New hire bids
RoAF-Mig21
Re: New hire bids
Post by RoAF-Mig21 »
Boeingman wrote: Sun Sep 18, 2022 3:44 pm looks like theyre tearing down the YYZ DH8 sim at CAE
Excellent news! Out with the old, in with the new. I wonder what they'll put in its place? Jazz wasn't the only one using that sim, so is it going somewhere else? A few other operators were using it for training.
maverick12
Re: New hire bids
Post by maverick12 »
Any news on the latest bids in the Sept 19 class?
Babar350
Re: New hire bids
Post by Babar350 »
Oct 31st DEC only. Already filled
Next should be sometime in November.
tango308
Re: New hire bids
Post by tango308 »
maverick12 wrote: Fri Sep 23, 2022 7:38 am Any news on the latest bids in the Sept 19 class?
8 Spots
3 RJ FO YYZ
5 Q4 DEC or FO YYZ
maverick12
Re: New hire bids
tango308 wrote: Fri Sep 23, 2022 9:42 am
8 Spots
3 RJ FO YYZ
5 Q4 DEC or FO YYZ
Wow thanks, didn’t expect the class to be this small
rudder
Re: New hire bids
Post by rudder »
Babar350 wrote: Fri Sep 23, 2022 8:28 am Oct 31st DEC only. Already filled
That should be interesting.
flyingcanuck
Re: New hire bids
Post by flyingcanuck »
rudder wrote: Fri Sep 23, 2022 10:25 am
True, how many will actually follow through
kiaszceski
Re: New hire bids
Post by kiaszceski »
flyingcanuck wrote: Fri Sep 23, 2022 10:51 am
Most importantly what will happen if they fail? Terminated ? back to be FO?
Interesting.
FL030
Re: New hire bids
Post by FL030 »
Yep, time for some soul searching for those guys.
Goodman5
Re: New hire bids
Post by Goodman5 »
Any clue about their experience level? 1500-2000 hour Instructor to 705 skipper would be scary quite frankly. Same with newish 703-704 Captains. Training standard won’t change for them so we’ll see how it pans out I guess
tango308
Re: New hire bids
Post by tango308 »
Goodman5 wrote: Fri Sep 23, 2022 12:47 pm Any clue about their experience level? 1500-2000 hour Instructor to 705 skipper would be scary quite frankly. Same with newish 703-704 Captains. Training standard won’t change for them so we’ll see how it pans out I guess
It is indeed scary if some instructor tries to go for left seat right away, will most likely end up as a fail. Remember if you fail a ride and interview at other operator this can come back and haunt you. Not to ding the instructor type, I was one myself, but 705 flying is a whole different game. Give yourself sometime, learn it from the right seat, do one of each seasons as an FO and then bid right seat, WIN.
ellinas
Re: New hire bids
Post by ellinas »
maverick12 wrote: Fri Sep 23, 2022 9:54 am
8 Spots
3 RJ FO YYZ
5 Q4 DEC or FO YYZ
Is this because that’s all they need or didn’t get enough? Interesting
if you are on the ground I guess there is now way but to look up!
tango308
Re: New hire bids
Post by tango308 »
ellinas wrote: Fri Sep 23, 2022 2:28 pm
8 Spots
3 RJ FO YYZ
5 Q4 DEC or FO YYZ
I can tell you with certitude it is NOT because that's all they need. Word from management is training capacity will be shifted from new hires to upgrades for a short while. Should you choose to believe this is up to you...
negative_g
Re: New hire bids
Post by negative_g »
tango308 wrote: Fri Sep 23, 2022 2:54 pm
Shifting to upgrades? But no one wants to upgrade. Isn't that why they're hiring DEC?
maverick12
Re: New hire bids
Interesting, I guess we shouldn’t hold our breathe for a 20 person GS in November. Don’t know why they’re still interviewing people then.
ellinas
Re: New hire bids
Post by ellinas »
Oh ok! So very little hiring for a while . They’ll be training present pilots to captains. So we should wait for a while before applying.
negative_g
Re: New hire bids
Why would you wait before applying?
Apply, get interviewed and get into the pool. Then one day the call comes and off you go. Waiting to apply doesn't make much sense.
kiaszceski
Re: New hire bids
negative_g wrote: Fri Sep 23, 2022 4:42 pm Why would you wait before applying?
It might actually, if you are close to switching "experience box" depending on what box you tick in the application.
If you are close to 1000 or 1500 hrs, or if you are close to 501+ hours of multi or than 1500 hrs.
maverick12
Re: New hire bids
kiaszceski wrote: Fri Sep 23, 2022 5:29 pm
But those boxes can be altered all the way till Sim eval atleast
rudder
Re: New hire bids
Post by rudder »
Oct 31 new-hire GS now limited to 10 candidates. Mostly DEC.
Oct 10 GS cancelled. Sept 19 was just 8 candidates.
Next GS after Oct 31 will be Nov 21 (supposedly).
Total actual pilots hired May-October will be less than 110 (that is an average of less than 18 per month. Meanwhile, AC is hiring 80 per month). Original Jazz plan May-Oct was 165 (205 for 2022).
If you add in non-forecast attrition (Porter/Flair/WJ/Transat/Sunwing/CargoJet/Morningstar/corporate/etc) no wonder Jazz wants to shut down AC flow.
Jazz is falling way behind in hiring/training considering that the previously achieved high water mark for annual PIT was 500+.
ellinas
Re: New hire bids
Post by ellinas »
rudder wrote: Mon Oct 03, 2022 8:00 am Oct 31 new-hire GS now limited to 10 candidates. Mostly DEC.
So there is a shortage of experienced pilots over 1000 hours not necessarily 500 hours pilots or just shortage of all pilots.
kiaszceski
Re: New hire bids
ellinas wrote: Mon Oct 03, 2022 9:50 am
1000h pilot doesn’t necessarily mean experienced pilots.
They need DEC, quick upgradable (3-6 months), in that order. When they won’t be able to fill in their DEC courses, they will call the quick upgradable candidates. Then the low timers.
Now does a 703 captain or a 1000hrs single pilot Navajo or a multi-IfR instructor or a 705 FO is the best fit to be a Q4 or CRJ captain, that is up to flight ops to decide.
They have all the numbers that show what might be the failure rate in each category.
ellinas
Re: New hire bids
Post by ellinas »
kiaszceski wrote: Mon Oct 03, 2022 10:04 am
So basically us 700 hour wannabes are just wasting our time trying to get something. We need over 1500 hours to even hit the nail on the head. Makes sense , experience counts
Re: New hire bids
Experience counts until they get desperate then suddenly “hard minimums” get softer than spray cheese. Even if you are not close apply anyway. I know a guy that got a corporate jet job with less than half the “non negotiable, don’t even apply if you don’t have the time” time.
Turns out they had a paid for sim spot starting in 3 days and their preferred candidate no-showed…..
jpilot77
Re: New hire bids
Post by jpilot77 »
Big Pistons Forever wrote: Mon Oct 03, 2022 1:09 pm Experience counts until they get desperate then suddenly “hard minimums” get softer than spray cheese. Even if you are not close apply anyway. I know a guy that got a corporate jet job with less than half the “non negotiable, don’t even apply if you don’t have the time” time.
Yes and no. A 1000 hour pilot ain’t going captain at a 705 no matter how low they get on pilots. Jazz’s problem right now isn’t lack of pilots, it’s a lack of experienced pilots. Jazz in 2019 was hiring super low time pilots left and right.
The problem with hiring a 1000 hour guy or 750, 500 hour guy is they’re at least a couple of years before they can go left seat. Jazz right now is hiring for DEC or guys that can upgrade in 6 months.
