172 down Hope BC ???
Re: 172 down Hope BC ???
ahramin wrote: Fri Sep 25, 2020 7:18 pm
When flying mountain valleys, cruising altitudes is certainly on the list of considerations but I can't think of anything lower priority. It has no bearing once weather starts to be a factor.
For experienced pilots, absolutely cruising altitudes is just one of many considerations, low time pilots flying in unforgiving terrain need to give themselves every break. I have no problem with a newbie turning back because they can’t maintain 6500 West bound.
If that offends you then I guess we will just have agree to disagree.
challenger_nami
Post by challenger_nami »
Would anyone here drive on the opposite side of the highway at highway speed? ... I sure hope not.
In my opinion, it’s very unwise and inconsiderate not to respect those cruise altitudes based on direction of travel just because they are not convenient. They serve a very important purpose: They reduce the risk of Mid Air Collision for 2 aircraft in cruise by more than 50%.
That’s specially important in a mountainous area when you are boxed in a canyon. You would not want to deal with another oncoming aircraft at the same altitude coming at you at 100 knots minimum. Even if you see the other aircraft, you probably can’t descend much because of the terrain below. And you probably can’t deviate left and right because of
Mountains on both sides. And you probably can’t climb fast enough due to aircraft performance limitations.
If everyone respect their cruising altitudes, the two VFR aircraft just clear each other by 1000 ft which is plenty OR 500 ft if on of them is IFR.
Skies everywhere are crowded with aircraft. SEE & AVOID is no longer adequate enough to keep separation. Also, many VFR pilots are not proficient in properly SENDING/RECEIVING position reports over the radio.
Maintaining The proper Cruising Altitude based on direction of travel is a very effective method of mitigating the risk of mid Air Collision in Cruise.
Post by ahramin »
Would anyone here think that highway rules are relevant to the discussion? I sure hope not but proof by analogy can be awfully tempting despite being completely useless.
Cruising altitudes do not exist at and below 3000' AGL. Easy to forget but true nonetheless. There is a reason for that, and anyone trying to get people to follow rules that do not exist should think about the reasons for that lack of existence.
In my opinion it is unwise to give advice about something without having any experience in it. Anyone who has flown in the mountains in poor weather knows that if weather is a factor:
1. You aren't going to be above 3000' AGL, and
2. You will be climbing and descending as the weather and terrain permit.
Even above 3000' AGL, there aren't any cruising altitudes when changing altitude.
I just hired a pilot this week to deliver an aircraft across the coastal and rocky mountains and after looking at the weather last night he asked if he could delay the flight to Sunday since it would be better. Conditions are ok today but in the upslope areas around Hope and Castlegar it's likely to be widespread cloud and possibly impassable, while Sunday looks a little drier so the flight will be faster and cheaper. The new owner is not in a hurry so we agreed and everyone is happy that everyone knows what they are doing. If someone told me that they couldn't fly on a given day because the clouds are too low for the direction of flight, they'd be fired instantly.
By all means fly within your limits but if your decision making is that poor, your limits should be no cloud below 13 000'. I know this sounds harsh but this is a sport / hobby / profession that can have serious consequences. It doesn't always end up with some unimportant metal bent and a few scrapes and bruises. Sometimes it ends up with 3 or more dead passengers. Pilots should take that responsibility seriously and judge their decision making skills accordingly.
challenger_nami
ahramin wrote: Sat Sep 26, 2020 11:26 am Would anyone here think that highway rules are relevant to the discussion? I sure hope not but proof by analogy can be awfully tempting despite being completely useless.
I don’t know where to start responding to your post. So I ll go at it one point at a time.
So here we go.
I think you are deflecting.
But Why would highway rules not be a valid analogy?
ahramin wrote: Sat Sep 26, 2020 11:26 am Cruising altitudes do not exist at and below 3000' AGL. Easy to forget but true nonetheless. There is a reason for that, and anyone trying to get people to follow rules that do not exist should think about the reasons for that lack of existence.
No one is trying to force people to maintain the mentioned directional cruise altitudes below 3000’ AGL.
ahramin wrote: Sat Sep 26, 2020 11:26 am In my opinion it is unwise to give advice about something without having any experience in it. Anyone who has flown in the mountains in poor weather knows that if weather is a factor:
If you are in the mountains, SPECIALLY around Hope (CYHE),in poor weather and you are forced to be below 3000’ AGL, you put yourself in a very bad situation probably just short of an emergency.
and YES, You should do anything you can to ensure you can get out of that situation. And as you mentioned, when safety is at risk and below 3000’ AGL, Directional Cruising Altitudes do not apply,
I don’t understand what you meant by that. Of course, when you are changing altitudes, there are no cruise altitudes.... well you are not cruising, you are changing altitude.
conditions are ok today
CONDITIONS ARE OK TODAY???
Please have a look below at the ATTACHED SCREEN CAPTURES of CYHE (Hope) Airport Camera, taken 26 Sep 2020 at around 2100 ZULU.
Please tell every one you call that visibility and those clouds OK for flying VFR around those mountains toward Castlegar.
  • It seems like you believe you did a huge favour to your pilot by not firing him for not flying today.
  • And It sounds like if your customer ( the new owner ) was in a rush to have his airplane sooner, you would actually force your pilot to fly through the mountains today, or risk being fired instantly. UNBELIEVABLE!!!
My suggestion to your pilot would be to quit working for you.
And I ask you to hire me, so you can INSTANTLY fire me when I refuse to go on a flight due to the weather and cruising altitude, as you promised above.
Then I would respectfully take your business to the court and Transport Canada and see if we can make aviation safer by having your operation shut down for disregarding the rules which are meant to keep everyone safe.
And Yes. I fully agree with you.
All of us, pilots and aviation company owners and operators, should respect the rules and not try to push the envelope and bend the rules. We also shall not force our employees to push the envelope or risk being fired, instantly.
If we don’t respect safety rules, that’s when airplanes end up in the trees, as the airplane in the original post did. Luckily there was no loss of life in this case. However, now General Aviation insurance premiums will rise because of this accident and the many others similar to this one. These types of accidents can be prevented.
Also, as one of the moderators of this forum you have the added personal responsibility of promoting safety, and sadly you are doing the opposite.
I respectfully hope you reconsider.
Post by ahramin »
Lets get our discussion straight Challenger_nami since you seem to be drifting away from the point under discussion.
I was responding to this comment:
Big Pistons Forever wrote: Thu Sep 24, 2020 9:48 amI told my students when approaching the Valley you must be able to maintain 5500 or 6500 ft ( dependent on direction of flight
ahramin wrote:When flying mountain valleys, cruising altitudes is certainly on the list of considerations but I can't think of anything lower priority. It has no bearing once weather starts to be a factor.
to which you said
challenger_nami wrote: Sat Sep 26, 2020 6:08 am In my opinion, it’s very unwise and inconsiderate not to respect those cruise altitudes based on direction of travel just because they are not convenient. They serve a very important purpose: They reduce the risk of Mid Air Collision for 2 aircraft in cruise by more than 50%.
But now you are saying
challenger_nami wrote: Sat Sep 26, 2020 12:55 pmwhen safety is at risk and below 3000’ AGL, Directional Cruising Altitudes do not apply
So I'm glad we agree. It's possible that you came into this discussion without realizing that the comment I was responding to was about weather minima for going through a certain route, obviously that's going to be below 3000' AGL at the highest terrain.
As for the weather today, the pilot in question said today might be ok based on the forecast yesterday. The flight was already scrubbed so I haven't checked the weather today. I can see how my comment could be construed to mean that I have checked the weather today and concluded that it's ok. I haven't, my apologies.
The highest terrain along his proposed route of flight is 4350'. I wouldn't go through there at less than 5400' ASL. If someone told me a 6000' ceiling is fine to go through that route Eastbound but not Westbound then yeah, they'd be fired. If you want to charge $500 a day to move a Cessna for me you need better decision making abilities than that.
Lastly analogies are useful for helping someone understand something they are having trouble with. An analogy doesn't explain what is going on and it certainly doesn't prove a point. It's obvious that no one here is suggesting driving at highway speeds down the left side of the highway, just as it should be obvious that this does not apply to a one way street, or an aircraft.
patter
Post by patter »
It was really ugly on the Coq today and at Hope today. I was so low and slow....
In around 2100
challenger_nami
I Personally absolutely believe in what Big Pistons is saying here:
I was completely in the loop of the conversation. I read what you wrote here and I slightly disagreed with the low priority angle of it, but I was not really responding to you.
I indirectly made the following comments to the gentleman who was saying he always flies even numbers, regardless of the direction.
I stick with to my comments above. Cruising Altitudes are important.
Many aviation restrictions get eased OR go out the window when the safety of flight is in question. However it’s important not to Flight plan based on that ease of restrictions when you are on the ground. Those shall only be used in the cockpit when dealing with an unforeseen potentially dangerous situation.
The Direction Based Cruise Altitudes are based on the one way streets and Highways, so I still stick to the analogy.
I am glad we straightened this up Ahramin.
challenger_nami
Here are my suggestions for someone who is planning to fly through the BC Mountains around CYHE for the first time. Due your due diligence and consult with an approved flight instructor.
Proper weather and flight planning is the key to having a safe flight in that route.
. Review all the GFAs available at the time of your flight planning and flight itself, and understand them.
. Get a proper Weather briefing from Kamloops Flight Information.
. Know the wind direction and intensity, and how that affects your flight ie: turbulence
. Look at CYHE (hope) airport weather Camera, and have a clear understanding of what you are looking at.
. Don’t rely on CYHE (HOPE) METAR. it’s an AWOS and like other AWOS systems, it’s only reporting what it sees above a small cross section of its sensor ... it’s really really inaccurate, in my opinion.
My suggestion to Nav Canada: deactivate the AWOS as it can be very misleading. Instead, invest in a better airport weather camera system.
. Have LOTS of extra fuel.
. If you are planning to get fuel at an airport along the route of flight, be sure to check the notams for Airport Being Open and Fuel being available when you get there.
. Shed as much as payload weight as you can
Flying East Through the mountains from HOPE eastbound:
5500’ should be tried by an experienced pilot who is familiar with the area in a more powerful aircraft which is loaded at less than 50% of the max payload ... in case the aircraft gets caught in the downdrafts associated with the mountains.
For someone who is not familiar with the area,or in a less powerful engine or heavily loaded airplane, or with less overall flying experience 7500’ is more favorable as that puts the aircraft above the height of the mountain ranges and their associated turbulence and downdrafts.
The above are my suggestions. Due your due diligence and consult with an approved flight instructor.
With proper planning, it can be a safe and enjoyable flight.
Just found this TSB brief in my In Box
Occurrence No.: A57P0001 Occurrence Type: ACCIDENT
Class: CLASS 5 Reportable Type:
Date: 1957-04-24 Time: 00:00:00 UTC
Region of
Responsibility:
PACIFIC
Country: CANADA Province: BRITISH COLUMBIA
Ground Injuries: Fatal: 0 Minor: 0
Serious: 0 Unknown: 0
---------- Aircraft 1 ----------
Registration: C-FIDP Operator:
Manufacturer: RYAN
AERONAUTICAL
Operator Type: PRIVATE
Model: NAVION CARS Sub Part: RECREATIONAL AVIATION
Injuries: Fatal: 2 Minor: 0
Serious: 0 None: 0
Unknown: 0
Occurrence Summary:
CF-IDP, a privately operated Ryan Aeronautical Navion aircraft was conducting a local flight from
Vancouver International Airport (CYVR), BC with one pilot and one passenger on board. The
aircraft collided with terrain 600' below the summit of Mount Breakenridge. Both occupants on
board were fatally injured and the aircraft was destroyed. There was no fire.
Fly safely.
7ECA
Post by 7ECA »
And what does an accident that occurred in 1957 - that is 63 years ago, have to do with the rather markedly questionable decision making displayed by this 172 pilot?
7ECA wrote: Mon Nov 16, 2020 12:21 am And what does an accident that occurred in 1957 - that is 63 years ago, have to do with the rather markedly questionable decision making displayed by this 172 pilot?
I’m sorry about causing such concern for you. I shouldn’t have assumed how obvious it would be in a thread discussing the hazards of CFIT near Hope that you would not realize that this was another CFIT near Hope as was highlighted in bold.
Therefore, I will also add it to a thread I started recently that is even more appropriate.
Apologies once again for the confusion.
karmutzen
Post by karmutzen »
Two different accidents, connected by the weather theme. Hitting terrain 600’ below a peak suggests inadvertent IMC and an attempted climb, CFIT. Brushing trees on an attempted 180 is delayed recognition of turn radius in rising terrain. You could relate both to mountain training and experience. I recently went through there with the AWOS calling 600/2 (in a helicopter, wouldn’t have wasted my time with an airplane). That’s a ceiling of 600’ looking straight up with possibly/probably lower stratus, and ground viz of 2 miles. You won’t have 2 miles at 600, might not even have one mile.
Both incidents are worth discussing for their respective insights into dynamic mountain decision making.
challenger_nami
HOPE (CYHE) AWOS is so dysfunctional. Let me paraphrase it: CYHE AWOS, is like any other AWOS and is limited to the small cross section of sky above its sensor, which is not representative of the conditions in the other quadrants.
AWOS works well In the rest of Canada where there are not much mountains, but not in CYHE. due to the CYHEs location in close proximity to deadly terrain, the inherent inaccuracy of the AWOS gets magnified tenfold. Often, the CYHE AWOS gives better than actual weather information and a false sense of security to the pilots who are unfamiliar with the area.
It might be a good idea for NavCanada to remove the AWOS system at CYHE and install more accurate Weather Cameras there.
Last edited by challenger_nami on Mon Nov 16, 2020 1:15 pm, edited 1 time in total.
challenger_nami wrote: Mon Nov 16, 2020 10:00 am
It might be a good idea for NavCanada to remove the AWOS system and install more Weather Cameras.
Cameras are a very good idea.
cncpc
Post by cncpc »
Yep. Great idea.
AWOS? You might as well ask a cow.
patter
Post by patter »
It’s a rather bold comment to tell a pilot to ask a flight instructor for advice about flying in the mountains on the Vancouver coast. Their experience is usually quite limited in mountain flying.
Although it was not in the Hope Princeton, there have been a few crashes by flight instructors in the mountains in the Coastal Region.
The accidents near Tipella with instructors, resulted in death, and serious injuries. There have been others as well. Be careful who you talk to.
New flight instructors on the coast have had maybe a mountain cross country for a couple hours, and most of their cross country has been above the mountains. And they teach mountain cross countries.
If you are going to fly low in the mountains along low level routes without experience, fly it in good weather first.
Cruising altitudes low in the valleys is a joke. If you are low in the valleys and inexperienced on the route, fly with altitude above you and below your position. Always keep a turning radius. Your visibility should be at least 6 miles and watch your OAT. Your goal is to be an old pilot like me, and have common sense.
Where I am I at the moment, we had warmer air 1000 feet above the ground and freezing at the surface. Snow at the surface and liquid at 1000. Nothing in weather reporting to say so.
My latest favourite weather map for general and broad information accross the country is Ventusky.
I like the current Hope set up regarding Nav Canada weather.
cncpc
Post by cncpc »
challenger_nami wrote: Sat Sep 26, 2020 6:28 pm Here are my suggestions for someone who is planning to fly through the BC Mountains around CYHE for the first time.
What are your qualifications to make these suggestions?
challenger_nami
cncpc wrote: Mon Nov 16, 2020 2:31 pm
There you talk again CNCPC ... my qualifications are More than .yours.
Last edited by challenger_nami on Mon Nov 16, 2020 2:52 pm, edited 1 time in total.
patter wrote: Mon Nov 16, 2020 1:52 pm It’s a rather bold comment to tell a pilot to ask a flight instructor for advice about flying in the mountains on the Vancouver coast. Their experience is usually quite limited in mountain flying.
Agreed. Most I've met have little to no experience in IMC, either, even in flat terrain.
Some things it's better to learn from a very experienced mentor pilot, if possible.
karmutzen
Post by karmutzen »
There’s already more than 10 cameras within 10 miles of Hope. NavCanada, DriveBC, private, (try Windy.com) and I use them all. How many more do you think you need???
challenger_nami
:prayer:
Of course there have been accidents with instructors as well. But if you do the math, you will see a lower number of accidents caused by instructors as opposed to some random pilot.... and when I say instructors, I don’t mean some new class 4 instructor, I mean more experienced instructors with mountain experience.... specifically, the instructors who teach in Squamish airport.
for the record, I am not an instructor.
@PATTER,
I don’t know how you can possibly like the current Hope setup.
ATTACHED is what the AWOS is reporting at the time of me writing this at 2200zulu on the 16th.
the AWOS is reporting 8 SM VISIBILITY, when you look at the images and references, you can clearly see the visibility is barely 1.5 mile.
The AWOSis reporting clouds at 3000’.but it is not even detecting the few or possibly scattered clouds at around 1500’ over the circuit.....
and that is how people end up crashing: the pilot looks at the AWOS and sees 3000’ and 8 am visibility .... then ends up in 1500’ scattered at 2 mile visibility .... with 4000’+ mountains all over.
@Karmutzen
The more the merrier.
Plus, when we talk about Camera’s , we are talking about aviation cameras with references such than as a pilot you can interpret Ceiling and Visibility from the image .... not just some random traffic camera.
Last edited by challenger_nami on Mon Nov 16, 2020 3:44 pm, edited 1 time in total.
shamrock104
Post by shamrock104 »
I have had students approach me and ask for a Mountain check out and to me that's the blind leading the blind. As much as I would like to I direct them to find someone with a ton of experience and go fly with them. They of course do not have to be Flight Instructor"s.
The AOPA has some good material on safe flying in the mountains. (And all kinds of flying)
They had a great online course I recall taking but I can't seem to bring it up. Might have been decommissioned.
https://www.aopa.org/training-and-safet ... -mountains
As for flight instructors being any guarantee----
When searching I found this, a 1700 hour CFI who decided to take off, in the mountains, at gross weight, on one magneto.
https://www.aopa.org/training-and-safet ... ain-flying
This is another one, with a CFI, a 172 trying to fly through mountains with 60 MPH winds. Caught in mountain wave....
https://www.aopa.org/training-and-safet ... flying-(2)
patter wrote: Mon Nov 16, 2020 1:52 pm Be careful who you talk to.
Something I have stated many times and agree with
patter wrote: Mon Nov 16, 2020 1:52 pm If you are going to fly low in the mountains along low level routes without experience, fly it in good weather first.
Thanks for the advice
I claim very little experience with the type of mountain flying that poor weather at Hope demands, I've only done it four times, with great caution and planning each time.
Though I respect the role of an instructor, that role is to instruct. An instructor has demonstrated skills in instructing, not necessarily mountain flying. Just as an instructor could be awesome at instructing, but have no tailwheel time, and thus be a poor instructor in a taildragger. If you know an experienced mountain pilot, who's also an instructor, perfect, ask them!
Of course, inexperienced pilots should seek mentoring for mountain flying. I'm not quite sure how the effectiveness of that training is measured, but I'm sure that "instructor" is not an automatic qualification to give that training.
I sent an experienced flatland pilot on a three day "mountain course" taught in Calgary, many years ago, as he was being sent (in the plane I was responsible for) to fly in the BC mountains. He died doing an unwise thing in a valley (during CAVU), which I would have hoped that the mountain course would have taught him not to attempt. So much for "mountain training" by who knows whom!
As for airplane performance, I have learned that moving mountain air can outperform any GA plane, so avoidance is the best plan.
even though I probably know more than you, PATTER
How have you made that determination Nami? And, how is it useful?
