New hire bids
swervin
Re: New hire bids
Post by swervin »
Only 17 in this class again?
hank998899
Re: New hire bids
Post by hank998899 »
swervin wrote: Mon Feb 20, 2023 11:40 am Only 17 in this class again?
17 new hires + 2 return to work
ellinas
Re: New hire bids
Post by ellinas »
hank998899 wrote: Mon Feb 20, 2023 12:24 pm
Are there normally more in a new classroom? What’s the size of your typical new hire GS?
if you are on the ground I guess there is now way but to look up!
kiaszceski
Re: New hire bids
Post by kiaszceski »
ellinas wrote: Mon Feb 20, 2023 12:35 pm
20
ellinas
Re: New hire bids
Post by ellinas »
kiaszceski wrote: Mon Feb 20, 2023 12:49 pm
20
Oh ok , thanks! I guess 19 out of 20 seems like a full class.
S2CPC
Re: New hire bids
Post by S2CPC »
I thought everything was shifting east?
capt_Z
Re: New hire bids
Post by capt_Z »
Anyone knows which GS they are currently filling up?
rudder
Re: New hire bids
Post by rudder »
S2CPC wrote: Mon Feb 20, 2023 6:57 pm I thought everything was shifting east?
They cannot get CA to leave YYC/YVR. Western CA attrition to AC is nominal. So attrition FO spots are filled to balance rosters.
If 10 western CA resigned tomorrow, then there would be less new-hire opportunities out west.
Malfunction
Re: New hire bids
Post by Malfunction »
rudder wrote: Tue Feb 21, 2023 4:43 am
Lots of yvr cpts leaving. Bottom 1/3 are leaving
rudder
Re: New hire bids
Post by rudder »
Malfunction wrote: Sat Feb 25, 2023 7:11 am
YVR is not the problem. When the dust settles, YVR will likely be the only western base.
AC pilot bases - YUL/YYZ/YVR (*YWG 50 pilots due to ACPPA)
Jazz pilot bases - YUL/YYZ/YVR
This is what Bill Bredt (Jazz COO seconded from AC) wanted in 2004.
hank998899
Re: New hire bids
New bid numbers
CRJ 2xYYC 2xYVR FOs
Q400 6xYYZ CAs OR 4xYYC 2xYVR FOs
E175 2xYUL 6xYYZ FOs
canadian_aviator_4
Re: New hire bids
Post by canadian_aviator_4 »
rudder wrote: Mon Feb 27, 2023 6:32 am
%100 Agree
capt_Z
Re: New hire bids
Post by capt_Z »
hank998899 wrote: Mon Mar 13, 2023 3:29 pm New bid numbers
CRJ 2xYYC 2xYVR FOs
How do they assign the equipment and base?
Depending who got hired first?
canadian_aviator_4
Re: New hire bids
What is the experience level of the new hires these days?
hank998899
Re: New hire bids
capt_Z wrote: Mon Mar 13, 2023 7:23 pm
CRJ 2xYYC 2xYVR FOs
New hires that were part of ALPA carriers before get first pick in order of date of hire at their previous carrier, then it’s random seniority draw…
capt_Z
Re: New hire bids
Post by capt_Z »
canadian_aviator_4 wrote: Mon Mar 13, 2023 7:37 pm What is the experience level of the new hires these days?
I've heard 750 Hrs people getting offers.
RoAF-Mig21
Re: New hire bids
Post by RoAF-Mig21 »
When do new hires get posted to the seniority list? Is it as soon as possible, or once they get their line check done? Would someone that got his plane 3 days ago show up on the March seniority list?
flyingcanuck
Re: New hire bids
Post by flyingcanuck »
RoAF-Mig21 wrote: Mon Mar 13, 2023 9:17 pm When do new hires get posted to the seniority list? Is it as soon as possible, or once they get their line check done? Would someone that got his plane 3 days ago show up on the March seniority list?
Second day is I remember right. When you do the seniority draw
RoAF-Mig21
Re: New hire bids
flyingcanuck wrote: Tue Mar 14, 2023 7:13 am
Cheers for that! 'ppreciate it!
slicktop
Re: New hire bids
Post by slicktop »
There is no such thing as a "March" seniority list. The seniority list only gets updated once every January. The soonest they'll see their name on anything is in the next bid in April, or once they are assinged an aircraft and base they'll appear on that aircraft's elegibility list on Report Link.
rudder
Re: New hire bids
Post by rudder »
slicktop wrote: Tue Mar 14, 2023 3:44 pm
Seniority list is updated and issued quarterly.
Position list is updated monthly.
BTD
Re: New hire bids
Post by BTD »
Hmm. Sounds like this is in the wrong sub forum.
rudder
Re: New hire bids
Post by rudder »
BTD wrote: Thu Mar 16, 2023 7:59 am
Yes - that reply was definitely based on the AC system.
Roundel Randy
Re: New hire bids
Post by Roundel Randy »
hank998899 wrote: Mon Mar 13, 2023 7:37 pm
CRJ 2xYYC 2xYVR FOs
If you end up with something you don't want, when is the earliest you can switch? Is it possible to wait until the next bid?
Outlaw58
Re: New hire bids
Post by Outlaw58 »
Roundel Randy wrote: Sun Mar 19, 2023 8:51 am
Depends on what it is you don't want. If it's your base, that is a non-issue because you will more than likely be awarded your base of choice before the end of training.
If it is the equipment, you will be subject to an equipment freeze for 48 months,. The only exception is if you get awarded the E75 and want to move to YVR or YYC, in this case you would be released from your freeze after 24 months because there are no E75 based in the west.
The only other way to get released from your freeze is to bid a CA seat on your desired equipment, but beware that there are quite a few that have found making the move to the left seat on a new type somewhat challenging. Many (including me) will recommend to either switch type in same position then upgrade, OR upgrade on your current equipment and THEN switch type.
All that said, there are no "more desirable" equipment at Jazz; all types have something to offer and also have their inconveniences. Best is to make the most of it rather than remain bitter and twisted because you didn't get the type you wanted. That is a sure recipe to be miserable.
58
