracted during his pre-flight checks by an earlier near-miss between his motorcycle and a cyclist.
A plane that landed later ran over the towbar, but no damage was caused.
You've changed it to some expose' on fatal accidents, after you've been shown up.
Anything else?
laminar
Post by laminar »
Tow bars have always been a fear of mine with regards to this type of incident. My personal rule is a tow bar doesn't leave my hands. I pull it from a rack, move the plane, and take it back to the rack before my next task.
rookiepilot wrote: Wed Jan 29, 2020 12:40 pm Oh, Fatal accidents are never funny.
Anything else?
Only a bit of curiosity about your accident. What happened and what can we learn from it?
This is a perfect forum for a detailed analysis. I could start a new thread if you prefer.
rookiepilot wrote: Wed Jan 29, 2020 12:40 pm Oh, Fatal accidents are never funny. No one is saying that.
The only thing I have been shown is the complete incompetence of many posters, including you. I give multiple examples of fatal accidents that would have been prevented by a couple of simple procedures(each lasting only a few seconds) and several of you latch onto calling it more checklists and simply making extremely juvenile responses. It is a true explanation of why accidents continue to happen...the thought process of so many.
7ECA
Post by 7ECA »
North Shore wrote: Wed Jan 29, 2020 11:22 am Morning Checklist #1, Rev 1
Reason for amendment: Insert 'Butter: APPLY'
Coffee start Button: DEPRESS
Toaster ENGAGE
Coffee: POUR
Cream: AS DESIRED
Toast: REMOVE
Butter: APPLY
Jam: APPLY
You'll need an additional revision, you've forgotten the 3-Ss. Important part of any morning routine.
Oh dear, and you've forgotten anything about getting dressed and making sure your epaulettes are shiny, and you've neglected the wearing of an appropriately large watch... :lol:
C-GGGQ
Post by C-GGGQ »
7ECA wrote: Wed Jan 29, 2020 7:52 pm
Toaster ENGAGE
Coffee: POUR
Cream: AS DESIRED
Toast: REMOVE
Butter: APPLY
Jam: APPLY
That's only morning checklist #1
Please refer to morning chelist #2-6 for those steps
7ECA
Post by 7ECA »
C-GGGQ wrote: Wed Jan 29, 2020 8:31 pm That's only morning checklist #1
Please refer to morning checklist #2-6 for those steps
Darn, I guess I forgot to add to my silent checks a check to check if I had checked if there were any additional checklists for the morning...
Might need to add those little coloured sticky tabs to the checklist. :)
Another example of how a quick final check would have prevented the circumstances leading up to a fatal accident. A bit more difficult to do on floats but still can be done fairly easily. Pilot forgot the gas cap.
https://tsb.gc.ca/eng/rapports-reports/ ... 8p0108.pdf
"Following this accident, Fort Langley Air Ltd. made several changes to its training program. These changes included the following: • increased awareness and training on fuelling procedures and the importance of confirming that fuel caps are replaced after fuelling;"
Kinda like I said.....throughout the thread.
PanEuropean
Post by PanEuropean »
laminar wrote: Wed Jan 29, 2020 3:01 pmMy personal rule is a tow bar doesn't leave my hands. I pull it from a rack, move the plane, and take it back to the rack before my next task.
My personal rule is that I always put some other operator's name on my towbar. :mrgreen:
PA32pilot
Post by PA32pilot »
Did that oil fill cap snap down? Trust your gut feeling and taxi back. Better to suffer some embarrassment than suffer through a whole flight,or worse.
You don’t need a fancy checklist. It’s called a walkaround.
Look at every surface of the aircraft and the area around the aircraft for abnormalities. If the systems that are in place have been implemented properly (flags, high vis markings, ground icing training, norms, etc) you aren’t going to miss anything and you don’t need to write a new checklist for every different plane or situation.
Most others are satisfied by actually following the manufacturer’s checklists (which already include all of the killer items) and improvements over the years which added layers of technology rather than more checklists (takeoff config warning, EGPWS, etc).
iflyforpie wrote: Wed Mar 25, 2020 8:14 am You don’t need a fancy checklist. It’s called a walkaround.
You don't need any checklist. I doubt that Fort Langley Air has any new checklist. They have a procedure to check fuel caps after fueling. After all, fuelling likely happens thousands of times per year AFTER the walkaround is complete, which makes a thorough walkaround kind of useless for ensuring the caps are back on in those cases. Just like several other items which I suggest checking. Takes less time than I spent on this post. This pilot would be alive if he had done what I suggest, and he may well have done the world's most thorough walkaround.
jakeandelwood
Post by jakeandelwood »
My final check before getting in is tow bar, fuel caps, baggage door, oil cap and dipstick, takes 15 seconds. Other than the oil cap and dipstick which I just feel is important to double check any of the other things could become a problem again between your pre flight check and take off if you fuel up before take off. Yes and I check my gear at least 2 more times after the pre landing checklist.
https://pilotworkshop.com/tips/cowl_plu ... mpaign=tip
It turns out that a lot of pilots do my recommended final check procedure in the US as I just discovered. They call it a 360 check. There is a survey available at the posted link(along with many general comments and a brief article).
The question is...."Do you step back and do a final 360-degree walk around before climbing into the airplane?" Out of nearly 13,000 responses, almost 10,000 said 'Yes, always'. I guess they see the common sense in it. Who wouldn't.
7ECA
Post by 7ECA »
Sure, it could be possible that between the time you did your DI/walkaround and when you yawned, readjusted your nuts, and loaded your oversized flight bag into the aeroplane that a mud dauber could have blocked the pitot tube. Or, an errant baggage cart could position itself in front of an engine. Or...
Or, your poor church mouse wife could have run off with another church mouse taking all the cheese, on the same day that an incredibly large tax bill arrived. I mean, shit happens; but let's be realistic.
7ECA wrote: Mon Apr 06, 2020 9:02 pm Sure, it could be possible that between the time you did your DI/walkaround and when you yawned, readjusted your nuts, and loaded your oversized flight bag into the aeroplane that a mud dauber could have blocked the pitot tube. Or, an errant baggage cart could position itself in front of an engine. Or...
Thanks for your advice. Here is realistic for you....
viewtopic.php?p=1110501#p1110501
Beware who you take your advice from.
7ECA
Post by 7ECA »
Who knows, maybe the missing fuel cap would have been noticed - or maybe it wouldn't have been.
Nevertheless, if one does not panic and tighten a turn at low level; leading to a stall/spin... Or, is there a checklist item to avoid that scenario?
7ECA wrote: Mon Apr 06, 2020 10:24 pm Who knows, maybe the missing fuel cap would have been noticed - or maybe it wouldn't have been.
Only completely stupid people would still think that this last minute look-around is a checklist after I have repeatedly stated that it is simply a last minute look-around(as well there is the occasional bitter poster like 7ECA who has been proven wrong in previous discussion with me and therefore can only achieve a juvenile level of posting in attempt to somehow get back at me on several threads).
Intelligent and mature people can plainly see that it is desirable to avoid getting airborne with a fuel cap missing(and possibly avoiding the inconvenience of losing said fuel cap), even if they have a checklist to avoid low level turns. Then there are all the other crash examples I have posted in this thread that could have been avoided because pilots didn’t deal with it properly.
Beware of the maturity level of who you take your advice from newbies, you will encounter people like this as you gain experience.
goldeneagle
Post by goldeneagle »
pelmet wrote: Tue Apr 07, 2020 4:06 am Only completely stupid people would still think that this last minute look-around is a checklist after I have repeatedly stated that it is simply a last minute look-around
And only completely negligent people have to go double check, and triple check things that were on the first check list (walk around).
If you didn't catch it the first time, then maybe you need to haul out the walk around checklist and start over.
7ECA
Post by 7ECA »
goldeneagle wrote: Tue Apr 07, 2020 9:13 am If you didn't catch it the first time, then maybe you need to haul out the walk around checklist and start over.
True, have you seen the level of detail on the pre-flight inspection checklist for a simple aeroplane like a 152/172? It's insane, but thorough - maybe pelmet should be advocating the use of manufacturer approved checklists, rather than home-brewed non-approved checks?
Also, when was I "proven wrong"? Mind you, it's bad enough that I've continued engaging in these circular arguments with a lunatic...
goldeneagle wrote: Tue Apr 07, 2020 9:13 am And only completely negligent people have to go double check, and triple check things that were on the first check list (walk around).
Then I suggest pilots of light aircraft consider themselves completely negligent and do the so-called '360 check' of items such as towbars, chocks, baggage doors, fuel caps, oil cap, intake plugs, any damage cause by a vehicle or another aircraft just prior to getting into your aircraft to start up. Ask yourself if this has ever happened to you(or someone you know) where you missed one of these items(any of which could have happened in the time after the walkaround).
Then you won't end up being one of those non-negligent pilots who got caught forgetting these items.
Don't give up your professionalism just because some unprofessionals may berate you for it.
jakeandelwood
How's double, triple checking something negligent? I check to see if the front door is locked at least 6 or 7 times before I go to bed, crazy maybe but hardly negligent.
goldeneagle
jakeandelwood wrote: Wed Apr 08, 2020 12:00 pm How's double, triple checking something negligent? I check to see if the front door is locked at least 6 or 7 times before I go to bed, crazy maybe but hardly negligent.
If you do the walkaround, then the towbar is still attached afterwards, I would call that negligent.
goldeneagle wrote: Wed Apr 08, 2020 3:25 pm
One would think that experienced pilots would realize that walkarounds frequently get done before an aircraft is towed, the aircraft is fueled, baggage doors are closed for the last time, a pilot leaves the aircraft alone for a multitude of reasons(washroom, help pax, get something, etc, etc) during which a vehicle or other aircraft can strike a wingtip, rudder, etc. If you do nor realize that after however many long years you have been in aviation, you are negligent.
Do the final check....I have several examples on this thread of pilots(and their pax) who would be alive if they listened to my advice. And my advice in general is for negligent pilots as well. Something beneficial for us as we never know when we might be a passenger on their flight.
Some towbar incidents below, even on a large jet....
https://generalaviationnews.com/2019/03 ... -tow-bars/
jakeandelwood
No, negligent would be never even checking in the 1st place. You don't seem to know what the definition of negligent is. The definition of thorough on the other hand would be double checking to be sure you didn't forget.
