Long Landing Thread
Long Landing Thread
On some runways, you just don't mess around with anything other than a little bit of float(and it can be a good idea to specifically mention that to yourself if not used to short runways), while other runways have more margin and a continuing analysis on final/in flare is required.
This example would encompass the former......
"The pilot of C-FYFY, a Cessna 172P aircraft departed Brampton (CNC3) ON, with one passenger,
also a pilot onboard. The 2 pilots were going to fly locally and practice some inflight emergencies.
The aircraft flew to Burbank Field (CNN3) near Shelburne, ON and conducted a simulated forced
approach to Runway 08, but did not land. The aircraft came around again for a second approach
and attempted to land on Runway 08. The aircraft floated approximately 1600 feet down the 2000
foot runway before touching down. The pilot realizing the aircraft could not be stopped in the
remaining 400 feet applied full power and attempted to take off. It was reported that the aircraft
speed was low during take-off, and near the aerodynamic stall speed as the pilot attempted to clear
trees approximately 375 feet from the end of Runway 08. When the aircraft was just above the tree
tops it stalled aerodynamically and crashed in the forest. Both pilots exited the aircraft with no
injuries. There was significant damage to the aircraft."
Re: Long Landing Thread
"C-FQZM, a privately registered Piper PA-28-180, was conducting a visual flight rules flight from
Arnprior/South Renfrew Municipal Airport, ON (CNP3) to Toronto/Buttonville Municipal Airport, ON,
(CYKZ) with the pilot and 2 passengers on board. While enroute, the pilot made a decision to divert
and land at the Stirling Airport, ON, (CPJ5) due to inclement weather enroute. As the pilot
attempted to land on Runway 27, the aircraft continued to float down the runway. A go-around was
attempted however, the aircraft did not perform as expected in the hot weather. The pilot made the
decision to reduce engine power and land straight ahead. The aircraft touched down with
approximately 300 feet of runway remaining and overran the runway by approximately 200 feet,
coming to rest in a wooded area. There were no injuries. The aircraft propeller and nose landing
gear were damaged."
No mention of which runway it was. But 4 out of 6 possibilities are just over 2400' long which is not the type of runway where you want to land long when it is a wet runway. Not unexpected for a student to come in high, why not just get the student to practice their go-arounds and get into the students head that you don't accept long landings on runways short for aircraft type, especially when wet......
"C-FNJB, a Cessna 172P operated by Canadian Flight Centre, was conducting circuit training at Pitt
Meadows (CYPK), BC with 1 instructor and 1 student on board. The exercise being conducted
prior to the occurrence was practice forced landings. The aircraft's profile on final was higher than
the anticipated flight path and the aircraft touched farther down the runway than was desired. On
touchdown, the instructor took control of the aircraft and applied the brakes but unlike the previous
landing on the wet runway, the braking action was poor. The PIC determined that conditions did
not permit a go around. The aircraft overran the end of the runway, traversed a 250 foot grass field,
crossed a ditch, and came to rest in a field approximately 300 feet beyond the runway threshold.
The pilot shut down the aircraft and evacuated with the student. There were no injuries but the
aircraft sustained substantial damage to its propeller, engine cowling, windshield, lower fuselage,
and landing gear.
Maintenance crews recovered the aircraft and an aircraft maintenance organization will assess the
extent of the damage."
DHC-1 Jockey
Post by DHC-1 Jockey »
When landing in YYZ on RWY 05 in the Dash-8 during my Jazz days, the controllers frequently gave the landing clearance as "Jazz 123, cleared to land RWY 05, long landing approved." As a former controller trainee, I wonder what would happen if there was a runway over-run. Even though almost every Dash requested and did the long landing on 05, I'm just thinking of the implications of the controller "volunteering" the long landing offer if the flight crew didn't specifically request it, and an over-run incident occurred.
Canoehead
Post by Canoehead »
Thankfully that past practice has ended (Jazz pilots side). Landings are to be completed in the touchdown zone or a commence a go-around.
A346Dude
Post by A346Dude »
DHC-1 Jockey wrote: Sat Dec 19, 2020 12:49 pm When landing in YYZ on RWY 05 in the Dash-8 during my Jazz days, the controllers frequently gave the landing clearance as "Jazz 123, cleared to land RWY 05, long landing approved." As a former controller trainee, I wonder what would happen if there was a runway over-run. Even though almost every Dash requested and did the long landing on 05, I'm just thinking of the implications of the controller "volunteering" the long landing offer if the flight crew didn't specifically request it, and an over-run incident occurred.
The new MATS rule is a long landing cannot be approved unless it is requested by the pilot.
A346Dude wrote: Sat Dec 19, 2020 2:23 pm The new MATS rule is a long landing cannot be approved unless it is requested by the pilot.
Does it *need* to be approved? Which rule would you be violating if you touched down in the second half of the runway instead of the touchdown zone after you were "ceared to land"?
DHC-1 Jockey
So it's essentially the "contact approach" of landing clearances? Lol.
Zaibatsu
Post by Zaibatsu »
digits_ wrote: Sat Dec 19, 2020 2:44 pm
I’m not sure if there’s a rule per se. You won’t get violated by floating down most of the runway. As least not by TC. but it’s not conducive to HIRO. It takes a lot longer to clear the runway after a long landing than it does to land in the TDZ and take even the last high speed that doesn’t require a reverse.
Maybe there’s a new MATS that says it, but I constantly hear it offered. Same with contact approaches I guess. Preemptive offering. But If you can’t do it, don’t do it. It’s that simple.
Don’t think that no long landings make you safer. you can run a Dash 8 off 10,000 feet of runway with the right pilot.
No more circling. Spraying in sunshine. No long landings. Too bad everything has to be dumbed down to the lowest common denominator.
I was cleared to "land long" once. I was landing in Harare, where the runway is 16,000 feet long (from old BOAC Comet days, I was later told). It would be pointless to land a Twin Otter in the touchdown zone and then taxi it for three miles! I support the idea of the pilot knowing which portion of a whole runway is the appropriate part to use for the airplane they are flying. If a pilot can be trusted to accept an intersection takeoff, I don't see how choosing to land long is any different!
I've also been clear to land to hold short of an intersection, to me, that has the potential for a similarly bad outcome if not accomplished as intended.
I used to like to fly 2 dots high on the gp. It made for a nice stable and predictable path for long landings in VMC. The days of FDM made that go away though.
TheStig
Post by TheStig »
pelmet wrote: Fri Dec 18, 2020 7:02 pm Not unexpected for a student to come in high, why not just get the student to practice their go-arounds and get into the students head that you don't accept long landings on runways short for aircraft type, especially when wet......
Agreed, the current practice at airlines is to perform a landing distance calculation for every landing. As part of the approach briefing runway references (markings, adjacent taxiways, etc) are discussed for the planned touchdown point and the touchdown point limit which is based on environmental factors and runway length, with a set limit regardless of those factors.
It sounds a little arduous but it isn't supposed to be something to 'brief to death' but rather to provide clarity to the PM what the PF is planing.
Eric Janson
Post by Eric Janson »
digits_ wrote: Sat Dec 19, 2020 2:44 pm Does it *need* to be approved? Which rule would you be violating if you touched down in the second half of the runway instead of the touchdown zone after you were "cleared to land"?
I'd be violating company SOPs.
I believe this is one parameter that is monitored so you'd get a call from the safety department as well.
lhalliday
Post by lhalliday »
Here at Kamloops we routinely land long on 09 - coordinated with FSS, of course - since the taxiway to the Flying Club ramp means you'll be rolling to the end of an 8000 foot runway. Stabilized approach (always!), pick and hit your touchdown point, all the usual stuff. Pilot decision making and all that...
...laura
Eric Janson wrote: Tue Dec 22, 2020 12:14 pm
You'd be violationg company SOPs for landing long without a a specific "landing long clearance"? I've heard of companies prohibiting it completely, I've never heard of one only allowing it with a specific clearance. Interesting! Do you know what the philosophy is behind that policy?
telex
Post by telex »
"Touchdown"
"◇ The aircraft will be flown to land on the Touchdown Zone Markings. (TDZ)"
"◇ Touchdown should be at 1000ft or 300 metres from the threshold if TDZ markings are not available, to ensure landing performance."
Of course there is a difference between landing long in a DH8 vs a 777.
karmutzen
Post by karmutzen »
There's a difference between landing long in a DH8 vs a Super Cub. Especially if you are on Alaska Bushwheels and want to save as much rubber as you can on your asphalt landing. 8000' runway, if I'm exiting the end I'm going to touch down on the last 500'. Totally different in the paint-by-numbers performance-based airline world.
The Guelph Flight Centre Cessna 172 (C-FWAZ) was on a local training flight with the instructor
and student on board. On approach to runway 24 at Guelph Airpark (CNC4), ON, with the
instructor flying the aircraft, the aircraft landed long and suffered a runway excursion. The aircraft
came to stop off the runway amongst trees and shrubs. The aircraft was substantially damaged but
no injuries were reported. Runway 24 is asphalt covered and 2006 feet in length and 40 feet in
width. The runway has a displaced threshold of 730 feet. It was reported that weather and aircraft
mechanical issues were not factors in this occurrence.
Eric Janson
digits_ wrote: Tue Dec 22, 2020 1:20 pm
It's very simple - land in the Touchdown Zone or Go- around. No ambiguity.
lownslow
Post by lownslow »
pelmet wrote: Thu Jun 03, 2021 3:42 pm The Guelph Flight Centre Cessna 172 (C-FWAZ) was on a local training flight with the instructor
The rubber marks show the brakes were locked ~600 feet from the end of the runway and the plane carried on a good hundred feet after the pavement before hitting a tree hard enough to turn it 90°. I wonder how fast you have to be going at brake application to do that?
Probably not very fast. Once you lock the brakes the braking action is fairly minimal, and 100’ is fewer than three wingspans.
From Google Translate.....
C-GIOX, a Pilatus PC-12 operated by Airmedic Inc, was on a flight rules flight at
instruments (IFR) departing from Québec / Jean Lesage, Qc (CYQB) to Sept Îles, Qc
(CYZV) with 2 crew on board. The aircraft made an approach to runway 09 which
was wet and touched down approximately 3,250 feet past the runway threshold. The landing race
continued past the end of the runway before the pilot flying could stop
the aircraft and proceed to join the Delta taxiway.
http://www.gcmap.com/diagrams/pdf/CYZV.pdf
C-GHDI, a privately registered Piper PA-28-151 Warrior, was conducting a flight from
Vancouver/Boundary Bay (CZBB), BC to Langley (CYNJ), BC with the pilot and 1 passenger on
board. When approaching the CYNJ control zone, the tower controller advised the pilot the runway
had not been plowed since a recent snow fall and the runway remained partially snow covered with
ice patches. The pilot overflew the airport and requested landing on Runway 19. The aircraft
touched down with approximately 850 feet of runway remaining. While attempting to exit the
runway onto Taxiway A, directional control of the airplane was lost and it departed the paved
surface striking an airport sign with the right wing. The aircraft's right wing sustained substantial
damage. There were no injuries, and the ELT did not activate.
The aircraft was moved to the ramp and will be inspected to determine the extent of the repairs
required.
karmutzen
Post by karmutzen »
Can't find a CADORS from the usually trigger-happy CYNJ crew. Where did this summary come from?
pdw
Post by pdw »
The long landing to safely eliminate taxi time on a long runway, or the accident from float-bungling a short field landing at a shorter strip airport (usually single runway) are two entirely different worlds.
Regarding the ‘minimal float acceptance’ ? Innovative idea!
Mind you, by the second try for the threshold in that unfamiliar off airport approach with small aircraft you can also “tell yourself “ to ‘cease and go back to home base’. Sometimes it could be futile to target some of those thresholds in certain conditions, if next try maybe same thing. You could also be getting too slow on the next approach if there’s invisible high ground speed for final-approach in the works (like the Duncan instructor/student example) despite a windsock at the surface suggesting only breakeven. IMO the dates would enable substantiating that this is so often the case.
Reports of short field practise examples that go wrong need the revealing dates included to help bring to life why “float” threat has transpired unbeknownst to an unexpecting PIC. If you can reveal to a researching reader/pilot a reasoning for the extra floating and subsequently (in some cases) the degraded take-off performance accident that has followed, it can portray that profile better. The WX history date for each occurrence becomes the assist needed in developing more solid narrative on this in working on prevention.
