iflyforpie wrote: ↑Sun Jun 21, 2020 8:00 pm
trey kule wrote: ↑Sat Jun 20, 2020 10:33 am
Ah yes...the internet.
I should have been more precise. Single engine piston,
The Caravan provides a very much larger margin of reliabilty.
In the BC South East Fire Centre, where I flew for most of a decade among peaks that were 2000-5000 feet higher than we usually flew for survey and patrol work... they tried to make multi engine aircraft a requirement.
Until it was pointed out that every fatal fixed wing accident that happened doing forestry work for SEFC was a multi engine aircraft.
I didn’t feel any safer in a 337 than I did in a 206. Stall speed is higher, turn radius larger, the fuel management is more complex than nearly every turbine aircraft in existence, twice as likely to have an engine failure, and the remaining engine was quite unlikely to get you back to an airport.
Same gig in 2009. Out of Nelson, with a Hicks and Lawrence leased 337. Patrols and bug mapping. A lot of flying that year.
I was going to answer Trey specifically on SEFC policy, but I sensed they have lapsed that. I know Thierry gets the call for a 172 out of Nelson for patrols. When I was there it still was a twin requirement, but those guys at Creston got single engine work. So, not a hard requirement, but a preference, as you say.
It is true that you have twice as much chance of an engine failure on a twin than a single. On the other hand, you have a chance of making it to an appropriate landing area in the twin, if you can handle the single engine work. Obviously, that doesn't hold true on an engine failure just after rotation. I've never had one calve on the 337, but I don't see a failure at altitude as a problem. I did one trip with an observer who had worked for another company with 337s, and she told me they she was on a flight where both engines failed from fuel exhaustion, and she was very nervous. They failed back by Balfour/Harrop at patrol altitude and the guy deadsticked it onto Nelson, 19 miles away. She said it was very close.
Still, if it was some other cause, and one was still running, obviously it would have went quite a bit farther than that. Especially staying above waterways. Certainly Creston, Castlegar, and Trail would be makeable.
I don't recall any issues with steep turns mapping a fire, but I told them I'm not doing steep turns in a canyon 200 feet off the ground. I said, I'll report what I can safely fly over, and you can send a helicopter to look at it. And they did.
That is unique territory. You have next to dick all for options in a single. Other than lakes, which I guess are fine if you can make it to some shallow shoreline.
The one thing that was "special" about the 337 was that minimum speed to raise the gear thingie. If you had an engine failure and were below that speed you couldn't raise the gear. I think the speed was 103. The problem was that broken legged dance the gear does going through the up transit caused more drag than just leaving it down. I do think an engine failure on take off in a 337, depending on load, is a perilous situation. I think once you have the gear up, and are above 500 feet, you've got a good shot at getting back down.
When I took off from Nelson towards the Prestige, as soon as I lifted off, I would move the nose to pointing to the lake, so I had that option. Then stay low and immediately pull the gear up. I think we'd have done fine. Fuel fuel, but only two on board.
This Babine crash is likely going to result in another look at procedures within the Forest Service. I do credit them with having more than minimal aviation safety smarts. I think they frequently bring in expert advise.
