goingnowherefast wrote: ↑Sun Sep 27, 2020 6:27 pm It's been a number of years since I flew a King Air. However, there was always several hundred pounds left in each main tank. The aux tanks were usually bone dry. I emptied the aux fuel before reducing the quantity in the main tanks. I did it that way because that's what the AFM says. The King Airs I flew, the aux tank pumps had 3 options, ON, AUTO or OFF.
Been a while since I flew Navajos too. Take-off and landing is to be conducted on the inboard tanks, and I always had lots of fuel in those tanks. The outboard tanks were usually sucked dry, not to the point of the engine stumbling, but very close. I'm not going to leave 30 minutes of fuel in the outboard tanks because I'd rather have that fuel in the inboard tanks. Get stuck with unforecast weather and a diversion, I'd rather have 45 minutes in the inboards than 15 minutes in the inboards and 30 minutes in the outboards. That's just good fuel management.
goingnowherefast wrote: ↑Mon Sep 28, 2020 3:16 pm Every king air and 1900 has the same basic fuel system. Exception being the original 100 and perhaps the 90 series (never flew any of the King Air 90s).
So to answer your question, I'm referring to the A100, 200, B200, 300, 350, 1900, 1900C, 1900D. Transfer ALL the aux fuel into the mains. If the mains aren't full, there better be no fuel left in the aux tanks (exception being an aux transfer failure, but that's through no fault of the pilot).
the Beechcraft King Airs A100, 200, B200, 300, 350 and 1900, 1900C, 1900D which as you correctly indicated, have the same fuel systems. In these aircrafts the fuel from the Auxiliary tank automatically gets fed to the engine. The pilot does not have any choice in that and can’t stop/change the process even if (s)he really REALLY wanted to. The fuel in the Auxiliary tanks get used before the main tanks, unless there is a malfunction. That’s how the system is designed to function,
so when you say you did it that way because the AFM tells you so, that’s inaccurate: You had no other options.
Now if I am not correct, I appreciate if someone current & credible can refer me to the appropriate AFM.
You were right about About Navajo’s. You have the option to use either Inboard or outboard tanks. As far as remember, the only limitation was that you can only take off and land on the inboard tanks and can only use the outboard tanks in cruise or non critical phases of flight.
There was no limitation as to whether or not the outboard tanks needed to be fully empty for take off and landing. I am rusty on the Navajo, so if I not correct, I appreciate if someone current & credible can refer me to the appropriate AFM.
