Fall Ground School?
Fall Ground School?
Are there Fall GS classes for Encore? Did anyone get any offer? Been in the pool from so long and not sure if I should wait or look for other opportunities.
Cheeseburger
Re: Fall Ground School?
I’ve been told that a fall ground is in order. However , I have heard nothing yet either. If you’re an unemployed pilot , it is always best to be looking for other opportunities. Just because you’re in the pool does not mean you will get an offer this time around.
I’ve been swimming since February. How long have you been in the pool?
I have been in pool since April end and have currently around 1500 hours
Cheeseburger wrote: ↑Tue Aug 06, 2024 12:36 pmI’ve been told that a fall ground is in order. However , I have heard nothing yet either. If you’re an unemployed pilot , it is always best to be looking for other opportunities. Just because you’re in the pool does not mean you will get an offer this time around.
CaptDukeNukem
I once applied for a Navajo position in northern Ontario that required 4500 hours TT. But I’m just dating myself now.
Good luck on your endeavors.
What does it mean to be in the pool?
After the virtual interview or before?
Any past experience here for how long between virtual interview and offer or GS date to stop looking for a job??
That you were successful in the interview portion and are waiting for a spot. When a spot comes available the most competitive on the list are offered it.
Past experience won't mean anything as conditions have changed and it is dependent on how competitive you are. They've ran like 1(?) class since the spring, the pool will be large now.
It’s very competitive recently. My colleague who is a high time experienced king air trading captain hasn’t received an offer so far.Vsquared wrote: ↑Wed Oct 02, 2024 10:25 amThat you were successful in the interview portion and are waiting for a spot. When a spot comes available the most competitive on the list are offered it.
[/quote]
Have Pratts - Will Travel
dontcallmeshirley
Encore doesn't need first officers because it's the captains that are leaving in droves.
So I submitted the virtual interview and it says screening in progress. Is it a long wait after that? when is next ground school?
CaptDukeNukem
Next step should be fairly quick. I imagine you’ll hear back in less than a week or two.
Cheeseburger
They contacted me within about a week for an interview . I then had a second interview a couple of weeks later. I was placed in the pool about one month after initial contact.
I’ve been swimming for about 8 months. I’d like to believe that it’s mostly due to the fact that they haven’t ran any ground schools.
The last email I received they extended my application to stay in the pool. They also mentioned they won’t be running any ground schools until 2025.
Too many FO’s, not enough captains was mentioned in the email.
Good luck!
Encore needs to hire applicants who are upgradable in fairly quick timeframe. Sounds like poor planning to end ip with too many FOs.dontcallmeshirley wrote: ↑Thu Oct 03, 2024 9:04 am Encore doesn't need first officers because it's the captains that are leaving in droves.
CaptDukeNukem
Encore needs to hire anyone with a pulse if they want to continue operations.KN84 wrote: ↑Fri Oct 04, 2024 1:36 pmEncore needs to hire applicants who are upgradable in fairly quick timeframe. Sounds like poor planning to end ip with too many FOs.dontcallmeshirley wrote: ↑Thu Oct 03, 2024 9:04 am Encore doesn't need first officers because it's the captains that are leaving in droves.
Especially king air captainsCaptDukeNukem wrote: ↑Sat Oct 05, 2024 6:51 amEncore needs to hire anyone with a pulse if they want to continue operations.KN84 wrote: ↑Fri Oct 04, 2024 1:36 pmEncore needs to hire applicants who are upgradable in fairly quick timeframe. Sounds like poor planning to end ip with too many FOs.dontcallmeshirley wrote: ↑Thu Oct 03, 2024 9:04 am Encore doesn't need first officers because it's the captains that are leaving in droves.
CaptDukeNukem
Yes exactly. The ones with 6000+ TTMe262 wrote: ↑Sun Oct 06, 2024 9:04 pmEspecially king air captainsCaptDukeNukem wrote: ↑Sat Oct 05, 2024 6:51 amEncore needs to hire anyone with a pulse if they want to continue operations.
7000 with inflationCaptDukeNukem wrote: ↑Mon Oct 07, 2024 2:55 amYes exactly. The ones with 6000+ TTMe262 wrote: ↑Sun Oct 06, 2024 9:04 pmEspecially king air captainsCaptDukeNukem wrote: ↑Sat Oct 05, 2024 6:51 am
