Sunwing/Westjet
Discuss topics related to Sunwing.
elite
Re: Sunwing/Westjet
Post by elite »
Vanguard wrote: ↑Fri Mar 18, 2022 9:09 am Relax mate. I never said I was the Vanguard of the WJ pilots. Obviously I can't reveal who I am for obvious reason.
Honestly, if you're gonna show attitude...lets be quite clear. SWG got bought by WJ. Not the other way around. Obviously if there is to be a merger we would want to see it done properly and fairly. You guys and gals just recently signed a 10% discount on WAWCON so to come in with that attitude isn't the nicest thing. You're getting a major pay raise & job security. 20% ESP to your 7% after 7 years. You're bringing us some business but we are a network. You may also get to fly some nice new aircraft in your career ahead. Lets all play nice.
As far as Encore goes. We do understand with SWG merger it could get complex. The PTA may have to go however keep in mind while the PTA is active and lets say SWG merges. You would also have access to a position on the Dash8 if there was ever another downturn. It's easy to look at things from one angle, know that you would have to do more research. The sentiment of our group doesn't get represented by ALPAPolicy aka J. Swallow. Thats all I want people here to understand. This will eventually fizzle out as lots of noise.
Way too much assumption on your part! And whether you are an Encore pilot who directly benefits from this or a union guy that concocted this whole thing, it matters not. Just as it matters not who is the buyer and who is seller in a merger once common employer is declared. It will be decided by the forces of the industry and no one can stop it. And no one at Sunwing cares about Dash8 seats as you say, especially the poor contract that comes with it, because of the PTA! Ironic!
Because it benefits most folks in WestJet, there should be a bias towards merging the lists based on DOH and also because it results in most natural “fences” and most protection for everyone to maintain status, pay and in most cases base.
To merge based on DOH, WestJet MEC will have to present a list that is based on DOH which means a pilot who is on 2nd year pay could only have 2 years seniority, not a few more from a previous company. So unless WestJet agrees to common employer status with Encore, which has virtually zero chance based on reasons mentioned before, its pilots will have to be removed from the list and the remaining rearranged based on DOH at WestJet/Swoop. That is the only way WestJet can advocate for DOH which would be to the benefit of its pilot group. To not advocate for it, means WestJet MEC is more concerned about protecting Encore than its own due-paying pilots!
With that, and a freeze for everyone where they are until their seniority catches up with them, merge the lists based on DOH, combine Sunwing with Swoop, that way very few, if any, fences are required as there will be natural freeze at Swoop and the senior folks get to keep their coveted 787 spots based on higher seniority and no one can complain about being worse off.
If WestJet MEC does not do that, they still cannot force Sunwing pilots to merge with pilots of another airline that is a separate employer and separate bargaining unit, but also will not be able to advocate for a DOH, ALPA preferred method of mergers. Then they end up in a messy ratio based merger with all different kinds of DOH on the seniority which are not in order, necessitating more arbitrary fences, Sunwing pilots contesting ALPA’s representation, and almost certainly going to arbitration. And let’s face it, WestJet pilots don’t do well in arbitration because they overestimate their position.
rudder
Re: Sunwing/Westjet
Post by rudder »
elite wrote: ↑Sat Mar 19, 2022 5:53 am "………but also will not be able to advocate for a DOH, ALPA preferred method of mergers. Then they end up in a messy ratio based merger with all different kinds of DOH on the seniority which are not in order, necessitating more arbitrary fences, Sunwing pilots contesting ALPA’s representation, and almost certainly going to arbitration.
DOH is not the ALPA ‘preferred’ method of mergers (I presume you mean pilot seniority list integration).
Simply review the latest ALPA Merger Policy. DOH is not even referenced as a ‘factor’ to be considered in negotiating/arbitrating seniority list integration (although ‘longevity’ in included as a factor with no particular weight or priority assigned).
Any party is free to argue for a DOH solution. But there is no bias whatsoever in the ALPA Merger Policy towards DOH.
From a historical perspective, the only DOH based ISL’s flowed from consensual agreements. There are no arbitrated awards within the past two decades+ that were DOH.
elite
Re: Sunwing/Westjet
Post by elite »
The reason there have not been many DOH mergers recently has been mainly because of huge disparities, for instance Canadian with its own many previous (messy) mergers and the fact that it was being rescued by a company that had been thriving and hiring in its last years as opposed to being stagnant and barely surviving multiple CCAAs. Otherwise, DOH makes most sense; after all, how can anyone expect to have seniority more than the years actually worked?!
ALPApolicy
Re: Sunwing/Westjet
Post by ALPApolicy »
Because only one bargaining unit is represented by ALPA, Section 45 of the ALPA Administration Manual (Merger) is of limited application. It still offers guidance to the WSW/WJA Merger Committee but most provisions are not mandatory. (I am resisting making a crack about ALPA following its own rules.)
GoHomeLeg
Re: Sunwing/Westjet
Post by GoHomeLeg »
Keep it all separate. No seniority list merger. Do away with Swoop and absorb the pilots into Westjet and Encore.
Sunwing will do all the sun destination flying. There is no point in two carriers under the same company flying routes down south to the same places.
Onex bought Sunwing Vacation and Sunwing Airlines, not Westjet. You can fight me on that. : : :smt008 :lol:
cloak
Re: Sunwing/Westjet
Post by cloak »
Competitive forces currently present in the market would suggest that Swoop is going to get a lot bigger and it will fly not only to most sun destinations, but also almost everywhere that Flair, Lynx, Jetlines fly. They would also suggest that Swoop will be the main partner in the merger with Sunwing, and yes it’s WestJet that bought Sunwing and not Onex, which was made very clear. And there would be no logical reasons to do otherwise as WestJet is their first and foremost investment in the sector and the vessel through which Onex will realize its aspirations and visions in the airline industry.
boeingboy
Re: Sunwing/Westjet
Post by boeingboy »
Yea - on paper. Westjet doesn't have 2 nickels to rub together just like every other airline in this country. The money and approval for shares transfer came from Onex, If you think GS had no part in this - I have an iceberg to sell you...
However this deal actually plays out - this is certainly true - if for no other reason than Westjet mainline aircraft are not configured the same as Sunwings - where Swoops are.
imjustlurking
Re: Sunwing/Westjet
Post by imjustlurking »
boeingboy wrote: ↑Mon Mar 21, 2022 3:24 am
If we're being honest, Sunwing Airlines was likely pushed on WestJet as part of the deal to buy Sunwing Vacations. WG is not worth much on its own.
fruz
Re: Sunwing/Westjet
Post by fruz »
No surprise here...
The Bureau's empirical economic expert found that the Proposed Transaction is likely to result in significant competitive effects, including price increases for Canadians on a variety of routes where the merged entity would have market power.
As a result, the Commissioner has concluded that the Proposed Transaction is likely to result in a substantial lessening or prevention of competition in the provision of vacation packages on 31 routes between Canada and Mexico or the Caribbean, and represents a merger of the only two integrated tour operators and airlines offering non–stop service on 16 of these routes.
https://www.competitionbureau.gc.ca/eic ... 04690.html
Re: Sunwing/Westjet
fruz wrote: ↑Wed Oct 26, 2022 9:20 am No surprise here...
Having been on 2 Sunwing vacations in the past 2 years, I can say that the price of WestJet vacations wasn't even comparable. Easily 20% more money (often almost double the price) for seemingly very similar destinations/ packages. Transat vacations comes really close or even beats Sunwing, but only out of YYZ/ YUL, they have very little to offer out west. I also found that if I shopped by resort price only with airfare separately, AC Rouge was nearly impossible to beat for airfare only. Once WG and WS become one entity prices are going up guaranteed.
rudder
Re: Sunwing/Westjet
Post by rudder »
co-joe wrote: ↑Mon Dec 26, 2022 2:36 pm
Check out the most recent Sunwing headlines.
And you think price is the only issue at Sunwing?
frog
Re: Sunwing/Westjet
Post by frog »
pilot4life
Re: Sunwing/Westjet
Post by pilot4life »
let the fun begin!
CaptDukeNukem
Re: Sunwing/Westjet
Post by CaptDukeNukem »
I will be watching this closely :)
Re: Sunwing/Westjet
Great, now they can go on strike together!
Re: Sunwing/Westjet
digits_ wrote: ↑Fri Mar 10, 2023 3:04 pm Great, now they can go on strike together!
I would think that WG pilots still being Unifor would make it very difficult for them to go on strike at all, since they haven't filed for conciliation and their contract isn't up for negotiation. Merging them into ALPA is going to be a significant hurdle to be accomplished at a later date. As a result my guess would be that WG will still fly even if WS and Swoop pilots take job action.
cdnavater
Re: Sunwing/Westjet
Post by cdnavater »
co-joe wrote: ↑Sat Mar 11, 2023 12:50 am
Which is very bad for WS pilots, I’m sure management celebrated with the announcement and I’m sure they’re working on a plan to cover some or most of the flying with WG, it is their slow time of the year. Deployments cancelled will be the next announcement to the WG pilots.
Worst case, allow Westjet to die and rebuild with Sunwing or new name Westwing! Can’t catch a break in this industry!
Canadaflyer46
Re: Sunwing/Westjet
Post by Canadaflyer46 »
I heard Sunwing is deploying tails to Europe this summer? If that's the case it'll be pretty hard to cover any flying if WS are on strike. Also, I know full well if I was a SWG pilot asked to cover WS flying during a strike I wouldn't be showing up. Sick/Personal days/Call it whatever you want. Not happening.
fruz
Re: Sunwing/Westjet
Post by fruz »
Sunwing is deploying aircraft and pilots to Europe this year. If WestJet expects Sunwing to cover WestJet flights this summer, good luck. It'll hardly make a dent with how many aircraft they'll have available.
elite
Re: Sunwing/Westjet
Post by elite »
Canadaflyer46 wrote: ↑Sat Mar 11, 2023 7:07 am I heard Sunwing is deploying tails to Europe this summer? If that's the case it'll be pretty hard to cover any flying if WS are on strike. Also, I know full well if I was a SWG pilot asked to cover WS flying during a strike I wouldn't be showing up. Sick/Personal days/Call it whatever you want. Not happening.
They may not have a choice as they are bound by their contract, same with Encore.
ant_321
Re: Sunwing/Westjet
Post by ant_321 »
cdnavater wrote: ↑Sat Mar 11, 2023 6:16 am
I would be shocked if the deployments are canceled. Part of the WestJet/SWG deal is that TUI is taking a stake in WestJet. Our European deployments are mostly for TUI, it would cripple TUI UK’s summer season. SWG will only operate 8-10 airplanes in Canada this summer. Even if we are forced to do the flying it won’t make a dent in WestJets flying.
cloak
Re: Sunwing/Westjet
Post by cloak »
Presumably aircraft on order by WestJet are for the entire "group" and can go to any of its divisions. And Sunwing has no restriction on the size of its fleet and with the recent of settlement of all its grievances and amendment to its pay, there is ample time left in its contract.
fruz
Re: Sunwing/Westjet
Post by fruz »
You're assuming Sunwing will also have pilots to operate these aircraft too. Attrition is real at Sunwing also. WestJet may be counting on using Sunwing to fulfill operational needs if the westjet pilots stike but the amount of aircraft and personnel available at Sunwing will hardly do anything to fulfill said need.
averageatbest
Re: Sunwing/Westjet
Post by averageatbest »
fruz wrote: ↑Sat Mar 11, 2023 9:02 am You're assuming Sunwing will also have pilots to operate these aircraft too. Attrition is real at Sunwing also. WestJet may be counting on using Sunwing to fulfill operational needs if the westjet pilots stike but the amount of aircraft and personnel available at Sunwing will hardly do anything to fulfill said need.
Sunwing can barely staff it's own needs. Except for a few cases, the majority of WestJet passengers will be screwed if the pilots go on strike.
The affected passengers will not side with the pilots, but that is no reason for WestJet pilots to suck it up and continue to work.
CaptDukeNukem
Re: Sunwing/Westjet
averageatbest wrote: ↑Sat Mar 11, 2023 12:58 pm
Don’t forget government will probably force you back to work within a week of strike action, citing “national interest” , just like handshakes were replaced by elbow bumping. What a farce.
Return to “Sunwing”
