VSI Question
VSI Question
Can anyone explain why the VSI has an opposite indication when a climb/descent is started abruptly?
shitdisturber
- Location: If it's Monday it's got to be somewhere shitty
we did the floating book trick, and took a movie of it and then watched it when we landed. and it was ok till we started to laugh so hard that we looked in he back of the plane and all the book and stuff was floating in the storage bin... now i know why there are nets there...
Turbine twins all have or should have IVSI's just to cure that problem. An IVSI has an accelerometer that will get the thing going right direction instantly. That the "I" in IVSI.
Our IVSI actually stands for Intermittent. But we don't really have a problem with the VSI reading the wrong way as we do very little wrenching around the sky anyway.
But the best systems are the electronic variometers we have in the competition gliders. A total energy probe sticks out of the tail and measures both forward and vertical speed. If you pull back on the stick in smooth air, the vario shows no change, as you are trading off kinetic energy for potential. When you hit a thermal it shows you how much energy you are gaining. In addition you can get your climb rate integrated over the last sixty seconds at the push of a button. As well as an audible tone so that you do not have to look at the vario as you are soaring (very important when you are climbing in a gaggle with 20 other gliders).
