Difficulty in getting a RAIC?
Hello,
I am currently in the 704 world now about to make the jump to the 705 world which requires a RAIC.
I do not have any convictions but my record is not clean as well. I had several charges in the past at different times but they all either ended with being withdrawn/stayed or I entered a conditional discharge and my record was wiped clean (none are drug/gang related). I have no problem passing a regular criminal check and crossing the boarders as I have been doing it for 704 operations consistently.
I know Transport Canada will see everything though as they request LERC (Law Enforcement Record Check) from RCMP. I was wondering what my chances are in getting a RAIC. My last charge was from 5 years ago. What can I do to increase my chances of getting the RAIC?
Anyone here that got their RAIC denied? What are you doing now? Did you appeal and did you try again to get a RAIC after the required 5 years wait time?
Re: Difficulty in getting a RAIC?
Bump - I’m in a very similar situation, did you ever receive your RAIC OP?
If an airline asks the question if you will be able to obtain a RAIC you have to say yes, you won't get hired if the answer is maybe or no. In your cases I would probably go get hired by Tim Hortons or EFC or Menzies or something and do the process. I don't know of a way to find out without actually applying for one, I know a guy who got let go before sim training when it turned out his pardon wasn't enough and he had more steps to go through. I don't know any specifics about his case except that as a young man he made some bad decisions.
TailwheelPilot
How is anyone supposed to know if they will be issied a RAIC or not? Or is there a publicly accessible, very clear and exhaustive list of things that makes one unacceptable?
Ģenetally speaking, drug trafficking will disqualify you.
DUI you should be ok.
The Barrel Man
For what it’s worth I have an assault charge and I’ve held a RAIC for almost 10 years. I’ve also travel to the USA a few times.
Thunder Bay radio, HEG is in the airborne section, call final for 27
mmm...bacon
Getting rowdy in the Winston!The Barrel Man wrote: ↑Fri Dec 01, 2023 7:09 pm For what it’s worth I have an assault charge and I’ve held a RAIC for almost 10 years. I’ve also travel to the USA a few times.
Sorry for the late reply.
I did eventually get my RAIC even it took a year on the yellow pass.
My understanding having gone through the process is as long as you stayed out of trouble for the last 5 years and your past charges do not have anything to do with drugs/trafficking/violence, you should be fine.
I would start reading up relevant cases on CANLII.org as many has suggested here throughout the years here and have a letter/references/supporting docs ready to go if TC do ask.
Hope you do get your RAIC! Is a nerve racking experience for sure. Good Luck!
