Caravan Trys to Eat Otter Tail on Saltspring
geodoc
Post by geodoc »
I bet the sound was even worse than the visuals.
https://old.reddit.com/r/vancouver/comm ... ooks_like/
Blowin' In The Wind
Re: Caravan Trys to Eat Otter Tail on Saltspring
Post by Blowin' In The Wind »
boeingboy
Post by boeingboy »
Geez - Again????
They just got the last one back on line.....
geodoc wrote: Sat Jul 17, 2021 2:23 pm I bet the sound was even worse than the visuals.
That's the sound of about a million dollars in damage and someone with some 'splainin to do! :o
fish4life
Post by fish4life »
Note to any dock guys out there if it’s going to hit and you can hold it back GTFO of there. That guy is lucky he never got severely injured by shrapnel from the prop or the tail. You can always fix a plane but a chunk of aluminum into the upper torso will end your life
I'm thinking that the understanding and use of blade latches was a factor, at the point of deciding to select out of feather following the start.
switchflicker
Post by switchflicker »
I thought the PT-6 was fitted with blade latches when on floats for the very reason to avoid the unwanted thrust when going from feather to fine/reverse. Makes me think the prop wasn't shut down properly. Maybe time will tell.
"I'd rather have it and not need than to need it and not have it" Capt. Augustus McCrae.
geodoc
Post by geodoc »
Quick video access:
Edmund
Post by Edmund »
Hard to tell but looks like he may not have been on the pitch locks and fired up. Too bad
Looks like there was a second but much gentler collision after the Caravan's tail swung out.
Post by 2112 »
pelmet wrote: Sun Jul 18, 2021 6:45 pm Looks like there was a second but much gentler collision after the Caravan's tail swung out.
Yeah saw that too, meanwhile as both guys are running in holy F#$% mode it appears the engine was still running and began spooling back up while both heads were down at the front of the float. Luckily the prop gets hooked on the otter tail again before getting up to speed and you can see the pilot run back in to grab the condition lever (I assume) when he realizes how close they both came to getting a haircut....horror show would be an understatement.
Bulawrench
Post by Bulawrench »
Look at the lack of training for both the pilot and dock hand. Seair continues to become the new West Coast Air. :lol:
Lucky no one lost an arm or worse.
trey kule
Post by trey kule »
Sad to see a couple of nice aircraft damaged.
Good no one was hurt.
Life will go on.
Accident speculation:
PT6-114A
Post by PT6-114A »
if it did not have prop latches why unite it from the dock till it is running and the prop is under control?
cncpc
Post by cncpc »
trey kule wrote: Mon Jul 19, 2021 11:55 am Sad to see a couple of nice aircraft damaged.
Life will go on.
All that needs be said.
'97 Tercel
Post by '97 Tercel »
Just another accident from just another shady west coast operator.
oldncold
Post by oldncold »
? with this recent incident n the otter flip over on a lake near ft smith how many dhc3 are left . there was one lost in manitoba in 2019. Alaska lost a couple in 2019. if my memory is accurate there were 416 built
New Antique Pilot
Post by New Antique Pilot »
oldncold wrote: Sun Jul 25, 2021 12:24 am ? with this recent incident n the otter flip over on a lake near ft smith how many dhc3 are left . there was one lost in manitoba in 2019. Alaska lost a couple in 2019. if my memory is accurate there were 416 built
466 were built. Standby for the number still active.
NAP
New Antique Pilot
Go to DHC-3archive.com. There is a chart showing the status of each Otter built. There are approximately 170 still active. The chart also shows aircraft in museums or under rebuild.
NAP
boeingboy
Post by boeingboy »
This is not a writeoff. It's been towed back to Vancouver and is already being repaired. Heck - The one that was eaten by a Beaver last summer was much more damaged than this and that one is back flying.
fish4life
Post by fish4life »
If a data plate survives I wouldn’t be surprised to see a complete rebuild from that as time goes on.
goldeneagle
Post by goldeneagle »
fish4life wrote: Sun Jul 25, 2021 11:49 am If a data plate survives I wouldn’t be surprised to see a complete rebuild from that as time goes on.
The data plate from a beaver or otter is virtually indestructible. Many of them have been thru much worse than this over time, and are today flying around with a whole bunch of new parts attached.
C-GIGO, a float equipped Cessna 208 aircraft operated by Seair Seaplanes Ltd., was preparing to
conduct a flight from Ganges Harbour (CAX6), BC to Vancouver Int'l (CYVR), BC with 1 crew
member on board. Prior to the engine starting, the dockhand assisting the pilot untied the guide
rope and held it in his hand. When the engine started the aircraft travelled forward pulling the rope
from the dockhand. The aircraft began travelling forward until the propeller of C-GIGO struck the
rear of C-GUTW, a float equipped DHC-3T operated by Harbour Air. After the initial prop strike, the
pilot of C-GIGO quickly shut down the engine as the aircraft rotated 90 degrees striking C-GUTW
with the RH wing. C-GUTW was tied to the dock with no one on board during the occurrence.
There were no injuries; both aircraft sustained substantial damage.
boeingboy wrote: Sun Jul 25, 2021 10:34 am This is not a writeoff. It's been towed back to Vancouver and is already being repaired.
Video of towing a floatplane. Not sure which one this is.....
https://www.msn.com/en-ca/news/canada/v ... d=msedgntp
