Procedure Turns
Re: Procedure Turns
Where a "course reversal" (the official name for a procedure turn) is charted, there is a certain volume of protected airspace guaranteed safe from terrain and other traffic; as long as you remain within the protected airspace, the method and path you fly to turn your aircraft around is entirely up to you.
I believe in the US where a racetrack is charted you must use it; but that's a US rule so won't come up in the INRAT.
Re: Procedure Turns
Anyways, notice they’re just all more or less variations on a hold entry and take 4-6 minutes. I’m not sure there’s much to be asked about them on an exam other than questions about which airspace is protected for you and in the case of uncontrolled airspace how long it’s protected for.
Re: Procedure Turns
Here's the source for the different types of reversal:
https://ffac.ch/wp-content/uploads/2020 ... edures.pdf
See section 3.2.2 and following.
Re: Procedure Turns
How can uncontrolled airspace be protected?
dialdriver
Re: Procedure Turns
I don't have it in front of me right now, but I believe the Instrument Procedures Manual will cover procedure turn variations.archstantun wrote: ↑Sat Mar 18, 2023 4:38 pm Hey guys, I'm studying for my INRAT right now. And I'm going through the procedure turns slides from pilottraining.ca. I can not for the life of me find out the source of the procedure turns.
I see these methods:
- Hockey Stick / Standard
- Racetrack
- S-Turn
I search the AIM, CAP GEN, TC Flight Training Manual even, CFS, and yes From The Ground Up. There's nothing in these books discussing these methods. Ctrl-F brings up nothing. Where in the hell are these procedures coming from? Thin air? Lol thanks. I've even screen shot the picture, then searched by image on google, I can find the picture on an American website. But again, no sources.
- Modified Racetrack
The bullshit thing is in the AIM, it actually states that procedure turns may potentially cause mid-air collisions at major airports. But knowing my luck, this will be the question I get wrong that will put me at 68% instead of the 70% to pass. So I'm looking for your help. Thanks, lol
dialdriver
Re: Procedure Turns
It is protected by communication with other aircraft as outlined in the AIM.
Re: Procedure Turns
You are correct - page 4-41.dialdriver wrote: ↑Sat Mar 18, 2023 5:43 pm
I don't see anything in the AIM that's relevant. When you get a chance, can you elaborate?dialdriver wrote: ↑Sat Mar 18, 2023 5:45 pmIt is protected by communication with other aircraft as outlined in the AIM.
- rookiepilot
Re: Procedure Turns
Usually the protected side is on one specific side of the final approach course.photofly wrote: ↑Sat Mar 18, 2023 5:13 pm Where a "course reversal" (the official name for a procedure turn) is charted, there is a certain volume of protected airspace guaranteed safe from terrain and other traffic; as long as you remain within the protected airspace, the method and path you fly to turn your aircraft around is entirely up to you.
- rookiepilot
Re: Procedure Turns
I can’t either. Where is your instructor? IPM is the bible for this…..archstantun wrote: ↑Sat Mar 18, 2023 7:10 pmI just can't believe I was never introduced to this document until JUST now.dialdriver wrote: ↑Sat Mar 18, 2023 5:43 pmI don't have it in front of me right now, but I believe the Instrument Procedures Manual will cover procedure turn variations.archstantun wrote: ↑Sat Mar 18, 2023 4:38 pm Hey guys, I'm studying for my INRAT right now. And I'm going through the procedure turns slides from pilottraining.ca. I can not for the life of me find out the source of the procedure turns.
- Racetrack
- S-Turn
... Can you please name all the documents I SHOULD have? God Almighty.
dialdriver
Re: Procedure Turns
Ser RAC 8.10, 9.12 and 9.13.photofly wrote: ↑Sat Mar 18, 2023 5:49 pmYou are correct - page 4-41.dialdriver wrote: ↑Sat Mar 18, 2023 5:43 pm
dialdriver
Re: Procedure Turns
Your primary reference documents are the AIM, CAP, IFR Charts, CFS, CARS and IPM.rookiepilot wrote: ↑Sat Mar 18, 2023 7:14 pmI can’t either. Where is your instructor? IPM is the bible for this…..archstantun wrote: ↑Sat Mar 18, 2023 7:10 pmI just can't believe I was never introduced to this document until JUST now.dialdriver wrote: ↑Sat Mar 18, 2023 5:43 pm
Re: Procedure Turns
I looked at those parts carefully and I don't see anything that answers your point here about which uncontrolled airspace is being protected for you, by whom, and for how long:dialdriver wrote: ↑Sat Mar 18, 2023 7:31 pmSer RAC 8.10, 9.12 and 9.13.photofly wrote: ↑Sat Mar 18, 2023 5:49 pmYou are correct - page 4-41.dialdriver wrote: ↑Sat Mar 18, 2023 5:43 pm
Can you be more specific?dialdriver wrote: ↑Sat Mar 18, 2023 7:31 pm m not sure there’s much to be asked about them on an exam other than questions about which airspace is protected for you and in the case of uncontrolled airspace how long it’s protected for.
Re: Procedure Turns
I wouldnt stress about this if I were you. But you should go through the IPM.
I used sharper edge when I did mine and also knew and understood the cap very well. If you do that you should be fine. I didnt find it to be a very tough exam.
dialdriver
Re: Procedure Turns
The airspace is not protected for you. It is 'protected' through blind broadcasts, position reports and pilots directly resolving conflicts with other pilots.photofly wrote: ↑Sun Mar 19, 2023 3:29 amI looked at those parts carefully and I don't see anything that answers your point here about which uncontrolled airspace is being protected for you, by whom, and for how long:
The quote about exam questions was not my statement, it was lownslow's. No idea how you quoted me on something I didn't write.
Re: Procedure Turns
I actually did a procedure turn on my IFR initial flight test......in 1986
With all approaches rapidly transitioning to RNAV T shaped procedures the chance of you actually having to do one in the real world is diminishing by the day.
Bottom line is don't over think the question. A procedure turn is like every other part of an instrument approach. Each leg will have a published altitude and track or heading. The outbound part of the procedure (i.e. the turn away from the outbound course to start the reversal) is flown for one minute. For a procedure turn on an ILS you fly outbound until you are above the glideslope before starting the reversal. All the airspace on the side of the procedure turn is protected. Anything non standard will be in the approach plate notes. That is all you should have to know to pass the test.
Re: Procedure Turns
….wait until Xi the Pooh throws a few billion ball bearings into low Earth orbit and takes out the GPS constellation…Big Pistons Forever wrote: ↑Sun Mar 19, 2023 9:32 am
Re: Procedure Turns
Yes - my bad. Maybe he can answer the question about what he meant?dialdriver wrote: ↑Sun Mar 19, 2023 8:21 am The quote about exam questions was not my statement, it was lownslow's. No idea how you quoted me on something I didn't write.
Re: Procedure Turns
You mean until you are below the glide slope, right?Big Pistons Forever wrote: ↑Sun Mar 19, 2023 9:32 am For a procedure turn on an ILS you fly outbound until you are above the glideslope before starting the reversal.
Re: Procedure Turns
Is an approach with a procedure turn ever asked on the flight test?
Re: Procedure Turns
Yes of course and I am going to blame Microsoft autocorrect for the typoAviatard wrote: ↑Sun Mar 19, 2023 3:30 pmYou mean until you are below the glide slope, right?Big Pistons Forever wrote: ↑Sun Mar 19, 2023 9:32 am For a procedure turn on an ILS you fly outbound until you are above the glideslope before starting the reversal.
Re: Procedure Turns
Did a hand flown full procedure for my faa test last year
dialdriver
Re: Procedure Turns
Not required for light twins.archstantun wrote: ↑Sun Mar 19, 2023 5:13 pm What about balanced field lengths? Not much to find in these documents.
Re: Procedure Turns
Mostly the candidate can plan whatever approaches are reasonable for the route they filed and the weather. One needs to be a precision approach or otherwise have vertical guidance but that's the only stipulation on what's flown. And I don't think it's normal for the examiner to step in. I was always suggested to get on the radio and ask for vectors to the localizer.
