The Air Canada OTS thread
your flight time ?
500+ PIC JET
37
4%
500+ PIC JET 2 CREW
103
10%
500+ PIC TURBOPROP 2 CREW
158
16%
1000+ F/O JET/TURBOPROP 2 CREW
165
16%
Total Time 1500/2000
52
5%
2000/3000
115
11%
3000/ More
372
37%
Total votes: 1002
flying4dollars
Re: The Air Canada OTS thread
Post by flying4dollars »
I agree with the sentiment that you should have a good reason to defer. Seniority at AC is king. The consequences of deferring could cost you financially. Also, when the next economy paralyzer happens, you're going to want as many numbers below you as possible to protect not just your job, but your seniority, which could affect how long you spend in the right seat if you aspire to want to be in the left as quickly as possible. It can even affect the length of time it takes to get your desired base, especially if you are gunning for YWG or YVR.
LongHaul89
Post by LongHaul89 »
My understanding after talking to HR was you could defer 1 or 2 classes (as they setting up the names for those classes) but not beyond that.
Dias
Post by Dias »
I imagine some of the people looking to defer don't want to leave their current employer in the lurch with no pilot. That's very admirable but I highly suggest not doing it. If the situation was reversed your current employer will not look at you with any loyalty. You're potentially setting yourself up for extra months or years of reserve duty at AC by trying to be a good employee for a company that would not do the same for you.
Crewbunk
Post by Crewbunk »
The sentiment of getting your seniority quickly is well found.
But something else to consider; Do you really want to be outside looking in when the music stops and everyone is looking for a chair? There have been occasions in the past where hiring/training just suddenly stopped. Not to restart again for up to 4 years.
Sitting at the bottom of the list for those 4 years would be crappy enough, but trying to get hired, knowing you had a spot but gave it up, would be worse.
One only has to look at past events to see how quickly the environment changes.
Cheftony
Post by Cheftony »
Does the background check request means that you made the cut or can you still get PFO’d afterwards?
NotDirty!
Post by NotDirty! »
Cheftony wrote: Fri May 19, 2023 12:23 pm Does the background check request means that you made the cut or can you still get PFO’d afterwards?
It’s usually a good sign… but don’t count your chickens until you’re sitting in a jet at V1.
flying4dollars
A job offer means you made the cut. Nothing else.
NotDirty!
Post by NotDirty! »
flying4dollars wrote: Fri May 19, 2023 4:38 pm
Unless that job offer was for the March 23rd, 2020 PIT course!
lownslow
Post by lownslow »
SkyBagPiper wrote: Sat Apr 29, 2023 6:20 pm While deferring is a choice. Choose wisely.
Past defer-er here. Can’t endorse it, it’s a poor life choice.
dontcallmeshirley
Post by dontcallmeshirley »
When did you do your interview?
tupues
Post by tupues »
SkyBagPiper wrote: Sat Apr 29, 2023 6:20 pm While deferring is a choice. Choose wisely. Deferring does not guarantee you a spot. If they for some reason decide to forgo a class or change hiring principles due to outside factors, you may be dropped.
Whats considered deferring?
I assume when they call you with the offer they will mention the planned course date under consideration of any notice period etc. and then you get the contract. My assumption is, that once the contract is signed you are hired for the planned course even if that is only in a couple of months due to whatever circumstances there might be?
Because who in their right mind will sign a contract and resign from their current job, not knowing if they will be "dropped" in the end as you mention it.
Captain101
Post by Captain101 »
Would anyone have any info on what the psychologist virtual interview might consist of? I had done the mmpi assessment in person on the day of the interview but now have been asked to do a virtual interview with the psychologist as well.
canadian_aviator_4
Post by canadian_aviator_4 »
Any calls going out for June PIT courses?
tupues
Post by tupues »
canadian_aviator_4 wrote: Wed May 24, 2023 5:39 pm Any calls going out for June PIT courses?
yes.
Loading...
Post by Loading... »
Are they hiring OTS rn with only 2k hours TT?
northtosouth
Post by northtosouth »
Yes however need a strong resume(lots of points) and help.
flyfasttakechances
Post by flyfasttakechances »
Are they s still running a ground school every two weeks over the summer?
Pirep1234
Post by Pirep1234 »
northtosouth wrote: Sat May 27, 2023 10:27 am Yes however need a strong resume(lots of points) and help.
What’s the point system? Or how many points you need to pass?
FL030
Post by FL030 »
Pirep1234 wrote: Sat May 27, 2023 4:28 pm
500
lownslow
Post by lownslow »
It’s generally accepted that they ‘score’ your resume based on traits that they think are desirable. I imagine there will be little more than speculation on the forum but it appears that things like level of education, experience, bilingual, maybe ex-military, etc. will all contribute to scoring higher on your application. Those scored files are then placed in order and when they need to hire someone they draw from the top. I have reason to believe that they also plan out a range of scores for each groundschool so that they don’t hire all the geniuses today and work their way down to the idiots next year.
sstaurus
Post by sstaurus »
Is there a way to tell if you were in the genius or the idiot pile? :lol:
dontcallmeshirley
sstaurus wrote: Sun May 28, 2023 3:45 am Is there a way to tell if you were in the genius or the idiot pile? :lol:
If you have to ask...
LongHaul89
flyfasttakechances wrote: Sat May 27, 2023 1:55 pm Are they s still running a ground school every two weeks over the summer?
Yup, class size increasing to 40 from 35.
flyingcanuck
Post by flyingcanuck »
LongHaul89 wrote: Sun May 28, 2023 10:11 am
They have been 40 all year
lownslow
Post by lownslow »
Who cares? In is in.
Return to “Air Canada”
