the best drive
the best drive
757 - powerful joy
A380 - quiet inside
737 - perhaps cramped but great all around
A319/20/21 - comfortable
King Air - fun
CRJ-200 - POS
Across other forums, these were some of the responses regarding the a/c listed.
There were other aircraft discussed beyond those above, of course.
What is the aircraft that, when you look back at your time on it, you smile or favor it over others?
Was it the aircraft on which you were the most senior?
Or was it the aircraft itself
A380 - quiet inside
King Air - fun
CRJ-200 - POS
- flying4dollars
Re: the best drive
Mountain flying in and out of crap/nice weather? Beech 1900C
Re: the best drive
Cargo falcon 20, best performer around for fun at night.
Re: the best drive
I second this. 1900C even more fun hand flying than B200 King Air.flying4dollars wrote: ↑Wed Dec 06, 2023 1:08 pm Mountain flying in and out of crap/nice weather? Beech 1900C![]()
Re: the best drive
Me personally, I'm not saying it is good nor bad. Here is a post from another forum regarding the CRJ- 200 specifically. Keep in mind these complaints were not toward the CRJ 700 or 900.
"Why do I have to trick the bleeds into switching properly? One button half a second too soon? Everything is fucked. Deadheading in a window seat? Too bad there's a fucking wall where your feet go. Need anti-ice in a descent? That fucking sucks, the thing only has enough power to get the anti-ice to come on at goddamn 75% thrust. Descending with power in and spoilers out. Fucking brilliant. Put blowers in the thing so maybe everyone won't die when you shut the packs off to start an engine in PHX in July? Naw, @#$! that. Don't worry though, once the engine starts are complete, the cabin will cool down. Around the time you get to FL330, which will take around 2 hours because you had to level off at 230,250,270,290 and 310 to take a running start at the next altitude. And that's if you were one of the lucky bastards that actually had a working APU, even though that pile of shit didn't do half of anything anyway. You'd see people with their fucking lips on the gaspers trying to suck out whatever "fresh" air they could because the APU puts out air like an asthmatic breathing through a straw. Also, thanks, bumble-fucks at bombardier for not giving the thing slats. I just love 170kt GS approaches into Denver in the summer. Good fucking thing there's 12000' of runway, because once I flare from this stupid lawn dart 5 degree down approach angle, there's a pretty good chance I'm floating forever. Sure hope there isn't too much of a crosswind. Nothing says stability like main wheels that are 6 feet apart from each other. Taking off is a grand old time too. Flaps 8? Have fun with your 147kt vr speed in a plane you have to start flying at 50kts or the wind will pick up a wing and you'll wing strike the downwind wing that's only 3 feet off the ground anyway.
God I hate that thing."
Re: the best drive
Pigboat flying aka CV14/ PBY-5A, yanking that fucker off a lake with 7000lbs of water sloshing around. I won't mention manual gear lowering, you have to do one at a time, manual stow of the dump doors, same thing both individually. If you have to do gear and dump doors same time, well it certainly isn't your day. Standing still water take off is an adventure forcing the old beast on the step takes quite a forward tug, wing floats are down of course, you would be surprised with amount of drag with them dropped. Get them up pronto as soon as you know you ain't going back on the water. Thank Christ wing floats are electric stow, war time beasts had to be cranked up and down in the coning tower, actually it was the flight engineer position. plenty of other fun stuff with it but won't bore ya.
PS. Thread is airline orientated , however my interest was twigged.
Re: the best drive
The crj 100/200 were bad. They basically had stretched the 600 series and didn't bother changing anything up front. BBR got it right with the 700/900, slats and a redesigned wing. To.o bad they didn't change the wing on the 200 but, they froze the design. So no new changes
Re: the best drive
Metro 2: Cousin Vinny's $500 15 year old Honda Civic with mismatching panels and doors, but with a $600 growler exhaust and a $1000 subwoofer
Metro 3: The same, but on a Honda Accord.
Re: the best drive
Edited
Re: the best drive
Baby Caravan on Wip 8000 straight floats with a -12 Garret on the nose.
Re: the best drive
The Cheyenne II, that thing was the same gross as a Chieftain but twice the horsies. Climbed like a homesick angel, always said if I won a lottery where I could afford my own, I would get a super Cheyenne, same fuselage, bigger tanks and -135a instead of the -28. Had to be derated for takeoff or it would flip over on its back but in cruise you had it all, the super upgrade also included EFIS if I remember correctly.
Re: the best drive
I mean... if you're going Cheynne and like to climb.... how about the 400LS... -16 Garrets instead of those cute little Pratts. The thing still holds the record for time to climb (to 410!!!!) and speed in turbo props...cdnavater wrote: ↑Fri Dec 08, 2023 9:53 am The Cheyenne II, that thing was the same gross as a Chieftain but twice the horsies. Climbed like a homesick angel, always said if I won a lottery where I could afford my own, I would get a super Cheyenne, same fuselage, bigger tanks and -135a instead of the -28. Had to be derated for takeoff or it would flip over on its back but in cruise you had it all, the super upgrade also included EFIS if I remember correctly.
- CL-Skadoo!
Re: the best drive
Gravel protected 737-200 with -17 or better yet, -17A engines. The sound alone is a crowd pleaser and lets the wife know to get rid of her boyfriend before you can get home.
Takeoff from a gravel strip somewhere north of 60, land at a major airport in the south on the same day. A joy to hand fly, best seat of the pants feeling of any aircraft, jet or otherwise, I have ever flown.
Re: the best drive
I didn’t fly a 400ls but I didn’t like the T-Tail and composite props, I also don’t know enough about the short field performance and fuel consumption. Not to mention FL410 introduces some other issues like single pilot oxygen masks and RVSM.porcsord wrote: ↑Fri Dec 08, 2023 10:31 amI mean... if you're going Cheynne and like to climb.... how about the 400LS... -16 Garrets instead of those cute little Pratts. The thing still holds the record for time to climb (to 410!!!!) and speed in turbo props...cdnavater wrote: ↑Fri Dec 08, 2023 9:53 am The Cheyenne II, that thing was the same gross as a Chieftain but twice the horsies. Climbed like a homesick angel, always said if I won a lottery where I could afford my own, I would get a super Cheyenne, same fuselage, bigger tanks and -135a instead of the -28. Had to be derated for takeoff or it would flip over on its back but in cruise you had it all, the super upgrade also included EFIS if I remember correctly.
The Cheyenne II was happy at 270, I think 250 was the best true airspeed, it’s been a while though, over 20 years since I’ve flown one. Could be I might not like it anymore, I remember the flight deck being tight but a hell of a short field performance
Re: the best drive
My back cringes thinking about loading 1 45 gal drum let alone the 20 in a Basler. Hahah, nope you can have that one, I’m a delicate flower.
Re: the best drive
My 170B ... It means I'm on a day off.
Re: the best drive
Me too
But there is a “niche” with none of that crap (Survey Ops)
Re: the best drive
I’ll split the difference, and say turbine otter. Beats the beaver in performance when heavy, and much more comfortable.
I’ll say that if I had twin otter time, I bet I’d feel that’s the ultimate machine…
- oldncold
Re: the best drive
Pc12. Land n stop in 800ft only 1800 takeoff. 25 min later fly level 250 doing 250 knots alterate not a issue with 2700 lbs fuel and sippin. 320 lbs. Hour
My fav memory. Landing at night in greize fjord (cygz )1600ft one way in recip on departure. the leadin lights are curved and on peoples homes the airport cars operator turns them on ,the actual runway lights are arcal. temp -44c in jan stayn at the coop hotel a pound of hamburger it costs 26 probably 40 today . refueled n back next morn to yfb 4hrs lovd flyn that bird.
Re: the best drive
Always wanted to fly into Grise Fjord. That’s so coololdncold wrote: ↑Thu Dec 21, 2023 7:37 pm Pc12. Land n stop in 800ft only 1800 takeoff. 25 min later fly level 250 doing 250 knots alterate not a issue with 2700 lbs fuel and sippin. 320 lbs. Hour
- rookiepilot
