That's unusual given Captains have more vacation and tend to book off more. But either way, my position on the quick upgrade days nearing an end standsrudder wrote: ↑Thu May 25, 2023 11:47 amJust trivia but 60/40 is not the case at AC. As a percentage of total positions, CA are less than 50% (44.6% to be exact).
Negotiations
Re: Negotiations
Re: Negotiations
The ratio results from the fact that AC uses WB FO’s as augment pilots and that AC has also reinstated the WB RP position.truedude wrote: ↑Thu May 25, 2023 12:10 pmThat's unusual given Captains have more vacation and tend to book off more. But either way, my position on the quick upgrade days nearing an end stands
Based on the bidding demographic in the last bid, a pilot hired by AC TODAY will be able to hold a bottom 2% NB CA award sometime in late 2025 or early 2026. That of course presumes that hundreds of more senior pilots continue to avoid bidding NB CA (including the 767F which is assigned to the NB CA equipment grouping).
Getting hired sooner in a wave rather than later will always make a difference in career progression at a legacy carrier.
More trivia - a pilot hired in the spring of 2015 will be in the top third of the seniority list by 2026. It is entirely possible that junior WB CA will be available at 12 years of seniority. By 2026 that will probably be a $400k/yr position.
It is a numbers game and always has been.
Re: Negotiations
Yes, I did fail to take into account the augmented crews. And you have to take into account a lot of people not bidding captain positions foe lifestyle reasons, which will change as they move up in seniority.rudder wrote: ↑Thu May 25, 2023 12:15 pmThe ratio results from the fact that AC uses WB FO’s as augment pilots and that AC has also reinstated the WB RP position.
Re: Negotiations
If the RP position goes away for good which something I've heard this MEC talk about, expect the NB CA to go even more Jr. There will be a lot of people bidding into a WB FO position if the list essentially doubles as their relative seniority and lifestyle will improve drastically. And many parking themselves there for the next long while (myself included).
Re: Negotiations
And AC pilots could also push for certain augment duty to require 2 CA.airbussy wrote: ↑Thu May 25, 2023 12:44 pm If the RP position goes away for good which something I've heard this MEC talk about, expect the NB CA to go even more Jr. There will be a lot of people bidding into a WB FO position if the list essentially doubles as their relative seniority and lifestyle will improve drastically. And many parking themselves there for the next long while (myself included).
Lots could change in staffing depending on final outcome in bargaining in 2023/2024.
Re: Negotiations
I think it is starting to work in that direction. We finally have language around ULR with 2CA 2FO. Next step is getting similar augmenting to the American carriers such as 1CA 2FO, 2CA 1FO, 2CA, 2FO etc.rudder wrote: ↑Thu May 25, 2023 12:48 pmAnd AC pilots could also push for certain augment duty to require 2 CA.airbussy wrote: ↑Thu May 25, 2023 12:44 pm If the RP position goes away for good which something I've heard this MEC talk about, expect the NB CA to go even more Jr. There will be a lot of people bidding into a WB FO position if the list essentially doubles as their relative seniority and lifestyle will improve drastically. And many parking themselves there for the next long while (myself included).
There should never be more than 2FOs on a crew (and no RPs).
Re: Negotiations
Its not about commuting policy. I simply won't commute by air. The +1.5hr drive is stressful enough as is most days. Its also a massive waste of my time. Flat pay and the current FO pay(at AC) preclude me from buying a home anywhere closer. I was lucky enough to get into the market where I am when I did. Now with mortgage rates where they are and inflation far above what our contract covers, even the Jazz CA pay is not cutting it either. Moving to YYZ just isn't in the cards for me for a myriad of reasons. I would say most of the YVR and YYC jazz pilots hired post 2015 are in the same mindset.
They made it even easier to look elsewhere when they took away pass travel for the first 6 months again. Not that it's worth much these days anyways with the loads, cancellations and everything else.. Probably just another negotiating tool, but still.
I highly doubt AC will ever pay for a commute (time + flight costs) Or guarantee base in initial. So it's A No from me.
I WAS happy at Jazz and it WAS a great place. Its really disheartening to watch it fall apart as a result of ACs tactics. I would say the bulk of us hired post 2015 are looking elsewhere and outside of the AC umbrella.
Re: Negotiations
It’s truly sad what Jazz has become. Either they will up the pay to an appropriate level or they will continue to lose pilots and park airplanes. It’s up to AC. They call the shots.Rowdy wrote: ↑Fri May 26, 2023 10:19 amIts not about commuting policy. I simply won't commute by air. The +1.5hr drive is stressful enough as is most days. Its also a massive waste of my time. Flat pay and the current FO pay(at AC) preclude me from buying a home anywhere closer. I was lucky enough to get into the market where I am when I did. Now with mortgage rates where they are and inflation far above what our contract covers, even the Jazz CA pay is not cutting it either. Moving to YYZ just isn't in the cards for me for a myriad of reasons. I would say most of the YVR and YYC jazz pilots hired post 2015 are in the same mindset.
Re: Negotiations
An AC internal memo just came out about even more winter cancellations out of YYC.
Reason given for the second straight year. Not enough regional pilot hours.
It would appear AC views you guys as a watershed moment they want desperately to avoid. They do not want to see what happened in the US happen here with wages and are willing to endure some pain to avoid it.
I wonder if the WJ contract will start to make them realize it’s too late. The dam has burst. They can’t avoid it.
The choice is endure pain now and still pay OR just pay and avoid the pain. But door number three where they thought they could endure some pain and keep everyones wages low is not going to pan out.
At some point someone will flip the switch and accept reality.
Planning for Summer 2024 is fast approaching.
Re: Negotiations
I really look forward to finding out one day what moron was in charge of making these decisions...Fanblade wrote: ↑Sat May 27, 2023 8:10 am An AC internal memo just came out about even more winter cancellations out of YYC.
As I watch all this play out, I keep getting reminded of this quote: "I never saw a wreck and never have been wrecked nor was I ever in any predicament that threatened to end in disaster of any sort." Said by the captain of the Titanic.
I find it amusing that they are worried about winter, when their summer schedule is about to lay in ruins. It is like they are working with out of date information. The agents tell us about all the flights that had been planned for this summer, but have since been scrapped because we don't have the crew. It is like the last days in the bunker as orders were being sent to units that no longer existed.
I will give our Union credit at Jazz: they told them in October this problem will be cheaper to fix in advance, and becomes exponentially more expensive to fix the longer you wait. It is cheaper to keep people on property, than attract new people.
And flat pay could have been dealt with proactively last fall at AC. But after the failure of the MOA at AC, did the VP of Flight Ops regroup? Nope, he went into ground schools and ranted like a lunatic.
It is just opinion, but I believe the main issue is the VP of Flight Ops refusing to accept the reality of the situation, and trying to play the game using 40 years old thinking.
They will have planes parked at Jazz by the fall, and instead of AC deploying 220's on money making routes, they will be flying them YVR to YLW. By next summer their regional network will be a shell of what it once was. And I bet they still don't comprehend the severity of their situation.
Just painful to watch the ignorance and stupidity to play out. And why, because they just can't accept that they might need to pay pilots more.
Malfunction
Re: Negotiations
100% true.truedude wrote: ↑Sat May 27, 2023 10:50 amI really look forward to finding out one day what moron was in charge of making these decisions...Fanblade wrote: ↑Sat May 27, 2023 8:10 am An AC internal memo just came out about even more winter cancellations out of YYC.
Re: Negotiations
The things I heard from friends in new hire classes blew my mind, complete lack of awareness.
Though all of this, my biggest question is; Where is the BOD?
Re: Negotiations
One would have to think that the reality check will happen when the re-opener letter arrives.airbussy wrote: ↑Sat May 27, 2023 12:49 pmtruedude wrote: ↑Sat May 27, 2023 10:50 am
That is just hours away.
Re: Negotiations
Que the angry ground school rants by one VP of flight ops in 3... 2... 1...rudder wrote: ↑Sat May 27, 2023 1:10 pmOne would have to think that the reality check will happen when the re-opener letter arrives.airbussy wrote: ↑Sat May 27, 2023 12:49 pmtruedude wrote: ↑Sat May 27, 2023 10:50 am
Re: Negotiations
I don't think the VP of Flight Ops actually has a tonne of pull when it comes to big decisions other than training. He has probably been told to get his pilots back in line.
The decisions that we are talking about come from above his pay grade. And the answer so far has clearly been no.
The problem has been that upper ACPA was out of touch with the membership. Flight Ops managements understanding of the membership came from those former ACPA leaders. To Flight Ops the change has been like a switch. It didn't have to be. It should have been obvious but they weren't paying attention.
Now they are trying to get their heads wrapped around what just happened. And so far they are not impressed
It will be people well above the VP of Flight Ops setting the company approach. I expect that approach to be unpleasant for the next year
Re: Negotiations
What just happened was representational accountability. AC senior management was dealing with a union that had at its CEO position….. a former AC senior manager!Fanblade wrote: ↑Sat May 27, 2023 3:05 pm I don't think the VP of Flight Ops actually has a tonne of pull when it comes to big decisions other than training.
Now they will be dealing with a real pilot labour organization. It will be a very different relationship.
AC has a chance to set the tone. It can be mutual respect, acceptance of fact, and mutually beneficial cooperation based on real world comparators. Or it can be 100% adversarial.
It should be no surprise what bargaining proposals are coming from the ALPA represented AC pilots. And there won’t be any Wizard of Oz this time hiding behind the curtain allowing an end-run around legitimate bargaining.
Roll up your shirt sleeves and do the required work. There is no bargain basement deal to be had …. again. The AC pilots are going to achieve significant economic and lifestyle gains.
superbilly24
Re: Negotiations
https://www.exchangeincomecorp.ca/wcm-d ... 065507.pdf
This can't be good for the Q400 operations on the east coast with Jazz. I didn't think another airline could operate Q400 for Air Canada Express with the current contract.
Re: Negotiations
Correct. Jazz's service will be reduced as planned.superbilly24 wrote: ↑Tue May 30, 2023 5:48 am https://www.exchangeincomecorp.ca/wcm-d ... 065507.pdf
Re: Negotiations
AC pilot scope (Article 1) does not specify how many Express operators AC can contract. It simply sets limits on the Express fleet and gauge.a2btrail wrote: ↑Tue May 30, 2023 5:52 amCorrect. Jazz's service will be reduced as planned.superbilly24 wrote: ↑Tue May 30, 2023 5:48 am https://www.exchangeincomecorp.ca/wcm-d ... 065507.pdf
It would be the CHR CPA that would contain any exclusively provisions. Seemingly, based on this announcement they either do not exist or have been or will be waived by CHR.
For those that were not around at the time, this has all of the appearance of GGN round 2. May even be Jazz operated (but AC controlled) Q400’s that are transferred to PAL.
Once again, obvious that AC has developed a mitigation plan to deal with the circumstance where Jazz/CHR cannot meet planned flying levels due to pilot staffing issues.
Re: Negotiations
Watch people really start to leave now. And they still have to staff these airplanes. Not sure why they would have an easier time of it than us.rudder wrote: ↑Tue May 30, 2023 6:01 amAC pilot scope (Article 1) does not specify how many Express operators AC can contract. It simply sets limits on the Express fleet and gauge.a2btrail wrote: ↑Tue May 30, 2023 5:52 amCorrect. Jazz's service will be reduced as planned.superbilly24 wrote: ↑Tue May 30, 2023 5:48 am https://www.exchangeincomecorp.ca/wcm-d ... 065507.pdf
Re: Negotiations
Air Canada and Chorus Aviation Comment on Air Canada's Bridging Agreement for Additional Regional Capacity
MONTREAL and HALIFAX, NS, May 30, 2023 /CNW/ - Air Canada (TSX: AC) and Chorus Aviation Inc. (TSX: CHR) ("Chorus"), parent company of Jazz Aviation LP ("Jazz"), are providing comment on Air Canada's arrangement for additional flying capacity with another airline for up to six De Havilland Canada DHC-8 aircraft.
"Jazz is our long-term Air Canada Express partner, and we are working together to increase flying activity within the framework of our existing CPA given the current, industry wide pilot situation. As these efforts continue, and to help meet the needs and expectations of the travelling public, Air Canada has entered into a bridging arrangement with another airline to provide additional regional capacity on select routes in eastern Canada," said Mr. Michael Rousseau, President and Chief Executive Officer of Air Canada.
"Chorus understands that Air Canada is increasing capacity to meet travel demand and that the addition of these aircraft is a bridging solution. We confirm that this agreement does not impact Chorus financially," said Mr. Colin Copp, President and Chief Executive Officer of Chorus.
Re: Negotiations
Can’t wait to read the statement from the JAZ MEC……
“All is good. Nothing to see here. We are in control”.
Guess what? You are not in control. One only has to wonder what other developments are in the offing. Perhaps this is the “uncertainty” that CB referred to. This is not a good look for a group trapped in a 12 year (remaining) CBA that was sold based on guaranteed AC flow and Express exclusivity. And living with the lowest starting pay rates in the 705 sector.
Wonder what the PAL rates will look like?
Re: Negotiations
PAL already has Q400’s and Q400 rates. I believe they are pretty similar to Jazz.rudder wrote: ↑Tue May 30, 2023 6:56 amCan’t wait to read the statement from the JAZ MEC……
https://negotech.labour.gc.ca/eng/agree ... 19001a.pdf
Re: Negotiations
The AC pilots had their B1s taken today. It seems AC jist wants to go to war with the pilots, and that is fine. They just sent the biggest single yet the Jazz is a sinking ship and we will see people really jump to life boats now.ant_321 wrote: ↑Tue May 30, 2023 7:02 amPAL already has Q400’s and Q400 rates. I believe they are pretty similar to Jazz.rudder wrote: ↑Tue May 30, 2023 6:56 amCan’t wait to read the statement from the JAZ MEC……
These people in charge are really something else. They are playing this game with outdated rules.
Re: Negotiations
Found this summary. You have to wonder if there is truly any hope for improved WAWCON in the Tier 2 sector in Canada.
PAL
Pay
Dash 8 Q400 Captain from 09/2022
1…$92.54
2…$94.95
3…$97.36
16…$125.50
Dash 8 Q400 Captain from 09/2023
1…$94.39
2…$96.85
3…$99.31
16…$128.01
Dash 8 Q400 Captain from 09/2024
1…$96.28
2…$98.79
3…$101.30
16…$130.57
Dash 8 100/300 Captain from 09/2022
1…$85.32
2…$87.72
3…$90.13
16…$121.68
Dash 8 100/300 Captain from 09/2023
1…$87.02
2…$89.48
3…$91.93
16…$124.11
Dash 8 100/300 Captain from 09/2024
1…$88.76
2…$91.27
3…$93.77
16…$126.59
Dash 8 100/300 and Q400 FO from 09/2022
1…$48.94
2…$51.31
3…$53.68
10…$73.27
Dash 8 100/300 and Q400 FO from 09/2023
1…$49.92
2…$52.34
3…$54.75
10…$74.73
Dash 8 100/300 and Q400 FO from 09/2024
1…$50.92
2…$53.38
3…$55.85
10…$76.23
Credit System:
50% deadhead
4 credits per reserve period
50% Duty rig starts 9 months from signing
25% Trip rig starts 15 months from signing
15 minutes credit for any taxi only segment (taxing from terminal-hangar etc)
1.5 times hourly pay for working day off or overtime
Overtime over 90
MMG is 78
Scheduling:
No more than 3 hour schedule change without consent, and 1.5 rate if you do agree to the change
New bidding system allows pilots to bid pairings by seniority
Minimum 12 days off per month
10 days vacation years 1-3
15 days years 3-10
20 days years 10-25
25 days years 25+
10 ‘stat day vacation days’ per year – so no more stat pay but an extra 10 days vacation to bid on top of the days above, so basically it’s 20 vacation days from year 1.
Days off guaranteed on each side of each 5 day block of vacation
60 sick credits per year, can carry over up to 80 each year, so potential max of 140/yr
PAL
Pay
1…$92.54
2…$94.95
3…$97.36
16…$125.50
1…$94.39
2…$96.85
3…$99.31
16…$128.01
1…$96.28
2…$98.79
3…$101.30
16…$130.57
1…$85.32
2…$87.72
3…$90.13
16…$121.68
1…$87.02
2…$89.48
3…$91.93
16…$124.11
1…$88.76
2…$91.27
3…$93.77
16…$126.59
1…$48.94
2…$51.31
3…$53.68
10…$73.27
1…$49.92
2…$52.34
3…$54.75
10…$74.73
1…$50.92
2…$53.38
3…$55.85
10…$76.23
Credit System:
50% deadhead
Overtime over 90
MMG is 78
Scheduling:
15 days years 3-10
20 days years 10-25
25 days years 25+
