What happened to 122.75?
Post by ahramin »
Am I on glue? Isn't the air to air frequency 122.75 anymore?
Loon-A-Tic
Re: What happened to 122.75?
Post by Loon-A-Tic »
Not sure, who remembers "go standard"
Heliian
Post by Heliian »
126.7
I'm a helicopter!
valleyboy
Post by valleyboy »
air to air chit chat was usually 123.45
http://www.blackair.ca
Loon-A-Tic
Nowadays it seems to be all on "guard", its time for some educating
NotDirty!
Post by NotDirty! »
I found it somewhere in between 122.72 and 122.77. But I don’t have 8.33 kHz spacing, so YMMV
DH82EH
Post by DH82EH »
122.75 is Apron frequency at YYZ
123.45 is air to air chit chat
Kaykay
Post by Kaykay »
DH82EH wrote: ↑Tue Apr 07, 2020 6:59 pm 122.75 is Apron frequency at YYZ
I don’t think that’s right...every chart I’m looking at says 122.275 and 122.075 and I’ve never been on 122.75 there.
Go guns: 130.30
Go Canada: 118.67
Cheap suit: 129.95
Go company: What’s company?
Schooner69A
Post by Schooner69A »
Back in the UHF days in Europe, if an aircraft came up along side of you and made motions like "chambering a round" in a lever action rifle or the Lead said "Go Winchester", you dialed in 303.0
:D
CpnCrunch
Post by CpnCrunch »
ahramin wrote: ↑Tue Apr 07, 2020 5:08 pm Am I on glue? Isn't the air to air frequency 122.75 anymore?
It is and always has been, but since when has any pilot actually bothered to RTFM? See this thread for example.
Post by ahramin »
CpnCrunch wrote: ↑Tue Apr 07, 2020 9:10 pm
Exactly, my problem is I can't find it in the manual anymore. Can you?
I thought 122.75 is VFR air to air. IFR was 123.45
AR705
Post by AR705 »
I always thought that 122.75 was air to air in Canada. Have had other pilots look at my strangely though when I suggested it!
Did some looking b/c couldn't recall where I've seen that... For one, check out Nav Canada's RCO Brochure:
https://www.navcanada.ca/EN/products-an ... ure-EN.pdf
Says: "Any pilot-to-pilot communications not for this purpose should be conducted on 122.75 MHz (within the Canadian Southern Domestic Airspace) or 123.45 MHz (within the Northern Domestic Airspace and the North Atlantic)."
"This purpose" being reference to 126.7 position reports etc... Good enough for me!
NotDirty!
Post by NotDirty! »
Kaykay wrote: ↑Tue Apr 07, 2020 8:13 pm
Don’t forget 122.87 for apron coordinator....
Aviatard
Post by Aviatard »
AIP Canada (ICAO) GEN 3.4.3.2:
For air-to-air communications between pilots within Canadian Southern Domestic Airspace (SDA), the correct
frequency to use is 122.75 MHz; in the Northern Domestic Airspace (NDA) and the NAT, the frequency
allocated by ICAO is 123.45 MHz.
https://www.navcanada.ca/EN/products-an ... en_eng.pdf
Heliian
Post by Heliian »
A further expansion:
Air traffic service (ATS) frequencies are published in the Canada Flight Supplement (CFS), in the Canada Air
Pilot (CAP), and on aeronautical charts.
Frequency 123.4 MHz is allocated for the use of soaring activities, which include balloons, gliders, sailplanes,
ultralights and hang gliders. The use of this frequency for these activities includes air-to-air, air-to-ground
instructional and air-to-ground aerodrome traffic communications; the use of this frequency as an aerodrome
traffic frequency (ATF) is normally restricted to privately operated aerodromes used primarily for these
activities.
CpnCrunch
Post by CpnCrunch »
Yep, still in the cap gen as mentioned above. If you google "122.75 site:navcanada.ca" it's the 2nd result.
DH82EH
Post by DH82EH »
My mistake. Thanks for the correction.
Kaykay
Post by Kaykay »
NotDirty! wrote: ↑Tue Apr 07, 2020 11:35 pm
Oh yes yes. Must not forget to call fully ready.
20DMEYYZ
Post by 20DMEYYZ »
iflyforpie wrote: ↑Tue Apr 07, 2020 8:27 pm Go guns: 130.30
Go Canada: 118.67
Cheap suit: 129.95
Gooo cheaper suit: 119.95
"Go college" @ Confed
elainemorrison
Post by elainemorrison »
122.75 is the FCC (FAA) air to air communication frequency for private fixed wing aircraft, per 4-1-11 FAA AIM. There may be a local phenomenon of non-use, however, with aircraft preferring to monitor the closest airport frequency, or use an ADS-B aircraft radar system via an app instead (some are by subscription with an antenna, and there may be others which connect to the transponder wirelessly). Any information on a radar system would be helpful to me. Of course, Americans also use flight following for trips, so there is another option.
CaptDukeNukem
Post by CaptDukeNukem »
elainemorrison wrote: ↑Fri Jun 21, 2024 6:13 pm 122.75 is the FCC (FAA) air to air communication frequency for private fixed wing aircraft, per 4-1-11 FAA AIM. There may be a local phenomenon of non-use, however, with aircraft preferring to monitor the closest airport frequency, or use an ADS-B aircraft radar system via an app instead (some are by subscription with an antenna, and there may be others which connect to the transponder wirelessly). Any information on a radar system would be helpful to me. Of course, Americans also use flight following for trips, so there is another option.
You must have been really bored to revive a 4 year old thread. There’s a hockey game on.
elainemorrison
Thanks for your concern. I was googling the frequency apparently no one uses to see if it was paralleled perhaps somewhere nearby. We had no idea who was transmitting today and assumed it was Canada.
CaptDukeNukem
It’s used in certain practice areas.
