182 down by Smithers
Re: 182 down by Smithers
pelmet wrote: Sat Nov 07, 2020 6:23 am
photofly wrote: Sat Nov 07, 2020 6:21 am
pelmet wrote: Sat Nov 07, 2020 6:09 am
I think that you may have come to a conclusion and are now coming up with complicated ideas to back up the conclusion. I suggest testing it out on an appropriate aircraft and then get back to us with the results.
Even NTS and Beta Follow-up are designed to coarsen blades to reduce drag on certain turboprop engines. The coarser the prop, the less the drag.
I agree with that. (There’s nothing really very complicated about looking at the aerodynamic forces on a propeller blade).
So you agree that selecting full coarse on the blades on a windmilling prop will increase the glide distance.
I agree that the drag goes down when the blades are coarser. It’s certainly true for a stopped prop, and a reasonable proposition for one that’s windmilling. I have to go and see if in a piston single with the throttle closed the prop control still affects the blade angle. I don’t know if it will come off the full fine stop at such a low rpm. But I’ll take ahramin’s word for it, until I get a chance to try it.
Nevertheless, a rotating prop should not be thought of as generating force by “flat plate area”: look at the braking effect of a “discing” prop due to negative blade AoA. The rotation of the blade makes a big difference when compared to the drag generated by a stationary one. I would not trust reasoning based on “flat plate area” even if the conclusion is correct.
Even with a stationary blade, airplane drag is not due to “flat plate area” but due to the blade being stalled (with the opposite sign of AoA to when it is turning and producing thrust, but it’s still stalled.) As the stationary blade turns coarse, its AoA decreases, and it unstalls, decreasing drag. A feathered prop is one with zero AoA: least drag.
I’m not sure about the throttle position: intuition says opening the throttle will decrease the resistance to turning the prop, increasing the windmilling speed and absorbing more energy from the aircraft, which is not what you want. My intuition is usually pretty good, so if you have reason to understand the opposite, I’d like to hear it. It’s a harder experiment to carry out, because with a functioning engine opening the throttle will provide power. I guess one could experiment with the magnetos shut off.
photofly wrote: Sat Nov 07, 2020 6:27 am
I agree that the drag goes down when the blades are coarser. It’s certainly true for a stopped prop, and a reasonable proposition for one that’s windmilling. I have to go and see if in a piston single with the throttle closed the prop control still affects the blade angle. But I’ll take ahramin’s word for it, until I get a chance to try it.
It makes perfect sense that Ahramin had an rpm decrease due to coarsening. No need to test for yourself as you have no doubt already witnessed the same thing many times already. One can see it on a PT-6 and PW100(both of which I have operated) on the ground when the engine is started in feather and then the props are moved out of feather and vice versa in terms of rpm. There is a huge difference in rpm due to the change in drag. probably no different than when we used to note the drag while holding one's palm outside the car window a 60 mph with palm facing wind and palm 90° to wind.
Watch the blade angle change and see the rpm increase...........
https://www.youtube.com/watch?v=JdjIsEJsUY4
Watch the blade angle change and see the rpm decrease(followed by a separate shutdown)......
https://www.youtube.com/watch?v=Y_m44Q-ti4Y
pelmet wrote: Sat Nov 07, 2020 6:49 am
The question being discussed is specifically about a 182:
Wouldn't a 182 glide further with the prop in full coarse?
Piston singles in general have and the 182 in particular has a very different constant speed units to piston twins and turboprops. As you will know, single engine CSUs default (via a heavy spring) to full fine pitch and use a rise in oil pressure to turn the blade coarse when the RPM rises above a threshold set by the prop lever. Since there is no operational advantage to governing a prop in the typical range of a windmilling blade I’m not confident the CSU is designed to govern as low as 1200-1400 rpm on a 182. Hence my doubt that moving the prop lever of a 182 in a glide changes the blade angle at all. If it doesn’t, then the answer to Joe’s question, as posed, is “no”. But that bit is easy for me to test, since I own one.
Regarding the videos: I don’t think conclusions from engines under power apply to drag from windmilling props.
I believe we are using the word drag differently - both correct, but in different contexts. I was referring to airframe drag retarding the forward speed of the aircraft. For maximum glide range, that is the force that must be reduced. I’m unable to connect rpm changes (with pitch) of an engine under power to the quantity of interest.
Gyrocopter pilots might be able to add to the conversation: the rotor of a gyrocopter is always under autorotation like a windmilling prop blade.
photofly wrote: Sat Nov 07, 2020 7:03 am
Piston singles in general have and the 182 in particular has a very different constant speed units to piston twins and turboprops. As you will know, single engine CSUs default (via a heavy spring) to full fine pitch and use a rise in oil pressure to turn the blade coarse when the RPM rises above a threshold set by the prop lever. Since there is no operational advantage to governing a prop in the typical range of a windmilling blade I’m not confident the CSU is designed to govern as low as 1200-1400 rpm on a 182. But it’s easily tested: I own one.
I believe we are using the word drag differently - both correct, but in different contexts. I was referring to airframe drag retarding the forward speed of the aircraft. For maximum glide range, that is the force that must be reduced. I can’t connect rpm changes (with pitch) of an engine under power to that.
I believe that the rpm changes on the propeller are due to changes in air resistance(which some might call drag). This explains the change in rpm that Ahramin experienced.
Then there is the the drag on the aircraft which affects the glide range. Coarser pitch means less drag on the aircraft which is why the propeller blades are feathered if possible to reduce drag.
Therefore, greater drag to propeller blade rpm means less drag on the aircraft forward motion.
The intent of the videos is to show the effect of propeller aerodynamics. Coarsen the blades and look at what happens. Of course This can be overcome by increased power(ie fuel flow) but that is not the intent of the PW100 on shutdown so there is not an fuel flow increase.
However, one need only look at the Allisons on this Electra to see the coarsening being used differently for more power. The engines are operating at 100% as it taxies out to the runway(which is why it is so damn loud during taxi). One might ask how the engines can be operating at 100% while taxiing. The blade angle is at high pitch with not too much forward thrust. Then the power is added for takeoff but the rpm remains at 100%. What happens is the blades coarsen significantly. This means much more drag(air resistance to rpm) but also increased thrust due to higher propeller pitch. Increased fuel flow is required to maintain the 100% rpm that is creating more thrust with higher blade AOA. A lot more fuel is required with the blade angle continuing to coarsen to the takeoff setting.
https://www.youtube.com/watch?v=JRd4iuC ... =emb_title
Of course, for the engine out scenarios we were discussing, it is with an engine that has lost power where the propeller is driving the engine instead of the normal opposite situation.
Of course, for the engine out scenarios we were discussing, it is with an engine that has lot power where the propeller is driving the engine instead of the normal opposite situation.
I don’t think you can dismiss the difference in a throwaway line at the end of a post, as though it’s a minor detail.
Why do you recommend opening the throttle?
photofly wrote: Sat Nov 07, 2020 7:40 am Why do you recommend opening the throttle?
Best explained in this article here with no clear answer as to why......
https://books.google.ca/books?id=1bkFXh ... ce&f=false
Post by ahramin »
I had a closer look at the data and the average increase when going to full fine was 141 RPM. This is a minimum though as I never waited for it to stabilize before adding power. This was at speeds from 70 to 80 knots. Another interesting point is that the RPM slowly but consistently decreases during the descent, maybe because of engine cooling.
Test Card 8.jpg (997.71 KiB) Viewed 3283 times
According to Peter Garrison(who some on this forum have indicated is well respected).....
"The most important thing to remember, in airplanes with separate prop and throttle controls, is throttle forward, prop back. Glide at your approach speed, with the throttle open and the prop in coarse pitch — that is, low rotations per minute."
https://www.flyingmag.com/glide-sail-so ... can-do-it/
From another article by someone experimenting with a C210......
"Part of the best-glide procedure should be to clean up the airplane: flaps and landing gear retracted, cowl flaps closed, rudder trimmed. With a variable-pitch prop, pull back the prop to as slow a speed as possible. Years ago, as part of establishing power settings in typical configurations and generally getting to know our then-newly-purchased Cessna 210, we discovered that, with the aircraft clean, at idle, and best-glide speed, pulling back the prop reduced drag so we could trim up, lowering the descent rate from 2000 to 900 fpm, a difference of 1100 fpm.
Years later when we replaced the prop with a shorter, modern prop with less drag, the difference was only 750 fpm, but still significant. We also learned the big gear doors act as excellent speed brakes, increasing the descent 1200 fpm. Try this prop exercise yourself (another great excuse to go flying) at a safe altitude, and assuming the engine has cooled and the airspace is clear. You can also use this time to determine an approximate descent rate for your plane, to help determine gliding range should an aircraft engine failure happen to you."
https://disciplesofflight.com/dealing-w ... in-flight/
I personally, have never experimented with this idea. It is interesting in the difference created by different sized props.
marlin
Post by marlin »
Something I feel is worth mentioning - it very much depends on what kind of propeller you have on your airplane. Most piston singles don't roll out with a feathering propeller.
http://www.sq44.cawgcap.org/uploads/ngr ... cerpts.pdf
Page 2-5 shows the high and low ranges of motion in a factory standard Cessna 182R. The range of motion between low and high pitch is 14.4 degrees (between 15 and 29.4 degrees) between low and high stops.
https://desertflying.club/wp-content/up ... ec-POH.pdf
Conversely, Page 2-2 of this Aztec manual gives you 65.5 degrees of prop pitch (14.5 to 80 degrees at full feather).
Regardless of whether you're even able to control prop pitch effectively after an engine failure, you aren't reducing nearly as much drag in a piston single with a non-feathering prop. I'd personally just focus on following the applicable emergency checklists to the letter - lots of other important things to do, and efficiently using the time you've already got is at least as worthwhile as trying to gain a handful of extra seconds.
marlin wrote: Sat Nov 07, 2020 3:34 pm Regardless of whether you're even able to control prop pitch effectively after an engine failure, you aren't reducing nearly as much drag in a piston single with a non-feathering prop. I'd personally just focus on following the applicable emergency checklists to the letter - lots of other important things to do, and efficiently using the time you've already got is at least as worthwhile as trying to gain a handful of extra seconds.
According to the first article by Peter Garrison, he was able to increase his gliding distance by 30% in a variable pitch single engine aircraft. Considering that the actions to do that take less than two seconds and may save your life, it is well worth considering.
marlin
Post by marlin »
Fair enough, certainly worth keeping in mind - the caveat is that this was demonstrated with a healthy engine at idle power.
If I'm not mistaken, most governor mechanisms for piston singles (with non-feathering propellers) require oil pressure to maintain that high pitch and reduced drag. If your damaged engine stops windmilling or producing idle power to run the governor pump, or if you run out of oil, the risk is that you could revert back to low pitch and increased drag - if you were relying on that performance increase to make a field, you might suddenly be SOL! I guess it depends on how confident the pilot is in the nature of the failure, and their knowledge of their airplane's specific systems.
Cliff Jumper
Post by Cliff Jumper »
marlin wrote: Sat Nov 07, 2020 5:09 pm the caveat is that this was demonstrated with a healthy engine at idle power.
I'm confused. For all of these 'trials' people are conducting, are we talking an idling engine, or a non running engine? (Ahramin, others?)
It seems to me that this difference would create wildly different results.
I'm still interested in photofly's question. Without any power (engine not running at idle) will there be enough oil pressure to drive the prop to course pitch? what min rpm does the prop need to be windmilling at, to create enough oil pressure to drive it to course, and wouldn't slowing the prop make the oil pressure even lower, causing it to drift back towards fine pitch?
The articles referenced refer to an engine windmilling in the air with magnetos off and mixture at idle cutoff, so not producing power.
Post by ahramin »
Cliff Jumper wrote: Sat Nov 07, 2020 5:35 pmI'm confused. For all of these 'trials' people are conducting, are we talking an idling engine, or a non running engine? (Ahramin, others?)
The data above was with the engine idling. I've done these tests with the mixture ICO and the results are very similar. Even though the engine is "off", it's still turning at idle speed, the governor and oil pumps are still spinning, and the propeller blade angle still changes measurably.
Post by ahramin »
telex wrote: Fri Nov 06, 2020 10:44 pm When all else fails consult the manufacturer's POH for guidance.
CESSNA MODEL 182Q
ENGINE FAILURE DURING FLIGHT
1. Airspeed -- 70 KIAS.
2. Carburetor Heat -- ON.
3. Fuel Selector Valve -- BOTH
4. Mixture -- RICH.
5. Ignition Switch -- BOTH (or START if propeller is stopped).
6. Primer -- IN and LOCKED.
FORCED LANDINGS
EMERGENCY LANDING WITHOUT ENGINE POWER
1. Airspeed -- 70 KIAS (flaps UP).
65 KIAS (flaps DOWN).
2. Mixture -- IDLE CUT-OFF.
3. Fuel Selector Valve -- OFF.
4. Ignition Switch -- OFF.
5. Wing Flaps -- AS REQUIRED.(40° recommended).
6. Master Switch -- OFF.
7. Doors -- UNLATCH PRIOR TO TOUCHDOWN.
8. Touchdown -- SLIGHTLY TAIL LOW.
9. Brakes -- APPLY HEAVILY.
No mention of prop.
No mention of trim either, or for that matter moving the yoke. The checklist contains required items but is not a complete description of how to successfully deal with an engine failure under all conditions. In many cases there is no advantage to adjusting the propeller control.
However if you get to the point in your engine failure procedure where you are selecting your landing spot and there is any doubt about being able to glide there, it should be a normal part of your flying skills to minimize drag, including pulling the prop control out to the stop.
cncpc
Post by cncpc »
pelmet wrote: Sat Nov 07, 2020 8:23 am
I remember way back in the day when Raf Zur blew a tank on a 185 in the circuit in Langley, switched, got nothing, and continued to the flare with the throttle wide open. As he was about to touch down, the engine finally fired, at full throttle, and more or less twisted out of his hands enough to hook a wingtip and bend the thing.
telex
Post by telex »
ahramin wrote: Sat Nov 07, 2020 6:31 pm
CESSNA MODEL 182Q
4. Mixture -- RICH.
FORCED LANDINGS
No mention of prop.
In what other situations would you advocate deviating from manufacturer published procedures?
cncpc
Post by cncpc »
ahramin wrote: Fri Nov 06, 2020 12:46 pm
co-joe wrote: Fri Nov 06, 2020 9:37 am Quick question, I didn't see any more mention of this on the TSB report. Quote from 1.13
and the propeller control was fully in (full fine pitch).
Yes, but I don't think it's part of the Cessna emergency procedures.
The farthest glide will be achieved with the prop stopped.
Lower compression engines like the 172 require you to raise the nose to stop the prop when the engine is windmilling. I did that by accident in a rejected forced approach to land when a truck pulled into the section of the San Mateo landfill that I was on a 50 foot high final for. I had excess speed, and pulled up sharply as the ocean was the only choice left and I had to reset. The prop stopped and I lowered the nose to start the next glide. It stayed stopped
It all happened so fast, and I knew nothing about this debate now, but it is valid. In my instructing days, at certain airports, I would pull the mixture, and raise the nose to stop the prop in forced approach practice. We then continued to a deadstick landing, or at least far enough so the student would recognize that there is a significant increase in glide distance when the prop is stopped, as it would be in quite a few engine failure situations. It's glider quiet, and the "deck angle" is noticeably less than it is when you are trying to maintain glide speed with a windmilling prop. Done it dozens of times and it certainly works.
Once the prop is stopped, it stays stopped even when the speed picks up a bit. But if for some reason, I didn't like the way the approach was going and decided to restart, or if a restart was part of the drill from the beginning, I would set the engine up and ask the student to turn the key for the starter. It only needed a couple of blades for the windmilling to start again, and it would then fire up.
Not sure how the 182 would be, given a bit higher compression. But, from my experience, it would likely glide farther with reducing the speed to get the prop to stop, and increasing to glide speed again once it had stopped.
Post by ahramin »
telex wrote: Sat Nov 07, 2020 7:29 pm
CESSNA MODEL 182Q
4. Mixture -- RICH.
FORCED LANDINGS
No mention of prop.
Lol. If trimming for 70 kts, turning towards a landing spot and pulling the prop full coarse are deviations from the above procedure, what's your plan for getting it on the ground following the checklist?
telex
Post by telex »
ahramin wrote: Sat Nov 07, 2020 8:30 pm
I suspect the difference in glide between full fine and full coarse in a single engine piston prop with a dead engine is negligible.
There is a reason why it is not in the published procedure.
It doesn't make a difference. Most pilots can process information at 70 knots.
Follow the manufacturer's published procedure.
cncpc wrote: Sat Nov 07, 2020 7:28 pm
Obviously, the full engine shutdown procedure had not been performed and the mixture was still rich.
Post by ahramin »
telex wrote: Sat Nov 07, 2020 8:41 pm
Always good advice Telex. Perhaps you'd share a bit more advice with us: If I'm cruising with the prop control at low RPM, would leaving it there be a deviation of the manufacturer's published procedure or should it be returned to full fine? Not to put too fine a point on it, the reason Cessna does not include the prop control in the checklist is not because it's vital to leave it exactly where it randomly happens to be, but for the same reason they do not include the yoke in the checklist: certain controls can be left to the pilot to decide what to do, while others must be set in a specific manner. The ones that must be set in a specific manner are the ones in the checklist.
As for the difference in glide being negligible, if that's the case why do you consider it so important not to touch it? In the aircraft I was testing last month however, the glide went from 1.4 nm / 1000' with the prop full coarse to 1.2 nm / 1000' full fine. When crossing the water from Vancouver to Vancouver Island the worst case glide to get to land is 5.5 nm. At the normal Westbound crossing altitude of 4500' full coarse gets you 6.3 nm while full fine leaves you just a little short at 5.4 nm. Just the way the math happens to work out for our particular situation here in BC but I don't consider the difference between shoreline and swimming negligible.
telex wrote: Sat Nov 07, 2020 8:41 pm I suspect the difference in glide between full fine and full coarse in a single engine piston prop with a dead engine is negligible.
Unfortunately, you don't provide any evidence, just a suspicion. As we have seen with airliners, the manufacturers procedure isn't always foolproof. And not one POH for singles recommends going to fine pitch from cruise power, just nothing mentioned.
Here is a link to a very good book about propellers.
http://dl.booktolearn.com/ebooks2/engin ... s_89bb.pdf
"In the event of an engine failure, the prop will reduce speed
to around 1200 RPM as it windmills. The power required to
cause the prop to windmill is provided by the free air stream
flowing through the prop disc. In an attempt to maintain
RPM, the CSU will decrease the blade angle to the fine/flat
pitch stop. However, a windmilling prop produces more drag
in fine/flat pitch than it does in coarse pitch. Therefore, on a
single-engine aircraft select full coarse pitch before the engine
stops running. The required oil pressure to the CSU piston will
be lost once the engine has stopped and then it is too late to
select coarse pitch. Reduced prop drag improves the aircraft’s
glide ratio enabling it to cover a greater distance in the ensuing
forced landing."
Select coarse pitch after a power loss in a piston single with a constant speed prop if you want to extend the glide range. It may save your life.
telex
Post by telex »
ahramin wrote: Sat Nov 07, 2020 10:19 pm
Do you think there might be a better flight planning option available to you in such a scenario?
Or are you so confident in your coarse pitch glide ratio that you will walk the fine line between landing or swimming?
telex
Post by telex »
pelmet wrote: Sat Nov 07, 2020 10:45 pm
forced landing."
Just nothing mentioned in the POH.
So you are better than the test pilots, engineers, and lawyers that wrote the POH?
Sure, just invent your own procedures.
