Socata TBM Crash in Alberta
Re: Socata TBM Crash in Alberta
I'm more curious about the other accident, where pilot died and passenger was seriously injured... Anyone know what type?
imjustlurking
A story about it is, but nothing about what type, which is what I asked. But thanks for playing.
C-FFYM, a privately registered Daher TBM700N (TBM910), was conducting an IFR flight from
Vernon (CYVK), BC to Westlock (CES4), AB. The aircraft departed CYVK and flew to Springbank
(CYBW), AB with 1 pilot and 1 passenger on board. The aircraft landed in CYBW and made a short
stop to pick up 2 additional passengers. During this stop, the aircraft remained running and did not
shut down. Moments later, the aircraft departed CYBW for CES4. During landing on Runway 28 at
CES4, the aircraft landed hard on the right hand main landing gear, bounced and rolled inverted
coming to rest on the south side of the runway. The passengers were assisted out the main
entrance by witnesses; the passengers had minor injuries. The pilot was trapped in the cockpit for
about 2 hours before first responders could get him safely out of the wreckage; he had serious
injuries. An investigator from the TSB Edmonton office deployed to the site.
The pilot survived but the investigators could not determine his time on type?
I'll never understand why people don't wear all their seatbelts in an airplane. Especially in a fairly new one with fairly comfortable ones.
- TurkeyFarmYQX
The TBM is the new Bonanza "Doctor Killer"
It's too much plane for most people.
Victimized by Boeing
The accident report takes the position that a 3° approach is optimal for this aircraft:
The report opines that:
Is it better to fly this plane like a jet, even though it isn't one? Maybe that's why it's "too much plane" - but I'm curious from what does that difference stem?
At this point, a descent path of 3.9° would have been required to cross the threshold at 50 feet AGL; this was significantly steeper than an optimal or typical descent path of 3°.
it began to sink below the optimal 3° descent path
At this point in the occurrence flight, the aircraft was 18 KIAS above the normal target speed and approximately 50 feet or 0.5° above the optimal 3° approach slope.
It's even given as a cause:and by 350 feet AGL, when the aircraft was descending through the optimal 3° slope,
Is that the case for this small single-engine prop-driven aircraft? It certainly wouldn't be for a piston-powered aircraft.Finding as to causes and contributing factors
The aircraft joined the final approach well above the optimal 3° descent path and, during the steep approach that followed, the aircraft’s airspeed continually decreased and resulted in an unstabilized approach.
But this aircraft wasn't a jet transport, and was very much a turboprop that wouldn't have been "harder to slow during approach for landing".In November 2000, the Aircraft Owners and Pilots Association published an article titled “The Stabilized Approach.”Footnote50 The article states that the concept of stabilized approaches was first advocated in turbine aircraft in the late 1950s and early 1960s, when pilots were discovering that new jet transport aircraft were harder to slow during approach for landing than the large piston and turboprop aircraft they were used to. At the time, turbine engines also responded to power changes more slowly compared to aircraft with propellers, and turbine aircraft were frequently involved in undershoot accidents, in which they landed short of a runway.
A turbine aircraft is (usually) designed to fly IFR. I would say the TBM is especially suitable for such an environment, and most operators likely fly it IFR most of the time.photofly wrote: ↑Thu Mar 30, 2023 4:07 am The accident report takes the position that a 3° approach is optimal for this aircraft:At this point, a descent path of 3.9° would have been required to cross the threshold at 50 feet AGL; this was significantly steeper than an optimal or typical descent path of 3°.it began to sink below the optimal 3° descent pathAt this point in the occurrence flight, the aircraft was 18 KIAS above the normal target speed and approximately 50 feet or 0.5° above the optimal 3° approach slope.It's even given as a cause:and by 350 feet AGL, when the aircraft was descending through the optimal 3° slope,Is that the case for this small single-engine prop-driven aircraft? It certainly wouldn't be for a piston-powered aircraft.Finding as to causes and contributing factors
The report opines that:But this aircraft wasn't a jet transport, and was very much a turboprop that wouldn't have been "harder to slow during approach for landing".In November 2000, the Aircraft Owners and Pilots Association published an article titled “The Stabilized Approach.”Footnote50 The article states that the concept of stabilized approaches was first advocated in turbine aircraft in the late 1950s and early 1960s, when pilots were discovering that new jet transport aircraft were harder to slow during approach for landing than the large piston and turboprop aircraft they were used to. At the time, turbine engines also responded to power changes more slowly compared to aircraft with propellers, and turbine aircraft were frequently involved in undershoot accidents, in which they landed short of a runway.
IFR PPC training highly emphasizes stabilized approaches, and constant descend angles, even for non-precision approaches. 3 degrees seems to be the standard there. Perhaps the word 'optimal' is a poor choice, but I would definitely call it 'standard'. Doesn't the initial IFR flight test guide favor 3 degree glideslopes as well nowadays?
Given the flow of events, I would agree that the lack of 3 degree glideslope was a significant factor. He dove for it, landed short, engine likely didn't spool up quickly enough, and he was in trouble.
And yes, it was a VFR manoeuver, but if you're used to (hypothesis on my end) flying IFR on 3 degree glideslopes all the time, then a steep VFR descend might throw you off, even if it's in VMC.
There is a reason the PAPI's are set up for 3 degrees. It's a standard, not just for that type. VFR flying the papis to a normal runway, is optimalphotofly wrote: ↑Thu Mar 30, 2023 4:07 am The accident report takes the position that a 3° approach is optimal for this aircraft:At this point, a descent path of 3.9° would have been required to cross the threshold at 50 feet AGL; this was significantly steeper than an optimal or typical descent path of 3°.it began to sink below the optimal 3° descent pathAt this point in the occurrence flight, the aircraft was 18 KIAS above the normal target speed and approximately 50 feet or 0.5° above the optimal 3° approach slope.It's even given as a cause:and by 350 feet AGL, when the aircraft was descending through the optimal 3° slope,Is that the case for this small single-engine prop-driven aircraft? It certainly wouldn't be for a piston-powered aircraft.Finding as to causes and contributing factors
3 degrees is both optimal, and standard, but ref+5 in a light turboprop is too slow-the ones I've been flying for the last 5000 hours don't handle well close to ref, and being between 7k to 20k lbs instead of the 150k+ lbs that the approach and landing accident reduction document's guidelines we're designed for, you're much more susceptible to being bounced around by gusts, windshear or wake turbulence. Significant power changes are required to recover any energy deficit encountered when you're approaching at ref+5, these planes just don't have the momentum of a heavier aircraft to stay on slope and centreline when flying conditions aren't optimal on the approach.Maynard wrote: ↑Thu Mar 30, 2023 8:54 amThere is a reason the PAPI's are set up for 3 degrees. It's a standard, not just for that type. VFR flying the papis to a normal runway, is optimalphotofly wrote: ↑Thu Mar 30, 2023 4:07 am The accident report takes the position that a 3° approach is optimal for this aircraft:At this point, a descent path of 3.9° would have been required to cross the threshold at 50 feet AGL; this was significantly steeper than an optimal or typical descent path of 3°.it began to sink below the optimal 3° descent pathAt this point in the occurrence flight, the aircraft was 18 KIAS above the normal target speed and approximately 50 feet or 0.5° above the optimal 3° approach slope.It's even given as a cause:and by 350 feet AGL, when the aircraft was descending through the optimal 3° slope,Is that the case for this small single-engine prop-driven aircraft? It certainly wouldn't be for a piston-powered aircraft.Finding as to causes and contributing factors
To adapt the approach and landing accident reduction document's stabilized approach criteria for light turboprops I would rather vref+20 (+10/-5) and start slowing the aircraft to cross the threshold at ref at 200'agl.
There's also plenty of good reasons to fly a steeper approach, i.e. steeper papis as at Kemess or Creston out here in BC, following an Airbus or a Boeing on the approach into YVR. This would have to be briefed in a 2 crew environment, but is manageable with experience and aptitude.
I guess my question is, why is 3° optimal in a TBM but not for a Caravan, or turbo beaver? Or maybe it is? How about a Piper M600, or it's piston equivalent M350? 3° would be really weird for a visual circuit in most single engine planes, wouldn't it?
Yes. Almost all approaches are designed to be flown at 3°, that's your typical ILS glidepath, that's what the PAPI or VASI is calibrated to (where not otherwise indicated) and that's the usual constant approach angle data provided on approach plates for a non-precision approach.
But while you can fly a 3° approach in a light single, and would be expected to do so on an instrument approach, it wouldn't be a natural choice for a regular VMC overhead join to the downwind, base and final, which is what this airplane flew. If this pilot had flown a few more VFR circuits in this plane, this approach and landing should have been a no-brainer, shouldn't it?
What I'm asking is, is a TBM sufficiently different in handling that a competent pilot wouldn't be expected to manage a visual circuit without approach guidance in it like they could in many other similarly sized single engine turboprops? And what makes it so?
I totally get the focus on a stabilized approach, but the report almost makes a fetish of the 3° thing. The pilot was initially established on a 3.9° approach. That would be totally manageable in most small planes flying a circuit - unremarkable - if not even rather shallow. What's special about this plane?
I guess my answer is 3 degrees is optimal because it's standard for the glideslope and papi/vasi at the huge majority of airports, probably over 95%, so that's what the pilot's eye is accustomed to seeing. Flying consistent, stable approaches sets you up for consistently good landings, and the instrument and visual references we have available are pretty much all set to 3 degrees.
If I was to get into any of those types mentioned, or anything else new to me, I'd need a really compelling reason to deviate from glideslope or papi indications.
This was a VFR circuit in VMC conditions in a light single, onto a 3000' runway. Why would you need a PAPI or a glideslope to manage that (and this airport didn't have either, anyway.) Maybe the pilot just forgot how to fly a circuit in his plane?
It's not only about the plane. It's about this flight. It ended in touching down short of the runway, and then crashing.
I'm pretty sure if the same accident would have happened in a King Air or a PC12 (or any other turbine powered aircraft), the 3 degree thing would still have been mentioned in the same way.
I agree that it's totally manageable, but the crux of the matter is that it wasn't managed in this accident.
They mention in the report that he descended *through* the 3 degree glide path. If you start out on a 3.9, and you end below a 3 degree glidepath, then you are not flying a 3.9 degree glidepath, nor a 3 degree glidepath, and that is cause for concern.
To be clear, you think the dividing line between fussing over 3.9° vs 3.0°, and not fussing, is purely because the aircraft was a turboprop?
If a 787 made a 3.9° approach that would be worthy of comment for being too steep. If a 172 did it, you would be laughing at the "space shuttle sized" circuit and too-shallow approach the pilot chose to fly and agree that more circuit practice would be needed.
I'm trying to understand why the TSB thinks the TBM is on the "big airplane" side of that line; it's straight-wing, doesn't weigh very much, approaches slowly. It's also pulled by a prop, not a jet. The report doesn't have much to help me.
Happily I don't work for the TSB, but my reaction to the data would that the pilot lacked proficiency in flying visual circuits and was probably too used to relying on vertical guidance, which he didn't have available. Then he was unfamiliar with the characteristics of the aircraft during a late go-around - again, a lack of proficiency issue, and not one of glideslope. I'm sure the TSB has reached the correct conclusion and that I'm missing something, but I'm not sure what.
Yes. I'm just questioning the implication that even it had been stable and well flown at 3.9°, it would still not have been "optimal". It was a small plane on a VFR circuit to a small non-instrument runway at a small airport in VMC conditions. The report reads in the context of a much larger aircraft at a large airport.They mention in the report that he descended *through* the 3 degree glide path. If you start out on a 3.9, and you end below a 3 degree glidepath, then you are not flying a 3.9 degree glidepath, nor a 3 degree glidepath, and that is cause for concern.
I think that's the TSB's train of thought. Turboprops react a little bit slower to power changes than piston aircraft do.
Not that this should be an issue for a competent pilot. But competent pilots usually don't crash like this either. Which makes it worth mentioning it IMO.
I don't think it's about the 'big airplane'. I think it's about the turbine engine and the 'I assume it's usually flown IFR and thus used to 3 degree glideslopes'. And, more importantly, it went *below* the 3 degree glideslope.photofly wrote: ↑Thu Mar 30, 2023 10:23 am If a 787 made a 3.9° approach that would be worthy of comment for being too steep. If a 172 did it, you would be laughing at the "space shuttle sized" circuit and too-shallow approach the pilot chose to fly and agree that more circuit practice would be needed.
I'm sure both factors are important. But if he would have come down a 3 degree glideslope, stabilized (which was a more major focus than just the 3 degree glideslope per se), he would have had more chance to correct, and likely wouldn't have gone that slow, making a go around easier if required.photofly wrote: ↑Thu Mar 30, 2023 10:23 am Happily I don't work for the TSB, but my reaction to the data would that the pilot lacked proficiency in flying visual circuits and was probably too used to relying on vertical guidance, which he didn't have available. Then he was unfamiliar with the characteristics of the aircraft during a late go-around - again, a lack of proficiency issue, and not one of glideslope. I'm sure the TSB has reached the correct conclusion and that I'm missing something, but I'm not sure what.
Would it make more sense re-reading the report and replacing the 3 degree glideslope factor with an 'unstabilized approach'?
I think one has to read and judge the report as written, and without search-and-replace on the bits that you don't understand!
photofly wrote: ↑Thu Mar 30, 2023 10:23 amTo be clear, you think the dividing line between fussing over 3.9° vs 3.0°, and not fussing, is purely because the aircraft was a turboprop?
Yes. I'm just questioning the implication that even it had been stable and well flown at 3.9°, it would still not have been "optimal". It was a small plane on a VFR circuit to small non-instrument runway in VMC conditions. That's not addressed in the report.They mention in the report that he descended *through* the 3 degree glide path. If you start out on a 3.9, and you end below a 3 degree glidepath, then you are not flying a 3.9 degree glidepath, nor a 3 degree glidepath, and that is cause for concern.
I get where you're coming from, optimal is a strong word, and it's tough to be right on slope when you turn final in a VMC circuit because there's no visual or instrument slope indications available on the base leg anyway. I didn't key in as much on the deviations from 3 degrees as much though, speed and power settings we're also noted in the narrative and none of those two, or the slope, we're within any kind of stabilized approach criteria, so three out of four variables fluctuating (no mention of centerline that I picked up on)... Time to go flying and come around for another try at it.
Paragraph 2.1 does that for you. That's where the stabilized approach and the 3 degrees is tied together. It's also mentioned in the same line with the causes. It's not mentioned as a cause just in itself.
The focus on the 3.0 degree final is important because based on what I read this pilot knew or felt he was high based on his actions.
If you are on a 3.0 slope, you will need more power or thrust to maintain your speed and path than 3.9, from what I read he was at nearly flight idle for a good portion and then got low and slow. He then appeared to add enough power to drag it in just short.
My concern was a normal go around was what, 12 degrees, a stall recovery should be quite a bit less to break the stall but this pilot pitched up to 25 degrees, try that sometime, I guarantee 25 degrees pitch at the speed mentioned is well above the critical AOA.
This was a botched approach followed by a really botched bounced landing recovery!
I am only part way through the report but it looks like the pilot was high, descended through this 3 degree flight path and was then low and then stalled the aircraft. He was probably concerned about the length of the runway.
Bottom line....you have to manage your energy and be aware of it. Being a bit high is no big deal. Descending to be a bit low is no big deal. But you have to manage and remain aware of your airspeed. This is even more critical, when not flying a stable descent.
Ability to fly a steep descent in a turboprop can vary depending on engine type and drag but with a PT-6 with loads of flat pitch(like the TBM), I don't see why it would be a problem. I have flown one complete flight in a TBM700 in the left seat with a ferry pilot into Sept-Iles. I don't remember that much detail about it but it was fairly straight-forward handling, perhaps a bit heavy on the controls, if I remember correctly. I likely followed close to a 3 degree descent but if it was a bit more or less. it would not be difficult.
It is no big deal flying a 3.9 degree descent path in a large turboprop. I used to fly a 5.5 degree glidepath at an airport with a large commercial twin turboprop and it was just a matter of setting power and starting a descent. One had to flare a bit higher but proper airspeed management was key.
This guy got slow and was likely late on adding power. If you are going to dive down through the typical descent path and then reduce the rate of descent for the last few seconds of the approach, you have to be keenly aware of your airspeed and whether you will need to add power(likely if close to final approach speed) or not add power(if you have excess airspeed).
Finished the report. It appears that it was really just a case of not monitoring the airspeed resulting in a stall.
There is a link to a French report about single engine turboprops rolling over during go-arounds, typically at low speed. I suppose it may be a situation similar to the big WWII fighters with lots of torque. But really, most of have seen what happens in a power on stall.....the aircraft rolls more than with idle power.
Unfortunately, in this large report, the TSB does not discuss the most important thing of all....monitoring your airspeed.
