IATRA benefits?
ellinas
IATRA benefits?
Post by ellinas »
Hello aviators and Happy New Year!
Does having written the IATRA increase the potential of gaining that entry level pilot position?
Your thoughts and Thank you
if you are on the ground I guess there is now way but to look up!
twa22
Re: IATRA benefits?
Post by twa22 »
Simple answer, yes.
Had I not had my IATRA, I wouldn't have gotten my first job. Any job that requires a type rating will require an IATRA if you don't have an ATPL
ellinas
Re: IATRA benefits?
Post by ellinas »
twa22 wrote: Wed Jan 04, 2023 8:04 am Simple answer, yes.
Thank you for reaching out much appreciated. I figured it can only improve your chances.
MrAviator19
Re: IATRA benefits?
Post by MrAviator19 »
Well, you cannot operate multi-crew aircraft without IATRA or SARON/SAMRA. So yes, you absolutely need it unless you plan to instruct or do survey flying on a 172.
MrA
porcsord
Re: IATRA benefits?
Post by porcsord »
It is required for a 2-crew type rating, it is not however required for an aircraft that is certified single pilot, ie: most beechcraft twins (BE20, 30, 02...). Can you get a job without an IATRA? Absolutely. However if you're doing what we all did as new pilots and spamming every company in the country with a resume, it would be good to have in your back pocket in case you get offered an FO position on something like a 228, -8, ATR etc etc etc.
It's worth the $100.00 simply for the fact that if I'm hiring for a position that requires it, I won't even look at your resume unless you already have it. I'm not going to gamble on you writing it on time to offer you a position.
Just my .02
PS
ellinas
Re: IATRA benefits?
Post by ellinas »
Do I need a recommend to write it?
final28
Re: IATRA benefits?
Post by final28 »
No, just book the appointment.
ellinas
Re: IATRA benefits?
Post by ellinas »
final28 wrote: Thu Jan 05, 2023 8:59 am No, just book the appointment.
Thank you for your message, I wonder how long that would take dealing with TC!
jpilot77
Re: IATRA benefits?
Post by jpilot77 »
I don’t think there are big delays at this point for exams. I’d bet bet if you book an exam you’d actually need more time to study than anything else.
Return to “Employment Forum”
