Amputee PPL
Benm11
Amputee PPL
Post by Benm11 »
Hey everybody,
I have a buddy who lost his leg above the knee in Afghanistan who reached out to me recently about doing flight training. He wants to do his PPL and bush flying (tail wheel and floats).
Is there anybody who has prior experiences who I can get in touch with and try and get him set up?
Thanks for your help.
200hr Wonder
Re: Amputee PPL
Post by 200hr Wonder »
I would start with talking to a CAME for a medical. Without one he can not hold a PPL. Obviously missing the leg will require some hoops to jump through however Transport Canada is usually reasonable about getting people in the air if they can. Once that has all be sorted and what would be required in terms a prosthetic any school can do the training.
200hr Wonder
Re: Amputee PPL
Aircraft are available with hand rudder controls for people without the use of both feet:
https://www.freedomintheair.org/hand-controls/
Per the Handbook for Civil Aviation Medical Examiners:
Locomotor
Pilot applicants should be assessed for the ability to undertake flight operations in normal and emergency situations. In the case of amputation or paraplegia, special practical tests will be ordered by the RAMO to determine the applicant's suitability for flight.
RedAndWhiteBaron
Re: Amputee PPL
Post by RedAndWhiteBaron »
We have a double amputee at my soaring club. I'm not sure how he lost his legs, or what hoops he had to jump through for his GPL, but he does fly a specially modified sailplane with no issues.
Of course, there's no throttle or mixture controls or flaps to dick around with either, so it may be easier to get a GPL than a PPL as an amputee. I'm not sure.
Re: Amputee PPL
200hr Wonder wrote: Sat Jul 04, 2020 12:22 pm Obviously missing the leg will require some hoops to jump through
On a more serious note, it is definitely possible. This Begium club (you'll have to find a translation) https://www.handflight.be/ operates a plane with removable controls etc. People do get their PPL with lower leg issues.
Good luck!
Re: Amputee PPL
Good luck to him. I'm personally rooting for his success.
Re: Amputee PPL
I knew a fellow who lost a leg below the knee (having earlier lost an eye), he got a PPL no problem in a standard C150, with just a funny bracket I made on the rudder pedal. He worked it out so he could work the toe brakes fine. Your friends aspiration for tail dragger and skis might introduce a bit more challenge, but he won't know till he tries....
Re: Amputee PPL
It might be easier to do the ppl on floats if you have trouble adapting a plane. No brake issues... Although getting in and out of the airplane might be significant harder, be it in normal or emergency ops.
Cessna 180
Re: Amputee PPL
Post by Cessna 180 »
I know a guy who is missing a leg who got a Cat 1. I think there was some run around, but he eventually got it. I'd recommend Dr. Gilmore for any less than regular medical issues. He knows who to talk to to make it work (if it can).
RedAndWhiteBaron
Re: Amputee PPL
PilotDAR wrote: Sat Jul 04, 2020 6:53 pm I knew a fellow who lost a leg below the knee (having earlier lost an eye), he got a PPL no problem in a standard C150.
Jesus. I'll stick that one in the back of my head to remember, when I think that I've been dealt a bad hand. I'll bet my left testicle he has one hell of a story to tell, your friend.
It does make me wonder - how does one activate BOTH toe brakes with one leg in an unmodified plane? In a glider it's easy - the spoilers also activate the wheel brakes - and usually it's just a single belly wheel with brakes, but that's a one handed control.
broken_slinky
Re: Amputee PPL
Post by broken_slinky »
We have a local pilot who is wheelchair bound and has the plane configured with hand controls. As others have stated, I'm not sure of the medical hoops that had to be jumped through or training requirements for insurance, etc...
Flyboy757
Re: Amputee PPL
Post by Flyboy757 »
My dad taught a guy who was handicapped . Circa late 60`s. The guy had MD , had leg braces and walked with canes. Hardest part was getting in and out of the plane.Got his PPL on a Piper Colt....had a hand brake.
JBI
Re: Amputee PPL
Post by JBI »
Definitely doable. There will be some challenges and he may require an individualized flight test demonstrating that he can perform safely but I know of both a fellow who had an arm amputated above the elbow and another who had his leg amputated above his knee who both had commercial flying privileges.
Eric Janson
Re: Amputee PPL
Post by Eric Janson »
@Benm11
Pass this link on to your friend.
https://en.wikipedia.org/wiki/Douglas_Bader
JasonE
Re: Amputee PPL
Post by JasonE »
It could easily be done in a Cherokee. They have a handbrake available, in fact mine only had a handbrake and no toe brakes.
Re: Amputee PPL
JasonE wrote: Wed Jul 08, 2020 5:36 pm It could easily be done in a Cherokee. They have a handbrake available, in fact mine only had a handbrake and no toe brakes.
Good point! Older comanches are the same. If transport allows it, I suppose you could use the rudder with one foot. Maybe some kind of bicycle pedal bracket could be attached so the one foot can also pull on the pedal.
Re: Amputee PPL
Anything you attach to the flight controls of an aircraft is unlikely to pass the test not to be a major modification, so you will need something like an STC to fit it.
Re: Amputee PPL
Attach a hook to your shoe then, and slide it over the pedal. It would be the equivalent of wearing gloves.
futurebushpilot
Re: Amputee PPL
Post by futurebushpilot »
Contact Freedom Air at Cooking Lake, Alberta. I know that they helped a paraplegic get his PPL.
Panama Jack
Re: Amputee PPL
Post by Panama Jack »
I have a good friend who is an amputee. He holds a Class 3 medical and is an active pilot.
For real inspiration, google "Jessica Cox pilot" who has no arms. I know it's in the US and governed under the FAA, but she would be operating under an exemption. These days, it is easier than ever for pilots to get medicals as long as the authority can be convinced that a pilot can operate an aircraft safely.
-President Ronald Reagan
AirFrame
Re: Amputee PPL
Post by AirFrame »
digits_ wrote: Wed Jul 08, 2020 6:07 pmGood point! Older comanches are the same. If transport allows it, I suppose you could use the rudder with one foot. Maybe some kind of bicycle pedal bracket could be attached so the one foot can also pull on the pedal.
Shouldn't be necessary... You only push one at a time. Just move the foot over, like you do going between the gas and brake in a car.
teacher
Re: Amputee PPL
Post by teacher »
I knew of someone who did their PPL in an Ercoupe. No rubber pedals only 1 pedal for the foot brake. It had integrated rudder and ailerons through the control yoke and limited elevator movement that wouldn’t let it stall/spin.
https://en.wikipedia.org/wiki/ERCO_Ercoupe
https://eresonatemedia.com/
https://bambaits.ca/
Squaretail
Re: Amputee PPL
Post by Squaretail »
pigboat
Re: Amputee PPL
Post by pigboat »
Can also fly Gliders that are modified with hand controlled rudder. freedomswings.ca
Also a friend with no left leg was certified on Cherokee 140 and 180 back in the mid 1960 s. He had designed and built a hand control for the rudder bar and the MOT approved it.
molsonb
Re: Amputee PPL
Post by molsonb »
I'm actually a below knee amp, and I had to supply a bit more information during the medical, but all is well. Not to many hoops to 'jump' through as I feared. My instructors did a first flight to 'see' how things would go and if we had to do anything. The only tiny critic was, riding the brake since I don't have an ankle to articulate.
Since then, I've met many pilots in the amputee world. Being above knee though, most I know use a different leg/knee combo to use the peddles easier. (Smaller foot, almost peg like, so they can hit the rudder vs brakes separately). But no modifications to the plane.
