Is FSS training easier than ATC training?
braincandy
I keep hearing how intense the training is, but is that just for air traffic control or is the FSS training equally as intense?
Re: Is FSS training easier than ATC training?
The success rate is typically much higher, and training is faster so overall I would say it is easier. Training itself is still pretty tough and high pressure with simulator evaluations that are do or die but if you make it through basic you are almost guaranteed to check out in the field somewhere. 4/5 of my course made it but obviously that's a small sample size.
mckinley007
What you have to consider is the level of responsibility each holds. ATC being significantly higher the training will have greater requirements and milestones to hit. My VFR tower basic course started with 4 students, 3 graduated to sites, of those three only ONE qualified as a tower controller. One other switched to FSS with success, the third departed the company.braincandy wrote: ↑Fri Jul 01, 2022 8:17 am I keep hearing how intense the training is, but is that just for air traffic control or is the FSS training equally as intense?
