IFR from a Class E without a PAL or FSS
172DDriver
Flying from a class E zone on an IFR flight plan, This zone doesn't have a PAL to call center for clearance nor FSS but has an RCO with Edmonton FIC. I know I can get an IFR clearance relayed from FIC. My question is can I depart VFR without getting my clearance and grab the clearance in the air from centre, or since I filed IFR would I have to get a VFR departure clearance relayed? The airport in question CYQW
PostmasterGeneral
Re: IFR from a Class E without a PAL or FSS
Depart VFR or phone the fic and get your clearance.
You can depart and pick up your IFR clearance in the air.172DDriver wrote: ↑Sun Nov 26, 2023 9:52 pm Flying from a class E zone on an IFR flight plan, This zone doesn't have a PAL to call center for clearance nor FSS but has an RCO with Edmonton FIC. I know I can get an IFR clearance relayed from FIC. My question is can I depart VFR without getting my clearance and grab the clearance in the air from centre, or since I filed IFR would I have to get a VFR departure clearance relayed? The airport in question CYQW
inousspeckled
Yes, you can depart VFR without your IFR clearance if conditions allow, then pick it up from Edmonton Centre in the air. A specific "VFR departure clearance" isn’t required.
