The Air Canada OTS thread
your flight time ?
500+ PIC JET
37
4%
500+ PIC JET 2 CREW
105
10%
500+ PIC TURBOPROP 2 CREW
164
16%
1000+ F/O JET/TURBOPROP 2 CREW
167
16%
Total Time 1500/2000
54
5%
2000/3000
123
12%
3000/ More
380
37%
Total votes: 1030
Transition9er2
Re: The Air Canada OTS thread
Post by Transition9er2 »
crystalpizza wrote: Mon Aug 07, 2023 12:32 pm The Jazz pilots with September conditionals recently got upgraded to formal offers so at least for this group they are definitely following through.
How does the seniority draw work for these Jazz Sept hires? I’d their seniority determined in their Sept class? All while OTS hires get job offers after them, class starts before them and seniority numbers senior to them?
Am I missing something?
cdnavater
Post by cdnavater »
Transition9er2 wrote: Mon Aug 07, 2023 5:49 pm
Nope, not missing anything! That is exactly how it’s working out for them.
CaptDukeNukem
Post by CaptDukeNukem »
smooth wrote: Mon Aug 07, 2023 3:35 am Actually, it's a conditional offer, I've heard it's a different offer than what OTS guys are getting. Most likely they will honor the offer but you never know, nothing is 100%
CaptDukeNukem wrote: Sun Aug 06, 2023 2:53 pm
canadian_aviator_4 wrote: Fri Aug 04, 2023 5:33 pm
I wonder if AC will actually follow through with jazz pilots starting from sep to nov, considering how much further it will deplete jazz of pilots. Unless AC is hoping to start shutting down jazz bases and consolidating staff into one or two bases. At this point anything is possible.
I think they will. Many of them got confirmed PIT dates.
Sorry for the late reply. They started with conditional offers. Then got called for confirmed dates
ohio_19
Post by ohio_19 »
CaptDukeNukem wrote: Wed Aug 09, 2023 12:11 am
How many Jazz pilots will be in each class? 50% ?
ohio_19
Post by ohio_19 »
Are the calls going out for Sep GS’?
a2btrail
Post by a2btrail »
ohio_19 wrote: Mon Aug 14, 2023 1:44 pm Are the calls going out for Sep GS’?
Yup
canadian_aviator_4
Post by canadian_aviator_4 »
ohio_19 wrote: Fri Aug 11, 2023 3:32 pm
Hopefully %100 after all the bs they have had to endure from both jazz and Air Canada in the so called preferential hiring/flow scheme.
bob99
Post by bob99 »
August equipment bid results are out. Most junior Captain is now just under a year on the 220.
rudder
Post by rudder »
bob99 wrote: Tue Aug 15, 2023 5:33 am August equipment bid results are out. Most junior Captain is now just under a year on the 220.
Sounds about right.
Junior NB CA has been going around 800 numbers from the bottom.
DanWEC
Post by DanWEC »
How long is this expected to continue? Would someone hired reasonable soon be likely to enjoy the same progression?
bob99
Post by bob99 »
Imo it'll continue for a little while yet. Still lots of 220s to arrive, followed by the NEOs if that ever happens.
flyingcanuck
Post by flyingcanuck »
bob99 wrote: Tue Aug 15, 2023 9:18 am Imo it'll continue for a little while yet. Still lots of 220s to arrive, followed by the NEOs if that ever happens.
dont forget the XLRs
flying4dollars
Post by flying4dollars »
flyingcanuck wrote: Tue Aug 15, 2023 10:15 am
I think that's what he meant. The XLR's are NEO aircraft. Any talk of 320 NEO's is just a rumor for now. Thought it would be nice to upgrade the aged 320 fleet. Carrying 20T of gas from YYZ to YVR on a 321 is insane. The MAX burns like 4-5T less.
Hotoffthepress
Post by Hotoffthepress »
Quick Q.
What are the reasons for quick commands being available?
Not enough pilots?
Lifestyle choices?
Not enough candidates with hours, allowing those with less seniority to jump ahead?
FL030
Post by FL030 »
Hotoffthepress wrote: Wed Aug 16, 2023 12:52 am Quick Q.
Not enough pilots?
Lifestyle choices?
The job doesn't pay enough for the responsibility you have.
Not enough pilots?
Lifestyle choices?
Being at the bottom of the list sucks at any company. Years of being on reserve, working every weekend/holiday. Crappy pairings nobody wants. Missing out on family stuff…. That’s why many forgo the upgrade. It’s not all about the money. Quality of life is more important.
sstaurus
Post by sstaurus »
Many people will put in their bid, to automatically be placed at say, 75% of the list. (Or whatever) So they are just delaying until they can hold a better sched. In the meantime, those willing to be at the bottom are free to take it. However, higher seniority numbers will be parachuting in above you for quite a while…
Dry Guy
Post by Dry Guy »
What percentage do you need to typically to hold a block?
bob99
Post by bob99 »
That'll vary by the fleet and month. Looking at the Aug YZ37, there's guys in the bottom 10 positions holding blocks, versus the 319 where the bottom ~25 (12%) are on rsv. I think generally about 20% will be on rsv.
bob99
Post by bob99 »
Not enough pilots?
Lifestyle choices?
Upgrades are strictly seniority based, there's no such things as not enough hours. But not enough pilots definitely has something to do with it. Looking at the August bid, in YZ there's 155 737 Captains and only 36 FOs. They might add 15-20 FOs before the next bid, and the top ~20 guys usually stay put. For the YZ 220, there's 180 CA and 71 FOs, 44 of which have less than a year.
They've also forced lots of new hires into WB FO positions, many of which will stay there as they like the flying and have burned their WB course right.
LongHaul89
Post by LongHaul89 »
August equipment bid shows a need for atleast 800 more pilots!
Dry Guy
Post by Dry Guy »
Thank you for the info! I'm surprised actually that 20% are on reserve.
Hotoffthepress
Thanks for all the responses.
Good to get a bit of clarity to the situation.
TheStig
Post by TheStig »
flying4dollars wrote: Tue Aug 15, 2023 4:25 pm
The A350's are just a rumour. 26 A321XLR's have been ordered, the certification of the aircraft has run into delays.
https://aviationweek.com/air-transport/ ... xlr-delays
There are equipment overlaps on a lot of routes but the 73M8 and 321XLR will fill different rolls. The Max flying is pretty well established at this point, while the XLR will come with lie-flat bed and provide trans-Atlantic capacity that the airline hasn't had since the 767's were retired, as well as providing replacement aircraft for its ageing 320 fleet.
https://princeoftravel.com/news/new-det ... ess-class/
Mekki
Post by Mekki »
Any calls going out for late September groundschool?
Return to “Air Canada”
