Can you justify the bolded statement with some level of airline experience, ie; do you have any?digits_ wrote: ↑Sat Mar 04, 2023 3:13 pmThey are in an emergency situation. They don't have to meet any missed approach climb gradients anymore. (Although i am sure they could)co-joe wrote: ↑Sat Mar 04, 2023 1:54 pmNo weather to cause a missed? That wind can easily give moderate turbulence on the approach. A million other things outside of the pilot's control can cause a missed, unstable approach, aircraft or vehicle on the runway, birds... point is, in a 705 aircraft you need to brief and be ready for every possibility. Just saying oh we'll fly the lake to Penticton is all well and good, but you have to be able to meet the missed approach climb gradient single engine, which now means setting up and briefing the possibility of a complex special on one engine. Is it the tightest valley in the world? No of course not.J31 wrote: ↑Fri Mar 03, 2023 9:47 pm VFR in the valley around CYLW. TCU over the divide I believe. So a good decision to go to Kelowna. Easy single engine miss approach to the south if required but no weather to cause a miss.
...METAR CYLW 030000Z AUTO 26016G24KT 200V320 9SM BKN091 BKN110 08/M10 A2965 RMK SLP053
METAR CYLW 030100Z AUTO 23016G21KT 9SM BKN140 07/M10 A2968 RMK SLP065=
Good job on the Q400 folks!
Yes they did a good job, yes they were stopped by what looks like Bravo in the video, round of applause. Now can we get serious and talk about the decision to land in those winds, on the downhill runway, in a tight mountain valley, with a 9000' missed approach altitude in strong gusty crosswinds?
About the only thing that would force me to land in ylw single engine is an active uncontrollable fire. Just why would you add risk to the situation?
Again, where would you have landed instead?
First of all, at Jazz on both the RJ and Q400, for a planned S/E approach you MUST plan and brief aerodata which is our engine out procedure, in mountainous the S/E complex special procedures will be used.
For a normal two engine approach, if the missed approach procedure has an associated climb gradient, you must include the engine out procedure.
On what planet is the climb gradient no longer relevant, if you can’t maintain that, guess what happens, you contact terrain!
