737 in the water off Hawaii
JasonE
Re: 737 in the water off Hawaii
Post by JasonE »
rookiepilot wrote: ↑Fri Jul 02, 2021 9:56 am Confident someone already knows the cause.
Maybe we need a poll?
It will be interesting to find out why it went down. Good to hear crew was rescued.
montado
Post by montado »
JasonE wrote: ↑Fri Jul 02, 2021 10:44 am
I looked at the flight radar and I can confirm it was a malfunction that brought this plane down. Along with some crm as a contributing factor. Recommendations in my report will include if you choose to ditch it is preferable to do so in warm water such as this incident.
Not enough checklists.
172_Captain
Post by 172_Captain »
I heard the live ATC audio about an hour ago. They lost the number one engine. Were returning to land while completing the QRH. A few minutes before they went in the were reporting that the number 2 engine was now running hot, and they wanted the Coast Guard notified and vectors to the nearest airport which was 3 miles away. That was the last call.
https://archive.liveatc.net/phnl/PHNL1- ... -1130Z.mp3
Starts at 4:35
They state they lost AN engine at 5:35
Ready to return for landing at 9:01
11:35 crew confirms it’s the number 1 engine that’s gone, 11:44 crew says they will lose the other engine, it’s running really hot
PostmasterGeneral
Post by PostmasterGeneral »
Assuming the failure mode for both engines is the same, what would cause an engine to run hot? Incorrect fuel?
Not familiar with the -200, but is there some sort of "firewall power" available on your good engine for a limited time in the event you need it? I remember on King Airs and stuff I flew without FADEC, if I needed the power to avoid a crash, I wasn't overly concerned with torque or ITT limitations.
telex
Post by telex »
JT8D allows "Maximum Takeoff EGT (5 minutes)" and "Maximum Continuous EGT".
EGT varies between the engine versions.
Screen Shot 2021-07-02 at 16.38.16.png (42.95 KiB) Viewed 6284 times
Screen Shot 2021-07-02 at 16.32.06.png (99.89 KiB) Viewed 6284 times
RedAndWhiteBaron
Post by RedAndWhiteBaron »
photofly wrote: ↑Fri Jul 02, 2021 10:50 am Not enough checklists.
Wrong. It was their instructor's fault.
montado
Post by montado »
On Jul 3rd 2021 Coast Guard men involved in the rescue reported the debris field of the aircraft was about 1.25nm long. They discovered both pilots, one (58) was standing at the tail of the aircraft waving at the helicopter, the other clinged to a cargo net of cargo swimming around the aircraft. When the aircraft sank, the one pilot at the tail momentarily disappeared, they got sight of him again while he was struggeling to stay afloat and lifted him into the helicopter at 02:58L. The pilot was exhausted and unable to talk, but was conscious. The other pilot (50) was rescued by a boat at 02:51L, the pilot had head injuries and needed to be cleaned from aircraft fuel before he walked off the boat on his own and was received by medical staff who took him to the hospital.
Incredible timing with the rescue. Sounds like arriving 15 minutes later and it could have been recovering the remains.
Old fella
Post by Old fella »
RedAndWhiteBaron wrote: ↑Fri Jul 02, 2021 10:09 pm
With the killer checklist.
Mick G
Post by Mick G »
I wonder if its possible that avgas was mistakenly put on during refueling. I'd be curious to hear thoughts from others. Is it even possible? I recall reading somethingvavout this in the past with engine temp before shutdown, but it might have been vise versa jet a, in a piston engine ?
Mick G wrote: ↑Sun Jul 04, 2021 1:01 am I wonder if its possible that avgas was mistakenly put on during refueling. I'd be curious to hear thoughts from others. Is it even possible? I recall reading somethingvavout this in the past with engine temp before shutdown, but it might have been vise versa jet a, in a piston engine ?
According to NASA:
The real show-stopper is the lead. If you got the lead out, there's no reason you couldn't use avgas in turbine engines today. The current status, then, is that turbine engines can use avgas on an emergency basis. They are certified to do so, in fact, for between 6 and 150 hours per TBO.
https://ntrs.nasa.gov/api/citations/198 ... 014186.pdf
I would opine that it is very unlikely that a refueling person who is assigned to fuel a 737 has access to Avgas (or enough Avgas) to misfuel a 737 with it. I doubt that Avgas can be pressure fueled into an airplane at all, and if you're overwing fueling a 737, something is already odd, so people would be paying more attention.
And, as Photofly has said, [at least some] jet engines can tolerate Avgas for periods exceeding the length of this flight.
stef
Post by stef »
Does 737-200 require anti-ice additive?
telex
Post by telex »
No.
stef
Post by stef »
telex wrote: ↑Sun Jul 04, 2021 12:19 pmNo.
Hmm. Probably rules out def then.
Must be difficult for them to investigate fuel contamination under the circumstances.
SAR_YQQ
Post by SAR_YQQ »
The most cringe worthy part of the Live ATC radio exchange was the NFP total lack of communication skills.
TeePeeCreeper
Post by TeePeeCreeper »
SAR_YQQ wrote: ↑Sun Jul 04, 2021 10:51 pm The most cringe worthy part of the Live ATC radio exchange was the NFP total lack of communication skills.
Did I read your comment right? If so, you’ve got to be kidding me! Sounded like they had far more pressing issues to deal with than giving ATC POB/FOB numbers… :rolleyes:
Donald
Post by Donald »
Can you expand?
SpyPilot
Post by SpyPilot »
Yes, please do expand on your idiotic comment.
Cringeworthy might not be the correct term, but just like the 777 with the engine cowl separation recently, there is a serious lack of communication from the flight crew to ATC. There's a real difference in the response required for 2 souls on board and 100, and you know they're going to ask, it would have been faster to say 2 souls and X tonnes of fuel, than to say what he said. But hey I wasn't there and I don't know the 732 at all.
geodoc
Post by geodoc »
boeingboy
Post by boeingboy »
Wow - Looks pretty intact. Basically it's in 2 pieces snapped right at the leading edge of the wing. The cockpit section looks remarkably good with only the very lower part of the lower fuse damaged, it also looks like the co-pilots #2 window was open .I'm guessing that's how both crew got out (through their respective #2 windows). Very well done for a night ditching.
cncpc
Post by cncpc »
boeingboy wrote: ↑Sat Jul 10, 2021 11:56 am Wow - Looks pretty intact. Basically it's in 2 pieces snapped right at the leading edge of the wing. The cockpit section looks remarkably good with only the very lower part of the lower fuse damaged, it also looks like the co-pilots #2 window was open .I'm guessing that's how both crew got out (through their respective #2 windows). Very well done for a night ditching.
+1 on the very well done.
Is there a shear mechanism in those -200 engine pylons?
Mick G
Post by Mick G »
cncpc wrote: ↑Sat Jul 10, 2021 7:30 pm Is there a shear mechanism in those -200 engine pylons?
Yes
