Floats sealant
tazin river
Floats sealant
Post by tazin river »
Afternoon folks
What the best stuff you use to seal minor leaks on floats? Mostly
Along rivets.
Pacqing
Re: Floats sealant
Post by Pacqing »
Are there no float operators on here? Have you tried PRC?
MUSICMAAN
Re: Floats sealant
Post by MUSICMAAN »
Sikaflex or PRC
BGH
Re: Floats sealant
Post by BGH »
I used sikkaflex 292,usually found at boat service centers.
Cleaned area with brake clean,let it dry & then apply sealant.
Daryl
sunk
Re: Floats sealant
Post by sunk »
Call Goulet aircraft supply at Winnipeg. They sell a sloshing compound that seeps between the seams. Sixaflex works great on the outside seams as well.
Return to “Maintenance”
