Floatplane Crash Thread
FishermanIvan
Re: Floatplane Crash Thread
Post by FishermanIvan »
pelmet wrote: Tue Aug 12, 2025 4:14 pm Any suggestions on how this might have happened and what could be done to prevent it....
C-GCWO, a float-equipped Cessna 185F operated by Gogal Air Services Ltd., was conducting a flight from Snow Lake Water Aerodrome (CKM5), MB, to Lac du Bonnet (North) Water Aerodrome (CJS9), MB. The aircraft landed safely at CJS9 and began taxiing to the dock. After approximately 400 meters into the taxi, the right front float began to dig in under the waves and, shortly after, the left front float followed. The aircraft then slowly nosed over and sank becoming inverted with the floats keeping it afloat. The pilot, wearing his undeployed inflatable personal flotation device, was able to open the door and get out of the aircraft with no injuries. The aircraft was flipped back onto the floats and removed from the water in the following days by a contract maintenance facility. Upon inspection, it was noted that there was no structural damage to the aircraft.
....from tsb.
I’d assume the floats were full of water and weren’t pumped out at the start of the day, so they eventually stopped floating.
phillyfan
Post by phillyfan »
Not nearly enough info. I would not even pretend to guess.
From TSB...
C-GTMW, a privately-registered De Havilland Aircraft of Canada DHC-3T (Turbo Otter) airplane,
equipped with amphibious floats, was conducting a local flight under visual flight rules from
Harrison Hot Springs (CAE7), BC with 1 pilot and 6 passengers on board. After starting the engine,
the rope that had been securing the aircraft to the dock detached. The airplane then moved
forward. The pilot feathered the propeller and shut down the engine and, as the engine and
propeller were slowing, the aircraft struck a boat that was parked at the dock. The 1 person on
board the boat sustained minor injuries; all occupants on board the aircraft were uninjured. The
boat and aircraft sustained minor damage.
Not sure if something gave way or if it was a poorly tied rope.
7ECA
Post by 7ECA »
pelmet wrote: Wed Aug 13, 2025 4:49 pm Not sure if something gave way or if it was a poorly tied rope.
It's a PT-6'd Turbo Otter, why anyone would start it out of BETA or feather is beyond me... for this exact f'ing reason. There's also reverse, for situations in which you've begun moving forward when you don't want to be, but I suspect the report may be generous in its timeline - as in the PT-6 hadn't fully spooled up before things went sideways.
The other question that boggles the mind, is why many Otter floggers want to start up with only one rope in place. Too many turbine floatplanes have come to grief at the docks when ropes slip or break.
7ECA wrote: Wed Aug 13, 2025 10:28 pm
Is there a higher risk of rope slip/break for a turbine version of a floatplane versus a piston version?
TeePeeCreeper
Post by TeePeeCreeper »
pelmet wrote: Thu Aug 14, 2025 4:00 am
That’s a great question Pelmet.
I personally believe that with a good dock hand or two.. that it’s a moot point. With that said, my personal sentiment is that the piston will immediately tug on the lines tied to the dock versus a turbine (with a properly utilized pitch lock) won’t “tug” as much until commanded out of beta thus reducing the likelihood of mishaps.
TPC
TeePeeCreeper wrote: Thu Aug 14, 2025 11:46 pm
TPC
Thanks,
I guess 7ECA is simply talking about heavier aircraft being more likely to break a rope. I had not considered that as I am only flying relatively smaller floatplane types. But there is the possibility of something bigger soon.
scdriver
Post by scdriver »
If it’s in feather when you start, 2 ropes. If it’s on the latches one rope is fine. When you start it in feather it’s about 10s after completion of the start sequence before you have any prop control
enbt
Post by enbt »
In what sort of situation would you be starting any floatplane while tied to the dock, other than to warm up a piston? Is this how they do it at Harbour Air or other busy docks? I’ve spent my whole career flying floatplanes both piston and turbine and have never once started up while tied to a dock, let alone needed to debate whether it’s better to use one of two ropes.
scdriver
Post by scdriver »
enbt wrote: Sun Aug 17, 2025 10:16 am In what sort of situation would you be starting any floatplane while tied to the dock, other than to warm up a piston? Is this how they do it at Harbour Air or other busy docks? I’ve spent my whole career flying floatplanes both piston and turbine and have never once started up while tied to a dock, let alone needed to debate whether it’s better to use one of two ropes.
We start the turbines while tied up and usually back it up on the back rope to pivot out. It works well at the busy docks and usually they’re shut down in feather so pushing off before start is a no go then. Other docks on charters when it’s shut on the latches I’ll sometimes push it off and then start, but depends on wind/current and surroundings.
enbt
Post by enbt »
scdriver wrote: Sun Aug 17, 2025 11:07 am
Makes sense, thanks for that explanation. It's always interesting to see/hear how other people do things and maybe add another tool to the toolkit. I take it in that situation you would need a reliable dock person to undo the back rope once the nose is pointed out.
Sorry for the thread hijack, now back to our original programming.
Sounds like most operators don’t do this but a few do. Anyone have a video link and explanation of specifically what is happening?
Also, do any piston aircraft do this?
scdriver
Post by scdriver »
enbt wrote: Sun Aug 17, 2025 12:35 pm
Exactly, you need good dock staff or it can go wrong fast. That’s how seair went into the back of an otter a few years ago, untied while coming out of feather at the dock. Whenever I’m suspect of the dock support I make sure I’m shut on the latches.
TeePeeCreeper
Entb,
You’ve brought some great points to the discussion.
In my experience it’s always preferable to start any seaplane at the dock if able.
Since you mentioned a thread drift….
The 208 will produce almost 40 ft-pounds of thrust from the right side exhaust. No bueno when docked on the left float and facing quarterly wind conditions.
*dock hands matter*
TPC
The Hammer
Post by The Hammer »
"dock hands matter* lol
That's why they get paid the big bucks and jump on the garbage bags of empties like Gollum. "My precious....."
From TSB...
C-FJFL, an Atleo River Air Service Limited De Havilland Aircraft of Canada DHC-2 MK I (Beaver) floatplane, was conducting a flight, under visual flight rules, from Hot Springs Cove, BC, to Tofino Harbour Water Aerodrome (CAB4), BC. While landing westbound at CAB4, just prior to the intended touchdown, the left float contacted a water peak where two boat wakes had collided. The aircraft bounced and the nose yawed slightly to the left. The right float then touched down and the subsequent side load caused the right wing to dip and contact the water. When the wing tip contacted the water, it acted as a pivot point around which the floatplane spun 180 degrees. The floatplane came to an abrupt stop and remained upright. The pilot was able to then taxi to the dock. There were no injuries. The aircraft sustained substantial damage to the right wing and flap.
OneYonge
Post by OneYonge »
TeePeeCreeper wrote: Sun Aug 17, 2025 11:13 pm
Just push it out 90deg and grab the tail. Some in Ontario operate 208s and DHC3s as if there are no prop locks or reverse.
Maybe carryover from radials?
