danger of turboprop aircrafts
sufian1
Post by sufian1 »
Prevent stall on turboprop aircrafts like Dash -8 and ATR 72 42 and the likes
First there is a need to understand that these by-design have a very thin wing for economy purpose. This design feature must be thoughtfully studied to make flying these type of aircrafts not dangerous.
At approach speeds this thin wing requires all the airflows from the propellers.
The crew must keep the Rpm high at all time to keep the airflow over the wing
And perform the approach with really high power setting even if the speed would increase but it can be kept the lowering of the drags.
And reduce the speed by the means of lowering the drags ( landing gear, flaps)
Planning the approach path carefully so as not to be high at some point which dictate lower the nose down where the speed increase for the short runway ahead.
So these aircrafts are dangerously have a HIGH RATE OF DECELERATION unlike the jet aircraft which still share the higher deceleration rate at approach speed.
For example when performing the planning the crew must make sure to monitor the loading of the aircraft very closely as of balance in these aircrafts is intolerant.
A tail heavy loaded aircraft the stabilizer will provide upward force to keep the nose from pitching up but when the aircraft is slowed for approach (by means of drags and NOT THE REDUCTION OF POWER) the stabilizer will not be able to provide that upward force and the nose will pitch up when the speed is low and this will cause a deep stall where the crew cannot push the nose down.
And worse if the power is wrongly used and reduced to unspooled range when the crew no need to prevent the imminent stall the aircraft will stall before the engines spool up!
Worse if one engine would spool up before the other this will cause yaw and one wing will drop the nose now will start slowly to lower because of the loss of the vertical lift component. Altitude now is so low and not enough to recover from the stall!
Again the power must be kept up at all time (to keep the airflow of the propellers over the wing) and speed lowered by drags. The approach can be thought of as putting the aircraft for overshoot configuration with landing gear and takeoff flaps and high RPM, in a way that if engine failure should occur the crew would have high enough speed to force land the aircraft.
Bede
Re: danger of turboprop aircrafts
Post by Bede »
Sorry, what?
YC87DRVR
Post by YC87DRVR »
sufian1 wrote: Thu Jan 26, 2023 2:02 pm Prevent stall on turboprop aircrafts like Dash -8 and ATR 72 42 and the likes
Thanks Captain Obvious.
You’re saving lives, one rambling post at a time.
linecrew
Post by linecrew »
*aircraft
rigpiggy
Post by rigpiggy »
If your aircraft (non fbw) provides upward lift on your tail, you are dangerously out the back of your envelope. Methinks he watches "Mayday" too much
rigpiggy wrote: Sun Jan 29, 2023 8:06 am If your aircraft (non fbw) provides upward lift on your tail, you are dangerously out the back of your envelope.
What makes you say that?
Sorry, what?
Don't be sorry... just... what?
I don't know where to begin to comment that... So I won't bother....
porcsord
Post by porcsord »
This reads like you asked ChatGPT about ATR or -8 stalls.
No Smoke, No Fire
Post by No Smoke, No Fire »
porcsord wrote: Sun Jan 29, 2023 9:15 am This reads like you asked ChatGPT about ATR or -8 stalls.
ChatGPT would be a lot more coherent.
Old fella
Post by Old fella »
Bede wrote: Sun Jan 29, 2023 6:21 amSorry, what?
Hmmm……. this new “common-tater” has a distinctly similar writing style/structure as another poster who frequents this site 😉.
Loon-A-Tic
Post by Loon-A-Tic »
It's likely not the first time this acronym has been used but it seems appropriate.........OTL
fish4life
Post by fish4life »
Tell me you’ve never flown a large turboprop without telling me you’ve never flown a large turboprop.
YC87DRVR
Post by YC87DRVR »
Old fella wrote: Sun Jan 29, 2023 9:47 am
I’d like to bet 500$ on “Captain” Keith.
Rooster69
Post by Rooster69 »
No way the OP is a pilot. It is just written too poorly.
TG
Post by TG »
Nice trolling :mrgreen:
:lol: :lol: :lol:
Except even Captain Keith makes [a little] more sense than that!
rigpiggy
Post by rigpiggy »
digits_ wrote: Sun Jan 29, 2023 8:34 am
[/quo te]
Which way does the aerofoil face on most non the tails?
rigpiggy wrote: Mon Jan 30, 2023 9:48 am
Just because a lot of them point down a bit, doesn't mean that you need to be outside the back of the envelope, let alone 'dangerously' out the back of the envelope in order for them to provide upward lift.
During normal operations of an aircraft, it's perfectly possible that a tail will generate lift. You might not need as much positive lift as you might need downward force at some point in the flight, but you might encounter a lifting tail.
Remember, the more downwards force the tail generates, the more upwards force the wing needs to generate, and the less efficient your plane is. Ideally you'd have a tail that generates neither up nor down force. But that plane would be uncontrollable.
Some examples:
source: https://en.wikipedia.org/wiki/Center_of ... t_aircraft
This data strongly suggests that a CoG can be put behind the CoL of the main wing, which almost guarantees that the tail will have to lift.
Note the 'almost', as there are some extra forces due to drag on the fuselage which may create a nose up or nose down moment and could theoretically cancel out the need for a positive tail lift, but it seems highly unlikely they would be big enough to actually do so.
So the CoG position is located as indicated above. The CoL of a wing is usually located around the 25% MAC position. That leaves ample margin to determine with some degree of certainty that the 737, 767 and 747 will generate upwards lift on the tail at some point.
Or, see the discussion here: viewtopic.php?t=87966
CJ3PILOT
Post by CJ3PILOT »
Rooster69 wrote: Sun Jan 29, 2023 1:37 pm No way the OP is a pilot. It is just written too poorly.
Thank you now l don't have to say it.
broken_slinky
Post by broken_slinky »
I thought the danger of turboprops was those spinny things attached to the wings or nose?
NovaBoy
Post by NovaBoy »
I fear for my life everytime they make me fly the King Air
rigpiggy
Post by rigpiggy »
digits_ wrote: Mon Jan 30, 2023 10:07 am
Some examples:
Remember swept wing jets have area far behind the cg supplying upward
where do you measure the cg?
‘Bob’
Post by ‘Bob’ »
On the MEAN AERODYNAMIC CHORD.
Swept wings are literally why we use MAC.
YYCAME
Post by YYCAME »
I guess it's only a matter of time until AI bots start posting on forums and learning from the responses as a way to train them.
W5
Post by W5 »
Personally I thought it was the noise. (Darts anyone?)
