Job Posting!
Re: Job Posting!
altiplano wrote: ↑Fri Mar 18, 2022 12:29 pm Yeah. Flat pay sucks...
There sure are a lot of things that suck in this world, in this career, in this particular job... could be better, yada yada... but then there you are and you're making 250 large a year plus a pension and paid benefits and realising you aren't that far from the widebody... and there you are...
Once in a lifetime...
And you may find yourself living in a shotgun shack Brampton apartment
And you may find yourself in another part of the world CYUL base
And you may find yourself behind the wheel of a large airliner Q400
And you may find yourself in a beautiful house, with a beautiful wife that girl from YPL
And you may ask yourself, "Well... how did I get here?" through the online application
And you may ask yourself, "How do I work this?" FMS
And you may ask yourself, "Where is that large airliner?" its still a Dash 8
And you may tell yourself, "This is not my beautiful house"
And you may tell yourself, "This is not my beautiful wife"
And you may ask yourself, "What is that beautiful house?"
And you may ask yourself, "Where does that highway go to?"
And you may ask yourself, "Am I right? Am I wrong?"
And you may say to yourself, "My God! What have I done?"
Letting the days go by...
Same as it ever was...
Hangry
Re: Job Posting!
Post by Hangry »
Re: Job Posting!
LOL... I thought about doing that, but I didn't have time to be creative...
There's more to the point of it though...
how did I get here - wherever that is? is this my life? where does it all go? whatever you do, suddenly there you still are...
Once in a lifetime... letting the days go by... same as it ever was...
Enjoy it, whatever happens...
Old fella
Re: Job Posting!
Post by Old fella »
https://youtu.be/MFV1biHrOBU
Col. Panic
Re: Job Posting!
Post by Col. Panic »
Arnie Pye wrote: ↑Fri Mar 18, 2022 10:41 am We have to stop putting Air Canada on a pedestal.
I see no reason to apply based on potential earnings 10-20 years from now.
If NB captain positions continue going to 4th year pilots, that’s a $200k/yr potential earning, within 5 years.
schnitzel2k3
Re: Job Posting!
Post by schnitzel2k3 »
Col. Panic wrote: ↑Fri Mar 18, 2022 4:40 pm
How many bids are there vs how many pilots have to continue right seat? 1 bid for every 100 pilots? 1 bid for every 1000?
How risky is it to bid that spot with that level of inexperience?What is the QOL as a NB Capt with 4-5 years of seniority?
TheStig
Re: Job Posting!
Post by TheStig »
I’m not sure you have the right concept of how bids work? There is one equipment bid for all the pilots. It’s starts with the company providing a break down of the number of total positions in each position on each base.
Individuals have a standing bid that they can adjust with their bid, positions can be bid to the bottom of the respective list or qualified by percentage from the top or number of positions. What AC provides is options, every pilot decides what the best balance between pay and lifestyle their seniority will provide them.
There are 777 Captains with 25 years of service working every weekend and holiday, but they’ve made the choice to bid that position to the bottom. Likewise there are NB FO’s with amazing schedules with very few YOS.
The bottom 15-20% of each list is usually reserve. The bottom half of each list works parts or the entirety of every weekend, or they bid reserve to get weekends off. Those in the top half can work when they want or go where they want, the top 10% get everything they want.
It’s easy to get hung up on upgrade times because it’s an obvious answer to “should I apply to AC”, but the other thing to remember is the quality of life options available through rapid (re-)growth.
schnitzel2k3
Re: Job Posting!
TheStig wrote: ↑Fri Mar 18, 2022 6:19 pm I’m not sure you have the right concept of how bids work? There is one equipment bid for all the pilots. It’s starts with the company providing a break down of the number of total positions in each position on each base.
Individuals have a standing bid that they can adjust with they’re bid, positions can be bid to the bottom of the respective list or qualified by percentage from the top or number of positions. What AC provides is options, every pilot decides what the best balance between pay and lifestyle their seniority will provide them.
Has the upgrade process become easier than the gauntlet it used to be in the past, and are these upgrades on every positional bid?
At the end of the day - if its rare to get through the upgrade process, or if there penalties for failing - then it could prove super risky for most YR 5 guys banking on an upgrade to make up for flat pay losses.
Sharklasers
Re: Job Posting!
Post by Sharklasers »
schnitzel2k3 wrote: ↑Fri Mar 18, 2022 7:50 pm
Anecdotally the pass rate for upgrades is +90%. A little lower on the Airbus fleet, especially it seems since the change of command over there for one reason or another. Command training failures are reflected on the line status report and there were only a couple on this last one. The punishment for failure is death by hanging..... no wait that’s horse theft. If you fail the upgrade it’s 2 years before you can try again. You used to only be able to attempt twice in a career before your sentenced to a lifetime in the right seat but that recently changed as well.
Col. Panic
Re: Job Posting!
If it’s that big a concern, you can still bid widebody FO and make $160k+ in year 5.
These pay values are still way under where they should be, but I am just trying to dispel the idea that you have to wait 15+ years to make a reasonable wage. A 50% raise across the board would go a long way towards regaining the losses of the past 19 years, or at least return to 2003 pay (corrected for inflation!)
As mentioned elsewhere, the best thing that could happen for AC pilots would be for WS pilots to sign an industry leading contract! I would love to see ACPA go into negotiations in 2024 and be able to say “look how far behind we are now”!
FL030
Re: Job Posting!
Post by FL030 »
Forget WestJet. The best thing that could happen is if the US majors started broadly sponsoring Canadian pilot's visas.
Re: Job Posting!
Best thing is ALPA/ACPA WJ/AC both said enough is enough and membership had the stones to stand out together and started pattern bargaining at rates similar to US legacies.
schnitzel2k3
Re: Job Posting!
FL030 wrote: ↑Fri Mar 18, 2022 9:15 pm Forget WestJet. The best thing that could happen is if the US majors started broadly sponsoring Canadian pilot's visas.
https://drgnews.com/2022/03/11/skywest- ... -shortage/
C208
Re: Job Posting!
Post by C208 »
Any idea what it means when you get this,
“This message is to inform you that we have received your latest resume for the position of Pilot (for non AC-Express Pilots only). We thank you for your interest and would like to inform you that we have modified your online candidate file accordingly.“
I went to my profile, I couldn’t see anything jumping out that was modified? Cheers.
Kingair200
Re: Job Posting!
Post by Kingair200 »
C208 wrote: ↑Sat Mar 19, 2022 4:53 am Any idea what it means when you get this,
it's probably a generic reply cuz i got the same as well. best of luck and all the best to everyone who applied
columbia
Re: Job Posting!
Post by columbia »
Kingair200 wrote: ↑Sat Mar 19, 2022 7:05 am
Where are you guys flying now ?
DanWEC
Re: Job Posting!
Post by DanWEC »
I also haven't received a confirmation email, but when I verified through the "continue application" link that was emailed it said the current application had been processed.
TheStig
Re: Job Posting!
Post by TheStig »
ted_stryker wrote: ↑Fri Mar 18, 2022 12:14 pm Is YUL a fairly junior base to get? Or in the past have most new hires been sent to YYZ?
There are lots of positions open in YUL.
plbconrad
Re: Job Posting!
Post by plbconrad »
Hi,
I made a mistake with the first application and sent another one in correcting it. There was no way to go back and fix it. Will this go against me? Wondering if I should follow up with an email to HR?
Latitude
Re: Job Posting!
Post by Latitude »
I received the same as well.
C208
Re: Job Posting!
Post by C208 »
columbia wrote: ↑Sat Mar 19, 2022 7:59 am
Thank you for the response, KingAir. Columbia, I WAS flying for Syncrude. :?
tbayav8er
Re: Job Posting!
Post by tbayav8er »
So I updated my application from about 3.5 years ago. Does the HR department get some kind of notification that I have updated my application? Or should I submit a new application?
Arnie Pye
Re: Job Posting!
Post by Arnie Pye »
Every time people start telling me that Year 1-4 pay is crap but you have a potential earning within 5 years blah, blah, blah, I'm picturing a pyramid scheme being pitched by some "financial advisor" in a poor fitting cheap suit.
Return to “Air Canada”
