Sunwing/Westjet
Discuss topics related to Sunwing.
Canadaflyer46
Re: Sunwing/Westjet
Post by Canadaflyer46 »
nohojob wrote: Fri May 17, 2024 12:12 pm
Canadaflyer46 wrote: Fri May 17, 2024 11:55 am YWG is the quickest upgrade right now.
Here’s some quick numbers taken from the most recent ALPA department list for WJ.
MOST JUNIOR:
Yyc CA block holder: 16 years
Yyc CA: 11 years
YWG CA block holder: 12 years
Ywg CA: 10 years
787 CA block holder: 23 years
787 CA: 22 years
787 FO block holder: 10 years
787 FO: 9 years
What about yyz?
YZ CA block holder: 10 years
YYZ CA: 11 years
YVR CA block holder: 15 years
YVR CA: 12 years
YEG CA block holder: 11.5 years
YEG CA: 11 years
Upgradeable
Re: Sunwing/Westjet
Post by Upgradeable »
:rolleyes:
cdnavater
Re: Sunwing/Westjet
Post by cdnavater »
JBI wrote: Fri May 17, 2024 11:47 am
twa22 wrote: Fri May 17, 2024 10:33 am
CXALE wrote: Fri May 17, 2024 9:08 am Jokes apart, for 737 YYC Captain 16 years is correct :shock:
So from what I've read in the past, it's something like 15 years to hold CA in YYC, and and once you can hold CA, it's another 16 years on reserve? That means if someone joins WJ at 30 years old, they'll hold left seat at 45,and be on reserve until 61?
If true, that's looney tunes, who in their right mind would go left seat to be on reserve for the rest of their career... I hope I'm just understanding it wrong :rolleyes:
Well, WestJet has only been around for 28 years, so if someone has been here for 31 years, there's probably some sort of misunderstanding...
Pretty sure the poster was referring to the future, someone joining at 30 today, after 15 years can hold the left seat and then another 15-16 to hold a block.
Clearly misunderstanding the situation though, as I understand it, the 15 year YVR Captain block holder is 15 years with the company, not 15 years in the left seat.
JBI
Re: Sunwing/Westjet
Post by JBI »
cdnavater wrote: Fri May 17, 2024 3:34 pm
Ah, I may have misunderstood the misunderstanding.
For the OP and others who look to this board for info: Canadaflyer46 has listed what the current upgrade times have been at the moment. It's important to remember that this is a snapshot of what things are right now, and NOT a guide for what those hired today will encounter.
My educated guess is that the average upgrade times for those on property will continue to increase for the next couple of years, but then start decreasing again. Now, how much they decrease will depend on a number of factors which are too difficult to predict.
I've found a lot of people don't quite understand the concept of upgrade times. This isn't aimed at anyone in particular, just for general info. Pilots ONLY upgrade if there are Captain vacancies. These only occur if either a: there is growth (more airplanes, or higher utilization) or b: Captains leave (either retire or quit/are terminated etc.). Right at this moment, WestJet just does not have a lot of either a or b.
There has been a small amount of growth, but the reality is that with cancelling 3 of the 787 orders and the 737 Max delays, WestJet isn't getting significantly larger at the moment. There are orders on the books and it appears that WestJet is likely purchasing 4 to 6 of Lynx's 737s, but those 42 Max 10s that were supposed to start arriving in 2025 are likely still a few years out.
Unlike Air Canada, which had hundreds of pilots reaching age 65 in the last few years, WestJet has barely had any. That makes sense considering WestJet only started in 1996 and most of those hired in the first 10 years were in their 20s and 30s, they simply haven't reached retirement age yet. The first large cohort will start hitting 65 in the next 5-10 years. So we will see an uptick in retirements.
The other issue is that right now WestJet does NOT have a mandatory retirement age. This is a political hot topic which I don't wish to dive into, but from a human rights law perspective, the status quo isn't sustainable. While the Company can, and does, make individual schedules for the smaller number of pilots over 65 so that they only fly in Canada, more and more pilots reaching 65 will mean that making them schedules constitutes an "undue hardship" such that the Company can't accommodate so many.
The merger itself will play a role in upgrade times as well. Historically, mergers tend to slow movement down for short period of time leading up to the merger and a short period of time directly after the merger. However, once the merger process is completed, the new merged company starts seeing more growth.
While I'm hardly an eternal optimist, I can see all these 3 factors aligning nicely in a few years resulting in some pretty solid movement and upgrades. So, expect average upgrade times to increase, but then I expect it to drop once these 3 factors are settled.
To be clear, I do not expect to see it drop to the recent upgrade times at Air Canada. It's important to note that the vast majority of the new upgrades at AC are on Narrowbody, low seniority positions. They will be on reserve for quite some time (generally much longer than the time new WJ Captains will be on reserve - though yes, there are always exceptions). What you do see at Air Canada is more senior pilots bidding for, or staying on, widebody FO positions as the pay and schedule can be better than Narrowbody Captain positions. At WJ, senior 787 FOs do make more than 737 FOs, but don't make more than 737 Captains.
Zanzibar
Re: Sunwing/Westjet
Post by Zanzibar »
Does sw have many captains junior to wja averages or very few?
Handover
Re: Sunwing/Westjet
Post by Handover »
Zanzibar wrote: Sat May 18, 2024 3:34 pm Does sw have many captains junior to wja averages or very few?
Captains Hire Dates
Summary Statistics
1. Number of Employees
- Total Employees: 517
2. Tenure Statistics (in years)
- Mean Tenure: 7.23 years
- Standard Deviation: 5.68 years
- Minimum Tenure: 0.44 years
- 25th Percentile: 1.63 years
- Median (50th Percentile): 6.74 years
- 75th Percentile: 11.11 years
- Maximum Tenure: 19.56 years
3. Counts by Base
- YYZ: 244 employees
- YUL: 112 employees
- YVR: 64 employees
- YQB: 50 employees
- YYC: 47 employees
4. Counts by Position
- First Officer (FO): 270 employees
- Captain (CA): 247 employees
5. Counts by Hire Year
- 2004: 1 employee
- 2005: 11 employees
- 2006: 20 employees
- 2007: 30 employees
- 2008: 25 employees
- 2011: 6 employees
- 2012: 12 employees
- 2013: 35 employees
- 2014: 17 employees
- 2015: 29 employees
- 2016: 52 employees
- 2017: 42 employees
- 2018: 28 employees
- 2019: 26 employees
- 2020: 2 employees
- 2022: 81 employees
- 2023: 100 employees
Captain Statistics
- Total Captains: 247
- Average Year of Hire for Captains: Approximately 2012
- Average Hiring Rate: 16.47 hires/year
- Peak Hiring Year: 2016 with 33 captains hired
- Notable Hiring Years: 2013: 30 hires, 2007: 28 hires
- Percentage of Total Captains Hired in Peak Year: 2016: 13.36%
- Cumulative Percentage of Captains by 2016: By the end of 2016, 83.81% of the total captains were hired.
- Hiring Decline Post-2018: Minimal hires in 2019 (2 hires) and 2022 (3 hires)
- Distribution Over Time: The majority of captains were hired between 2006 and 2017, accounting for approximately 80% of the total captains.
twa22
Re: Sunwing/Westjet
Post by twa22 »
Yea that makes more sense now, thanks
Zanzibar
Re: Sunwing/Westjet
Post by Zanzibar »
Sounds like very few downgrades if date of hire is used for integration. That’s a good thing.
ads-b
Re: Sunwing/Westjet
Post by ads-b »
Looks like 99 downgrades out of 247 if DOH used. I’d argue that’s a significant number.
Zanzibar
Re: Sunwing/Westjet
Post by Zanzibar »
I’d assume they would keep pay like swoop did till wage catches up
pacman007
Re: Sunwing/Westjet
Post by pacman007 »
ads-b wrote: Mon May 20, 2024 1:17 pm Looks like 99 downgrades out of 247 if DOH used. I’d argue that’s a significant number.
Would that mean 99 upgrades for WestJet? I would agree that’s a significant number.
nohojob
Re: Sunwing/Westjet
Post by nohojob »
Retraining about 200 pilots who don't need to be trained would also come with a significant cost.
cdnavater
Re: Sunwing/Westjet
Post by cdnavater »
nohojob wrote: Tue May 21, 2024 12:16 am Retraining about 200 pilots who don't need to be trained would also come with a significant cost.
Not the unions problem, both sides will be fighting for their respective pilots and when the dust settles the costs will be the companies to bear. It is not the pilots fault the company purchased another company but you can bet on one thing, WJ pilots will fight tooth and nail to make sure there are no left seat out of seniority, guaranteed.
Precedent was set with the Swoop integration, an arbitrator will have to consider that.
ant_321
Re: Sunwing/Westjet
Post by ant_321 »
cdnavater wrote: Tue May 21, 2024 7:10 am
I’m not looking to debate a Jazz pilot on a westjet/Sunwing issue but, there has been no precedent set with the Swoop integration. Merging pilots working for the same company, represented by the same MEC is wildly different than two separate airlines merging.
nohojob
Re: Sunwing/Westjet
Post by nohojob »
ant_321 wrote: Tue May 21, 2024 8:00 am
Definitely
cdnavater
Re: Sunwing/Westjet
Post by cdnavater »
I’ll try not to be offended but this Jazz pilot has been in this business since 1990, I’m pretty sure I have a grasp on how things work.
For example, Swoop was a separate company with a separate seniority list, it was one of the biggest demands by WJ pilots, read huge bargaining capital used for that.
The fact the pilots were on the same bargaining unit played a part, guess who else will soon be in the same bargaining unit in a separate company, I’ll give you some time to ponder that.
One absolute truth, we won’t know until the dust settles how this will go but again, if you think WJ pilots will settle for anything less than seniority for the left seat, well, I don’t know what to tell you other than you’re in for a bit of a surprise then!
Good luck
Canadaflyer46
Re: Sunwing/Westjet
cdnavater wrote: Tue May 21, 2024 5:21 pm
Good luck
I agree. WJ has the longest narrowbody upgrades in North America if not the planet. I don't think any arbitrator will let everyone keep their left seat just because. I do think that a reasonable arbitrator will be fair though, and allow anyone downgraded to have their current captain pay "red-circled" until their pay at WJ catches up. That's how it was done when the Swoop pilots came over.
BigQ
Re: Sunwing/Westjet
Post by BigQ »
Also, consider that many junior captains at WG are YUL/YQB based. Many won't bump down and elect to stay senior YYC FO instead.
Zanzibar
Re: Sunwing/Westjet
Post by Zanzibar »
I’m also hearing that the merged airline will be overstaffed.
boeingboy
Re: Sunwing/Westjet
Post by boeingboy »
Zanzibar wrote: Wed May 22, 2024 5:20 pm I’m also hearing that the merged airline will be overstaffed.
I don't know how that's possible.....unless Westjet is heavily overstaffed, but everything I've heard says they love efficiency - so it cant be that bad.
Zanzibar
Re: Sunwing/Westjet
Post by Zanzibar »
I hear sunwing has double the pilots that their aircraft require? Max deliveries in question etc…
MaxAuto
Re: Sunwing/Westjet
Post by MaxAuto »
It might be overstaffed with old rest rules, but not the new on. Sunwing hired in anticipation of a busy winter season and pilots leaving to go to Air Canada which they are. By time this merge is all said and done, I anticipate 50 to 60 pilots will be gone to AC. Sunwing will not be hiring. If they do it will be little. West jet will eventually reduce hiring to absorb the Sunwing pilots and it will all balance out. Airlines have learned their lessons on being understaffed. Canceling flights because you can't crew them leads to fines and bad PR.
Their will be no furloughs because the competition bureau approved this purchase on the promised no one loses their jobs.
Delayed MAX deliveries will result in keeping older aircraft longer and differing MAX 10s to 8s as Alex discussed and sourcing used Max's.
boeingboy
Re: Sunwing/Westjet
Post by boeingboy »
Zanzibar wrote: Fri May 24, 2024 10:23 am I hear sunwing has double the pilots that their aircraft require? Max deliveries in question etc…
It's more complicated than that - you need to understand the business model. We are certainly not overstaffed for the winter season. This was a major reason we had TFW's in the winter to keep staffing reasonable....but that creates separate arguments. Are we overstaffed for Summer - yes, however - in the original plans we were going to be kept at 40 or so airplanes year round by doing some of the Westjet summer vacation stuff.
I'm sure Westjet will figure it out eventually to keep everyone working in the summer - but they now have obligations to Sunwing to maintain and expand the winter scheduals....so there will be no overstaffing. There are aircraft shortages though - which they are trying to resolve.
Sunwing has no Max aircraft - or any other aircraft deliveries pending. The delays are on the Westjet side.
phenix
Re: Sunwing/Westjet
Post by phenix »
boeingboy wrote: Fri May 24, 2024 12:12 pm It's more complicated than that - you need to understand the business model. We are certainly not overstaffed for the winter season. This was a major reason we had TFW's in the winter to keep staffing reasonable....but that creates separate arguments. Are we overstaffed for Summer - yes, however - in the original plans we were going to be kept at 40 or so airplanes year round by doing some of the Westjet summer vacation stuff.
Westjet summer vacations stuff looks like a bunch of red eyes
Oleo 4
Re: Sunwing/Westjet
Post by Oleo 4 »
Respectfully what was initially told to the Sunwing team when the initial announcements were made by SH have been proven to be misleading. Not to get into a debate on those details on a public forum and air dirty laundry. The pilots at both merging companies will have to concede that the structure and business model of what is becoming requires change and adaptation on all parties involved. The tails will be painted a single colour and what is going to have to stop is the Us vs. Them mentality.
The merger committees will sort out the roster, the X-Comm will sort out the business model and strategic positioning. The tails coming to the fleet are known, and both models will shift slightly to make a stronger single company. I look forward to flying with all Sunwing pilots without a colour attached to your name and I hope in return you can do the same. Debating what was, and is to become on this forum or any of the private chats is futile. Emotions are high with the fear of the unknown, fear causes anxiety, and anxiety causes irrational actions at times. Our limbic brains (lizard brain) employ a fight or flight response when startled or challenged. Lets let this process unfold rationally for now and the committees to do the work.
The one constant so far in my airline career has been change, whether external economic or market pressures challenged us, internal growth, reorganization, or a global pandemic. A quote from William S. Burroughs: When we stop growing, we start dying. Lets see what happens with growth as this is still a better conversation than we had in March 2020.
O
Return to “Sunwing”
