TSB Investigation - Canadian Approach Minimums
Gilles Hudicourt
Post by Gilles Hudicourt »
https://www.bst-tsb.gc.ca/eng/rapports- ... q0030.html
This investigation states that approach minimum regulations, and the approach ban itself, are far too complicated in Canada. I agree with this wholeheartedly.
Last edited by Gilles Hudicourt on Thu May 21, 2020 12:53 pm, edited 1 time in total.
Plausibledeniability
Re: TSB Investigation - Canadian Approach Minimums
Post by Plausibledeniability »
Gilles Hudicourt wrote: Thu May 21, 2020 12:36 pm https://www.bst-tsb.gc.ca/eng/rapports- ... q0030.html
This investigation states that approach minimums, and the approach ban itself, is far too complicated in Canada. I agree with this wholeheartedly.
Not too mention required Airport Operating visibilities as well!!
Completely agree that this needs to change.
bring me the horizon
Post by bring me the horizon »
"...go have a look and see where the runway is." Ahh yes, the ol' lookie loo
Just get rid of the approach ban. It's silly.
matt foley
Post by matt foley »
I work, and fly all, for a 703/704/705 operator. Some aircraft will operate as several categories in a single day depending on configuration and crewing etc. My last PPC ground briefing was just under an hour most of which was answering the question "Can you conduct an approach under conditions ABC at airport XYZ?" I was more confused afterwards than I was going in. Guess I will continue doing what I think is right and face the music when the time comes...brutal!
Kosiw
Post by Kosiw »
About 'effing time that TC got called out to get off their collective asses and make positive changes in the interest of safety.
Gravity always wins
Donald
Post by Donald »
The captain mistakenly believed the approach was legal.
The captain was also the company chief pilot.
Panama Jack
Post by Panama Jack »
Thanks for sharing this- it is very interesting.
The approach ban always had me scratching my head. I when I converted my FAA Instrument Rating to the Canadian one (pre-IPL era) a lot of mental energy was spent trying to get to grips with this. While I get that it was probably intended to provide a minimum level of safety to keep pilots from doing ”look see” approaches when there really was no realistic chance of getting in, the Canadian Approach Ban minima were an inadequate fix and perhaps introduced its own set of hazards, and this accident illustrates the point.
The FAA policy, if I am not mistaken, is that Part 121 or 135 (for hire) operations require the plated or Ops Spec minimum visibility/RVR to shoot the approach. For Part 91 (private operations) there is no approach ban but you need the required flight visibility and required visual references to continue to land. While I personally find the Part 91 standards a little loose, it makes sense to me that for-hire operations carrying the unsuspecting public prescribe a higher standard to guarantee a minimum level of safety and relieve commercial pressures from air crews.
I now fly for an overseas carrier. Don't have to deal with the CAP plates or the confusing Canadian approach ban methodology. We use Jepps and have a separate Jepp plate which shows the Company minimums for all the approaches at the said aerodrome.
There are so many ’gotchas’ in aviation, we could use a few less.
-President Ronald Reagan
Without the flow chart I'm not completely lost, but possibly slightly unsure of whether any particular IAP is legal.
valleyboy
Post by valleyboy »
To have an area where there is approach ban and another area where there isn't just shows how screwed up the thought process and the law makers implement the rules. Just like FDT there is far too much lobbying and industry influence to make the rules as they should be. Typical Canadian mentality, trying to make people happy and turn out pure crap and you end up with requiring legal advice and interpretation before commencing a manoeuvre.
I have ignored approach bans because of local conditions and did a pirep just to have something on the tapes but in reality I could have been charged because I initiated the approach below the ban. I never hear a thing so I have no idea how far up the ladder the filed report would have gone.
Back in the day with the old "below minimums" approach one would get some indication from ATC, like anyone who has tried the approach has landed, and he is saying fill your boots if you want or go to your alternate.
We have had corner turning incidents, Fredericton for one, that has motivated TC and the law makers to "dumb down" and create a rule to basically remove missed approaches and pretty much assure a landing. We all know you can't just make rule that are so complicated with exceptions and variables that confuse everyone.
A one hour pilot briefing before a ride is ridiculous and the check airman needs to bone up on his job, I have been a check airman and I know this type of thing indicates that even the check pilot is a little apprehensive as well. Doing the new course to become a TC check pilot is information overload and rule driven but common sense must prevail.
What's the solution, I think a stream lining of the rules, the international rules are pretty straight forward and in Europe an approach ban is an approach ban and you work with what your company has operationally but ATC will not issue approach clearance once it goes below approach ban limits and will actually ask what your company limits are. Canada needs to go this way and bring the rules in line with the rest of the world and ignore the urge to be influenced by the USA. This means the CAPs would be for general aviation and for companies without reduced limits authority. To go below the public minimums companies would need to have a cat 2 and/or cat 3 authority. TC will also visit LVP limits as well for reduced minimums. This mean mom and pop operations would likely be stuck with the CAP minimums as they should be and for companies who have been large enough to initiate cat 2 at least will be required to set up training and equipment to qualify.
The bottom line is approach bans should be enforced by ATC, by not issuing an approach clearance and not by the pilot, just like the rest of the ICAO would. Unfortunately, uncontrolled airspace is another animal, how do you enforce a place where an IFR flight plan isn't necessary. It should never be reduced to a point where pilots rat out pilots and of course if there is now official wx how can one even prove it as well.
It's a mess which likely could have been the post rather than all these ramblings :rolleyes:
http://www.blackair.ca
valleyboy
Post by valleyboy »
dbl post
GoinVertical
Post by GoinVertical »
Glad to see the TSB focusing on this as a result of this report...
I do find it funny though some of the things they mentioned in the report that they didn't put much focus on - especially the lack of de-icing available with 1/4-1sm in snow, calm winds, and temperature of -2... also the fact that the captain clams he had visual reference and the FO had nothing.
I'm pretty sure we all know that the skipper of this flight knew exactly what he was doing when it came to trying this approach at 1/4sm and having "visual reference" when the FO didn't... just didn't work out for him this time.
Again, despite all of these (common amongst northern 703 operators) issues, good report, and glad to see them focusing on the approach ban.
The revamp is mainly needed for a logistical/legal standpoint. Tell me if I can legally do the approach in an easy to follow manner—without having to remember what a percentage of advisory vis actually is and whether it’s inclusive or exclusive and whether TC considers an LPV precision or non precision (the definition in the CARS and TCs literature conflict) and ops specs and exceptions and exceptions to exceptions, etc.
Canada is not like the US or Europe and in lots of places, a simple and controlled approach ban won’t work due to the lack of weather information, the lack of ATC control or monitoring, or many other situations where approach ban simply does not apply.
But the root cause of the problem is continuing the approach beyond minimums without the required visual references. I’ve done 50% advisory vis and made it in no problem more times than I can remember—particularly off an ILS or LPV into an aerodrome with HIALS at night. See the lead in lights.. in Canada you can continue. Not waiting a second or two after DH. Not dipping below an MDA. Not “forgetting” to put in cold weather corrections. Not because I desperately needed to get in or management or customer told me to go try or get in or else.
I’ve also gone missed with airport reporting 3 miles vis because of ragged bottoms or a low cumulus cloud or a rain squall right at the MAP.
Approach ban is like the 12 hour rule. Pilots who showed up to work drunk when it was 8 hours will still show up to work drunk. It just ruins it for the rest of us who might want a single beer after work.
TurkeyFarmYQX
Post by TurkeyFarmYQX »
I really hope they can make some changes, would've made my INRAT so much easier.
Victimized by Boeing
golden hawk
Post by golden hawk »
thenoflyzone
Post by thenoflyzone »
iflyforpie wrote: Sat May 23, 2020 10:03 am . See the lead in lights.. in Canada you can continue.
Technically, you can in the States as well, but only down to 100 ft. To go below that, the red terminating bars or the red side row bars on an ALSF type approach lighting system need to be distinctly visible and identifiable. Or other approved visual references must be seen.
Yes, in Europe too.
What I meant was there’s no other qualifiers in Canada.. though it’s probably a good idea that you know where the runway actually is so you don’t undershoot it.
FICU
Post by FICU »
That flow chart at 2:07 says it all.
SRV
Post by SRV »
All you weak IFR wanna-be's, make a flow chart to figure out your approach ban options. And more importantly, learn to study.
It's grease easy to figure out without being a constant complainer...
Couldn't Stand the Weather
mijbil
Post by mijbil »
Glad I found this thread since this approach ban is one that I too have found very confusing. I recall heading back to CYFB one day and having an intra cockpit re-re-re read of the rules and then a Satcom conversation with dispatch and ending up with 4 opinions (kidding) but it took three of us about 30 minutes to figure out the answer. We did the LPV since that is "non precision" even though it has both GP and azimuth guidance.
Now that things are slow perhaps TC will have the time to finally come out with a clear and easy to know set of rules.
Here is my 2 cents. Get rid of approach bans altogether. Shoot the approach and if you see the runway, land, and if not go around. The plate visibility is for planning purposes (legal alternates). This is how we did it in the RCAF. We could file to a 0/0 (WOXOF) destination as long as we had a viable alternate. It was legal (mil rules) to do so. Would it be smart? - no, but it was legal. If we didn't have the required visual refs, then we went around. I realize that this is likely a bit idealistic in the commercial world since there are economic pressures that do not exist in the mil world but it really made life simple. The plated vis was for planning purposes. There was no approach ban. Oddly, in the civ world, you CAN shoot an approach below ban limits for training. Think about that. You can do it for training but not for real because you are expected to go around. There is also the north or south of 60 rule and the localized meteorological phenomenon clause allowing you to shoot it anyways.
As mentioned earlier, there is also less than ideal reporting in some more remote areas (AWOS etc).
valleyboy
Post by valleyboy »
That's the way it was until Fredericton - yup no approach bans north of 60 unless there is RVR -- makes no sense - shoot the NDB or RNAV because the ILS is banned -- someone had a brain fart
“Bob”
Post by “Bob” »
SRV wrote: Sat May 30, 2020 4:03 pm All you weak IFR wanna-be's, make a flow chart to figure out your approach ban options. And more importantly, learn to study.
You’re my hero!
:prayer: :prayer: :prayer: :prayer: :prayer: :prayer: :prayer:
It would be easier if we just used charted visibility.
That's how most of the world does it.
thenoflyzone
^ I agree.
The problem is though, you can't really chart anything less than RVR2600 on CATI ILS approaches in Canada, due to lack of proper runway lighting.
If you wanna chart anything less than that (without Ops Spec), you pretty much need centerline lights, along with HIAL & HIRL.
Unfortunately, most of Canada's runways don't have centerline lights (CL). Considering most of Canada's runways are also 200ft (60m) wide, CL are a must frankly, especially in low vis conditions. ICAO seems to think so, and it was one of the recommendations in the final report of the runway excursion of the AC A320 at YYZ on rwy 15R a few years ago.
https://www.tsb.gc.ca/eng/rapports-repo ... o0025.html
Recommendation.— Runway centre line lights should be provided on a precision approach runway category I, particularly when the runway is used by aircraft with high landing speeds or where the width between the runway edge lights is greater than 50 m. ICAO's Aerodrome Design Manual expands on the usefulness of centreline lighting, stating that
The function of the centre line lighting is to provide the pilot with lateral guidance during the flare and landing ground roll or during a take-off. In normal circumstances, a pilot can maintain the track of the aircraft within approximately 1 to 2 m of the runway centre line with the aid of this lighting cue. The guidance information from the centre line is more sensitive than that provided from the pilot's assessment of the degree of asymmetry between the runway edge lighting. In low visibility conditions, the use of the centre line is also the best means of providing an adequate segment of lighting for the pilot to use. The greater distances involved in viewing the runway edge lighting together with the need for the pilot to look immediately ahead of the aircraft during the ground roll also contribute to the requirements for a well-lit runway centre line.Footnote14
In the US, you have a lot of CATI ILS runways with proper lighting that have RVR1800 minimums with no Ops Spec. You don't have that many runways here in Canada that fit that bill.
This is why Canada has this whole approach ban concept. Our runways aren't properly equipped, so the onus is on the aircraft and crew to be able to go below published minimums, if they qualify for the Ops Spec. BTW, I find it silly that the general approach ban allows carriers to go 75% of advisory vis without an Ops Spec, considering how badly lit our runways are. That shouldn't be allowed, but it's an improvement of what the rule was before 2006, which is when TC last made significant changes to the approach ban rules.
Knowing this, I wouldn't hold my breath for them to do it again anytime soon.
http://picma.info/sites/default/files/D ... %20Ban.pdf
So do that then. Have the airport authority properly properly equip the runway. Or *gasp* put in a CAT 2...
Instead they spend money on art installations and vanity projects and put the onus on us to try to keep the operations going and land in below charted conditions at their poorly equipped airports.
Never mind try to understand the TC gobbledygook on if you can or can't... this whole business is getting over regulated to make up for the short comings of the regulator. KISS... use charted vs... and don't bother trying to ask what my legal duty day is or what the latest reissued bulletin about a bulletin about a bulletin is... fucked if I know anymore.
