Own vs Rent Break Even?
Archerboy
Post by Archerboy »
Hello all!
First post on the forums. Hope it's the right forum for the question. Got a FAA PPL but havent flown in near 2 decades and want to get back into aviation. Mainly life got in the way, but generally didnt get back in as flying for me is a do it 200% or dont do it at all thing. Not like driving a car you know. And so the cost of it kept me away.
Currently been doing homework on rent vs own. Rental of 172s is around $185/hr wet in my neck of the woods. I'd be wanting to fly around 100 hours a year so that'd be on the order of 18K/year + flight instruction (want to start from scratch and get Canadian certifications).
So far i'm looking at aircraft in the 40-50K range for purchase, and trying to run some ownership costs. 100LL is around $2.50 these days, so on the order of $60-70/hr for fuel. $1000 for annuals, $700 insurance, say another $1000 for misc maintenance and the biggest variable appears to be tie down vs hangar. Like $800/year vs $6000/year.
So for 100 hours/year, every $1000 in fixed cost is like $10/hr. So with like $9K yearly costs i'd be looking at $150-160/hr which is not far from the rental rates. But with something more reasonable like $4K/year we are closer to $100/hr for owner cost which is a decent saving vs rental rates.
But aircraft in the 40-50K range are generally VFR only, and for safety and IFR training I'd want to upgrade avionics a bit. Seems those can run 15-25K easy.
So in the end, worth all that headache to invest 60-70K and potentially end up only saving $40-50/hr compared to rentals?
Is it wise to go into ownership without much experience?
THanks
Archer
WANP
Re: Own vs Rent Break Even?
Post by WANP »
I would, and have, always chosen to own, over rent.
It is available on your schedule then, not someone else's, you know what maintenance is getting done, how its being flown, and more.
When you're done with it someday, you can sell it, and historically GA plane prices have been going up steadily for many decades.
Whitney
Archerboy wrote: Sun May 01, 2022 10:36 pm Hello all!
THanks
Archer
Where are you? I think most of your budget prices are low by at least 50%.
There's very very little to purchase in Canada at the $50k level, certainly not an even half-decent old-style 172. Annuals are going to be at least $2k, insurance $1500, add another $2k for other maintenance, and the cheapest tie-down within two hours drive of here is $2400 annually. Hangarage for a 172 could be as much as $20k a year, depending on location. Nor is fuel going to stop at $2.anything for very long. Don't forget to have a contingency for engine repairs - a new jug installed for a few $k, top overhaul at $15k, or pull the plug and do the whole overhaul at $30k, if your engine condition dictates. You may have to install a diversity ADS-B transponder system in a couple of years, depending on where you want to fly - figure on $5k+. You'll need it sooner than that if you want to fly into the US. So there's a lot of things to budget for.
My point here is not to scare you with costs - just to point out that you're responsible for a lot, when you own an airplane, and you can't divvy everything up into $x per hour. Owning an airplane isn't an alternative to renting merely to be chosen on budget terms; they're totally different experiences. Owning an airplane is a lifestyle choice, like buying a boat. Go where you want, when you want, and nobody will ever hand you the keys and tell you you had better be back by 11 or else, because the plane's booked out by a student then.
Where are your hundred hours per year going to be spent flying to and from? Heading out to the practice area for steep turns, stalls and slow flight gets pretty dull on your own after the first 4 hours; that leaves you another 96 to fill. Then there's next year. And the year after. What are your plans?
If you need an ifr equipped plane, then buy an ifr equipped plane. There is no realistic way a vfr airplane can be converted into an ifr one for 15k nowadays.
If you are looking at economics, I would just rent for training. If you want to own an airplane, then by all means buy one. But do it because you want to, not because you think it will be cheaper. It likely won't be.
digits_ wrote: Sat May 07, 2022 2:31 pm If you need an ifr equipped plane, then buy an ifr equipped plane. There is no realistic way a vfr airplane can be converted into an ifr one for 15k nowadays.
+1 to this. I missed that comment from the OP.
I agree with this. If you have any thought that you'd like to take the plane on some long trips, the freedom of owning is great. But, if you're not going to use it 100 hours a year, you're probably better renting.
I wouldn't buy thinking that you'll make a buck selling it later, but breaking even is hopeful. If you break even after flying 500 hours, then you really did get your money's worth. That said, more and more, aging aircraft inspections and AD's are being introduced, and some will be expensive. Have a really thorough pre purchase inspection done, with consideration to the most detailed inspection requirements appropriate to the airplane - in the case of a Cessna, the "SID's". If such inspection reveals a structural defect, best determine what the repair will be before you buy.
JasonE
Post by JasonE »
I broken even after close to 400 hours on a Cherokee.
Renting can work if you have a good non-profit flying club around.
photofly wrote: Sat May 07, 2022 1:48 pm
THanks
Archer
What he said /\
Ownership has many advantages but saving money isn't one of them. Personally I think partnerships for recreational fliers is the way to go. I was in a partnership for 12 years. All fixed costs are cut in half and I can only think of 3 times were we both wanted to use the airplane at the same time.
cargocowboy
Post by cargocowboy »
Very, very few PPL's fly 100hrs per year. Maybe rent for a year and see how many hours you'll actually fly. It might change your equation a bit.
CpnCrunch
Post by CpnCrunch »
Insurance is about 2k.
Figure at least 2k for misc maintenance. In the last year I spent $1500 to replace a flap cable, carb heat cable, and voltage regulator. The year before I spent $2k fixing a flap problem, changing the battery, replacing a failing magneto, fixing a door handle, etc. I also spent $5k to deal with what turned out to be dead brushes on an S-TEC pitch servo. With proper troubleshooting in the first place it would have been about $900. Also figure about $600 or more every 2 years for the ELT and pitot static checks.
Also, the $1k annual cost is only accurate if nothing needs done. My first annual was $1600 as I wanted the plane fogged with ACF50 and the prop balanced.
Bede
Post by Bede »
Basically what photofly said but depending on where you are hangarage & tie down can be cheaper. My dad pays $300/mo for a spot in a hangar split with 2 other airplanes in YKF.
I started a thread on here a year or two ago with my actual costs of ownership and comparing to rental. If I recall, I broke even at 50 hours, but that was with 3 other partners splitting the maintenance, tie down & insurance cost.
Archerboy
Post by Archerboy »
Sorry for late reply. Thread was in moderation for some days so did not notice the replies until today.
WANP wrote: Sat May 07, 2022 12:51 pm I would, and have, always chosen to own, over rent.
That was one of things I was curious about. If planes do not depreciate like cars, then the cost of acquisition could in theory be called an investment if the plane is maintained well enough to keep its value for potential future re-sale. Then again, how difficult is it to re-sell airplanes these days?
photofly wrote: Sat May 07, 2022 1:48 pm Where are you? I think most of your budget prices are low by at least 50%.
I'm in Calgary, I'd probably be flying out of YBW. I'm just familiarizing with the aircraft marketplace. When I got my FAA PPL in the states, gas was $3 a GALLON, the Warrior i flew was $76/hr wet and my instructor was $35/hr. Calgary rentals are $182/wet and instructors $65-70/hr.
The Archer i flew I think was sold for like 40K USD (this was like 15 years ago). On YouTube, I keep seeing "top affordable aircraft" and many are in the 25-50K range for 152s, Tomahawks, and even some 172s. But browsing Controller.com, seems there is almost no good 4-seater for under 80K CAD, most good ones are 90-110K. Twins about to go into overhaul can be had for 100-130K, but most good twins are upwards of 150K. The ownership costs I just grabbed from an online calculator...I think they were USD not CAD.
RE: the 100 hours/year
I have 130 hours flown in the US. The reason i never got back into it is because of costs to some degree but mainly those associated with keeping current and safe. I always felt you cant have one foot in the water in aviation, because being a bad GA pilot will get you killed. So would not pick it up if I'm flying once a month or once every two months. My intent with the 100 hours would be to make avaiation part of my life again, and primarily at first I'd be training as well as practicing a lot, with occasional leisure flights. Eventually, as my competency and confidence increased, I'd be going on cross-country IFR trips on top of more local flights. For example, although I have an FFA PPL, I'd start from scratch as a student pilot and get my CAA PPL and essentially get consistent training all the way to a Commercial / Multi-IFR and Instructor ratings.
The 100 hours would both allow me to fly often enough to remain proficient, allow me to progress through ratings. The idea of owning a plane would be that if I'm going to commit that much to flying, might as well invest in a plane and perhaps it'll also teach me a few things about maintenance.
RE: IFR vs VFR planes
Safety is quite important to me, especially on IFR flights over water or mountains or cities and with family/friends, so that's why I always wanted a twin piston, as the thought of losing the only engine on an aircraft in IMC over a city or mountains just seems like a death sentence. At least with a turbo-twin you can maintain altitude and reach an airport.
For IFR flying, i'd probably want max situational awareness through a good GPS and PFD, reduced workload from an autopilot and back-up steam gauges. If i bought a single piston, I'd probably never fly IFR unless for an emergency.
I do agree with the recommendation to start off with a flying club/rentals to understand exactly what it is I'd be doing in the first place, the type of flying, before committing to owning a plane.
Archerboy
Don't look at it this way. It might work out that way, it might not. Buy the plane with the intent of using it well, and getting your value by "using it up". Sure, it is likely that you can sell it when you want to move on/up, but don't enter ownership with this as an expectation. Twenty years ago, yes, now, not so much. A major factor is that the legacy planes are getting more and more consideration for the effects of aging, and there are more inspections and what could be expensive fixes. Requiring an "unaffordable" repair is rare, but you may need to do a repair which eats up what you "hoped" would be a profit. A really great pre purchase inspection can really reduce such risk, but that puts up the purchase price for you, and more assures that you're actually paying what the plane is worth rather than getting a deal.
In the case were an airworthiness directive, or other inspection requirement is imposed upon the plane, at best it's just an additional inspection - wise and not terribly costly. But it could require a repair or parts replacement which may be costly, or at worst case, difficult parts availability. Knowledgeable buyers (which everyone should be) will know to offer what the plane is really worth, and not over pay. Perhaps that means buying a plane with a known defect, when you know what's involved in repairing it. My first airplane was this, and an awesome deal - but that was 35 years ago, and repair parts are not quite so available and low cost as those days.
I still encourage ownership for the reasons given here, but I also encourage buyers to buy the plane to use it, and get their value out of it in the use, rather than seeing it as an investment. If you sell it for a profit - bonus!
Archerboy wrote: Thu May 12, 2022 10:21 pm and essentially get consistent training all the way to a Commercial / Multi-IFR and Instructor ratings.
More flight training makes you a better student, not a better pilot. More flying makes you a better pilot.
My comment here is that having a CPL doesn't mean anything, and having a group 1 instrument rating doesn't make you a competent pilot to fly mult-engine IFR trips. And having an instructor rating doesn't make a competent instructor. All those things are entry tickets, not proofs of competence. all those things need a lot of work after receiving the licence. Unless you actually intend to devote a significant amount of time working at a flight training unit as an instructor, don't bother with an instructor rating.
But you still haven't worked out what you're going to *do* with 100 hours per year. Like I said, going to the practice area for stalls, steep turns and slow flight, solo, gets pretty dull, pretty quickly.
I believe competent pilots are created out of people who have a need to travel, and use a plane to do so. A lot. Not out of people whose travel is created by a desire to become a competent pilot. I could be wrong though.
Safety is important to everyone.
You're fussing about the wrong things.
The most dangerous component of any aircraft flown by an amateur pilot is the thing holding the yoke. You're about 10 times more likely to die mishandling a small piston twin in unsuitable weather (and, frankly, most Canadian weather is unsuitable for a small piston twin) than in a single engine airplane. The benefit of a single engine VFR equipped airplane is that it stays on the ground when the weather is bad, and the pilot and the passengers don't get themselves into trouble they can't handle. If safety is important to you as you claim, don't buy a twin and don’t fly in weather: go by airline, like everyone else.
What I understand from this statement is that your personal sense of danger is mitigated by having more engines and fancier equipment. This is a beginner attitude.
Also: if budget is even a remotely a consideration, forget all about operating a small piston twin. Operating costs are through the roof: there’s a reason why they’re cheap to buy.
That seems sensible.
photofly wrote: Fri May 13, 2022 4:08 am You're about 10 times more likely to die mishandling a small piston twin in unsuitable weather (and, frankly, most Canadian weather is unsuitable for a small piston twin) than in a single engine airplane.
Where did you get that number?
photofly wrote: Fri May 13, 2022 4:08 am What I understand from this statement is that your personal sense of danger is mitigated by having more engines and fancier equipment. This is a beginner attitude.
Hmmm.... I find that attitude also surprisingly common between pilots who fly twins often, commercially or privately.
Once you get used to a twin, you might be quite uneasy flying a single.
photofly wrote: Fri May 13, 2022 4:08 am Also: if budget is even a remotely a consideration, forget all about operating a small piston twin. Operating costs are through the roof: there’s a reason why they’re cheap to buy.
Depends. If you calculate it per hour: ow yeah. If you calculate the costs per mile travelled: not that much.
Twin commanches are surprisingly economic, especially if you compare it to singles with 6 cylinder engines.
If you're looking at old small airplanes, count the number of cylinders you will need to maintain. That will give you a fairly accurate comparison across airplanes. Using that approximation a twin commanche will cost you 33% more in maintenance than a 182 for example, and will likely give you 25% more speed. So more expensive, yes. Through the roof? That will depend on your roof ;-)
Squaretail
Post by Squaretail »
digits_ wrote: Fri May 13, 2022 6:50 am
I seem to recall that stat from somewhere. While Twins are no more accident prone than singles, the fatality rate for light twins is way higher than that of singles and the probability of type of accident shifts away from the take off and landing type mishaps common to light singles, to approach and departure phase accidents. Not sure if 10 times is 100% accurate, but the point is true that its a lot more.
Edit: some quick googling finds this NTSB document which puts the engine failure fatality rate of light twins as 4 times higher than the same for singles.
http://libraryonline.erau.edu/online-fu ... S79-02.pdf
I think if you want an unbiased look at accident rates between different types of aircraft, you should turn to the insurance rates for them. How much more do you think it would cost to insure a low-time pilot on a turbocharged twin, vs a C172? Do you think a low time pilot could get insurance on a turbocharged twin, these days?
Two turbochargers, plus the hyrdaulic systems, the retractable gear, that old Janitrol heater, two constant speed props, more fuel tanks, de-icing systems, autopilot...
photofly wrote: Fri May 13, 2022 8:05 am I think if you want an unbiased look at accident rates between different types of aircraft, you should turn to the insurance rates for them. How much more do you think it would cost to insure a low-time pilot on a turbocharged twin, vs a C172? Do you think a low time pilot could get insurance on a turbocharged twin, these days?
Well yes, you can definitely go expensive and crazy, but you don't necessarily have to, to fly a twin if you so choose.
Lots of twin comanches or travel airs without turbochargers or de-icing systems.
Autopilot maintenance is usually the same for a twin vs a single.
If you go for a turbocharged deiced single, you'll also pay a lot of money for maintenance and insurance. That's not necessarily related to your choice of buying a twin. But it can be, yes.
Are we comparing a Bonanza to a twin comanche or a 152 to a Beech Baron? There will be different conclusions.
Out west the minimum airplane to be able to regularly fly IFR is a turbocharged, FIKI equipped machine. There are very few piston singles that fit that bill so realistically you are looking at a twin. One fellow I know who owns one budgets 40 K a year to own the airplane and that is before he puts any gas in it. With today’s Avgas prices you are looking at over $ 300 an hour.
Then you have to address how you are going to get the 4 season weather and operational smarts to safely operate this class of airplane
I had a similar conversation with a fellow awhile ago who was financially able to by a new Baron (1.3 M USD). I told him to by a new C 182 instead. Fly the pants off it going places VFR and when he has 500 hours he will know what he is both capable of and what he wants.
digits_ wrote: Fri May 13, 2022 10:01 am
Well let's see what the OP wrote. In the first place he's looking at a $40k 172, then suddenly...
... I always wanted a twin piston, .... At least with a turbo-twin you can maintain altitude and reach an airport...
So I don't know what we're comparing. But for anyone who's so budget conscious they're looking at buying an old 172 to save six dollars an hour on rental prices, it seem a bit odd to suddenly be talking about turbo twins with autopilots and glass panels. Because you don't buy those when "$700 insurance" is worth even a mention as a line item in your flying costs.
photofly wrote: Fri May 13, 2022 3:37 pm
Fair enough :)
Archerboy
Post by Archerboy »
PilotDAR wrote: Fri May 13, 2022 3:56 am
I mean, if over the course of ownership one looses 100K of initial purchase cost, big picture, would not make financial sense to own vs rent no matter how good the lifestyle and freedom might be. I was trying to look at the big picture financially. I understand that ownership adds financial risk compared to renting and if i really wanted to invest in something it'd be Stock Market, Gold or a house.
photofly wrote: Fri May 13, 2022 4:08 am More flight training makes you a better student, not a better pilot. More flying makes you a better pilot.
That's fair. But there is no denying more advanced flight training can only be beneficial, as long as it's for a purpose. Multi training if you are not going to fly multi is pretty useless. But a CFI rating, even if you do not end up teaching, will make you a better pilot as you are supposed to achieve a level of knowledge and skill to be able to teach others, so it'll improve even knowledge of fundamentals.
My thoughts on the hours is like any skill, but even more so in aviation due to the complexity of the skill, the only way to become a safe pilot is to fly a lot. That's why clubs and FBOs that rent planes require 30, 60 or 90 day currency on an aircraft before they allow you to fly it solo. If you dont have that currency, back to the drawing board you go with an instructor checking on you.
Yes agreed. I would rather board a plane with a 1000 hour pilot flying only on steam gauges rather than a 100 hour pilot who barely knows how to use his G1000 and has 30 hours of instrument time. But between two equally skilled pilots, having the extra equipment will make things safer as long as they dont become complacent and depend too much on the glass cockpit and forget the basics of aviation. It's very easy these days to forget how to read a Low Enroute IFR chart and maintain situational awareness without a GPS if you are so used to seeing your little plane on a map telling you exactly where you are and where you need to go.
The more engines is a simple fact. If properly trained to handle a twin (which goes back to training), one working engine is better than no working engines when below you there is no place to land, or worse, when you are in IMC and cant see anything past your windshield.
I understand there is a premium to be paid for that extra engine, just trying to figure out how much of a premium for the sake of "safety".
But how many of those twin accidents are due to pilot error? And how many are due to IMC conditions or crash landings? It's well understood that twins are more complex and require more training and they will kill you faster than a single in the hands of of a bad pilot. But that could be said of any plane in the hands of a bad pilot.
I was comparing single engine rentals vs single engine ownership, and then separately, twin engine ownership vs twin engine rentals. I do understand SE and ME are not comparing apples to apples in costs.
1974 Warrior - $79500 USD
https://www.trade-a-plane.com/search?ca ... e=aircraft#
1981 Seneca III - $85,000 USD
https://www.controller.com/listing/for- ... n-aircraft
The warior is low time and brand new engine. The Seneca has one engine that has 200 hours remaining before overhaul.
This is not typical, as most older twins I see on controller are in the 100-150K range
Archerboy wrote: Fri May 13, 2022 4:57 pm I understand there is a premium to be paid for that extra engine, just trying to figure out how much of a premium for the sake of "safety".
If you compare a basic twin to a basic 172 or warrior, you'll be likely doubling the hourly cost, and pay about 30% more per mile flown. Purchase costs will likely only be slightly higher for a twin, but that twin will likely be better equipped.
You do expose yourself to more financial risk though. Double the chance of something major (engine) needing a repair. Then again, if the purchase price is similar, you'll never lose more than what you put into it. A twin with 2 engines needing overhaul is pretty worthless. You can sell off your avionics and engine cores, but that's about it. Then again, a single with an old engine and broken wing spar is equally worthless. If you're dabbling in old airplanes, it could go either way for any airplane.
Assume that whatever money you spend on your airplane, single or twin, is gone. If you can't do that, you better not buy an airplane. And don't go into debt to buy an old plane for personal use either. It doesn't make sense.
The warrior is low time and brand new engine. The Seneca has one engine that has 200 hours remaining before overhaul.
Air Power is quoting 77,000 USD for the TSIO 360EB engine in a Seneca III. With the cost of the re and re replacing ONE engine will equal the cost of the whole airplane....
Archerboy wrote: Fri May 13, 2022 4:57 pm But how many of those twin accidents are due to pilot error?
All of them. Every single one. That's the point. It's not the number of engines that's the danger, it's you. You are the danger. Adding another engine, an autopilot, two fat engines and de-icing increases the probability that you, the most dangerous part of the whole operation, will kill someone, most likely yourself but possibly your entire family too. Start there.
