Joe, I just realized I may have misunderstood, did you mean 100k extra over the first 4 years? That’s basically what I did when I took 30/hr off new captain pay and applied to new FO pay, if that makes the difference between buying a house or not you’re not managing your money properly.Joeschumer wrote: ↑Tue Sep 17, 2024 6:06 pm I don’t think you are understanding that today’s money is worth more than tomorrows. The earnings in year 1,2,3,4… , these days are usually pilots between 25-35 years old most likely with debt to pay off. These are often critical years in a persons life to settle down, but a house and start a family. Let’s say in one proposal a pilot would make 100k more the first 4 years of employment. This 100k could be the difference between being out of debt, qualifying for a mortgage to buy a house and starting their investments early OR none of the above without that 100k. Who cares if 12 years down the line you may potentially have acquired “more” money if 100k in 12 years is worth 30k less anyways and it probably won’t even be more actual net worth to you because you would have lacked an early start on investments.
By having the means to start investing and owning property early in your life is the real goal everybody seems to have forgotten about.
cdnavater wrote: ↑Tue Sep 17, 2024 5:13 pmIt might be you that failed 3rd grade math, you might want to give it a little think!khedrei wrote: ↑Tue Sep 17, 2024 3:36 pm
Math may not be my best subject, but clearly you didn't finish 3rd grade math if you can't figure this one out.
A 20k raise on today's salaries working up to a 100k raise on today's salaries is the same thing as a 60k raise working up to a 60k raise. In fact, the 60k today is more valuable than the 100k in 12 years as has been discussed previously. Not sure why this is hard to understand.
I'm not advocating for taking away from current captain salaries. I'm advocating for giving the FOs the same amount of raise. Which just means not giving them as BIG of a raise.
To simplify it for you, I made very simple assumptions, I took 30/hr off NB Captain rates and added 30/hr to FO rates, I compounded both at 2% per year after the end of the new scale, first 4 years as NB FO, then NB CA for the remainder of the 12 year scale, compounding is your friend, current(proposed) top scale narrowbody at just 2% per year would be 403.14/hr in 12 years or 367.29 under your take from the top and give to the bottom proposal.
For the pilot starting today at the new scale, upgrading to narrowbody Captain after 4 years(reasonable) they would earn 3,029,326 at 900 hours per year, same pilot under your proposal, same assumption of upgrading after 4 years would make 2,896,147 after 12 years, the gap only gets worse from there.
You will spend many more years on the top scale, you hit that at 12 years and then the rest of your 30-35 year career at that scale, adding 30k to the bottom couple years doesn’t translate into more lifetime earnings, you spend 10% of your career there
I understand today’s money is worth more but in my assumptions, I factored 2% per year, over 12 years, so this is assuming next negotiations has nothing but a 2% increase to the new rates, kind of a worse case scenario. 12 years from now the captain top scale 403 vs 367, you also clearly missed the part where if you earn that extra 100k in the first year, after 12 years you are 134,000 less in total earnings, so think of it as interest on your delayed earnings. Without any increase, no compounding, the next 10 years you’ll earn 4 million or 3.6, so your 100k now cost you 400k later, better be a damn good investor to make up that difference!
