Misc Questions
Loading...
Misc Questions
Im thinking of going to Porter on the E2. Some questions:
1. How long approximately to hold YVR
2. How is the commute from YVR?
3. What are the pairings like? A lot of single days or multi days? My intention is to do single day pairings
4. Days worked per month?
5. Pension?
5. Pension?
CaptDukeNukem
Re: Misc Questions
1) the most junior FO in YVR was hired in March. However, I believe there is room at the base if you’d like to transfer early. Good question to ask during an interview. You might be stuck on reserve for a while tho.Loading... wrote: ↑Fri Aug 15, 2025 4:49 pm Im thinking of going to Porter on the E2. Some questions:
5. Pension?
2) commute is doable but can be strenuous
3) in terms of pairings… for September, system wide about 25% of the pairings are single days. 2 days are approx 28%. 3 days are sitting at 22 ish percent. 4 days about 15% and 5 days are 10%. Most of the Vancouver pairings are multi day pairings but there are some single days. (YVR-YYZ-YVR) or (YVR-YHM-YVR)
4) we get 13 GDOs per month. If your seniority allows it, you can work much less.
5) no pension, but RRSP match starting at 4% going up to 9% over time.
Loading...
Re: Misc Questions
Thanks for the reply. Is Porter still planning on hiring a lot? Or is the wave almost overCaptDukeNukem wrote: ↑Sat Aug 16, 2025 12:57 pm1) the most junior FO in YVR was hired in March. However, I believe there is room at the base if you’d like to transfer early. Good question to ask during an interview. You might be stuck on reserve for a while tho.Loading... wrote: ↑Fri Aug 15, 2025 4:49 pm Im thinking of going to Porter on the E2. Some questions:
5. Pension?
pilotdude1326
Re: Misc Questions
Im going to assume that accommodation for training would be out of pocket since they expect you to be living/based in YYZ?
CaptDukeNukem
Re: Misc Questions
Hiring every month for the foreseeable future.Loading... wrote: ↑Sun Aug 17, 2025 10:59 amThanks for the reply. Is Porter still planning on hiring a lot? Or is the wave almost overCaptDukeNukem wrote: ↑Sat Aug 16, 2025 12:57 pm1) the most junior FO in YVR was hired in March. However, I believe there is room at the base if you’d like to transfer early. Good question to ask during an interview. You might be stuck on reserve for a while tho.Loading... wrote: ↑Fri Aug 15, 2025 4:49 pm Im thinking of going to Porter on the E2. Some questions:
5. Pension?
CaptDukeNukem
Re: Misc Questions
Ya, it sucks. Unless you get a base at hiring.pilotdude1326 wrote: ↑Sun Aug 17, 2025 1:29 pm Im going to assume that accommodation for training would be out of pocket since they expect you to be living/based in YYZ?
Some online training and sim In YUL if you get lucky.
Re: Misc Questions
Will be between 20-30 a month between both fleets till we hit around 1200 pilot. Currently sitting at about 850CaptDukeNukem wrote: ↑Sun Aug 17, 2025 7:35 pmHiring every month for the foreseeable future.Loading... wrote: ↑Sun Aug 17, 2025 10:59 amThanks for the reply. Is Porter still planning on hiring a lot? Or is the wave almost overCaptDukeNukem wrote: ↑Sat Aug 16, 2025 12:57 pm
Loading...
Re: Misc Questions
Thanks for the reply. The recruitment page of the website says they will hire over 1200 pilots over the next 4 years. So I’m guessing that’s not true anymoreflyinhigh wrote: ↑Mon Aug 18, 2025 10:04 amWill be between 20-30 a month between both fleets till we hit around 1200 pilot. Currently sitting at about 850CaptDukeNukem wrote: ↑Sun Aug 17, 2025 7:35 pmHiring every month for the foreseeable future.Loading... wrote: ↑Sun Aug 17, 2025 10:59 am
Re: Misc Questions
I think we're staffing 14 pilots per aircraft. Which is roughly 1000 pilots with what's on order. If you listen to the rumours, I imagine them extending orders and needing more pilots.Loading... wrote: ↑Tue Aug 19, 2025 8:51 amThanks for the reply. The recruitment page of the website says they will hire over 1200 pilots over the next 4 years. So I’m guessing that’s not true anymore
Hardest part is this industry is not producing enough quality pilots anymore.
flieslikeachicken
Re: Misc Questions
I take that as a direct attack on me and I am deeply offended.
Re: Misc Questions
I take it you're trolling, or I hope you are, because CJP isn't, not even in the slightest, wrong... i've heard seasoned captains i've flown with say what CJP said countless times in the last few yearsflieslikeachicken wrote: ↑Tue Aug 19, 2025 7:11 pmI take that as a direct attack on me and I am deeply offended.
flieslikeachicken
Re: Misc Questions
Yes, it was a joke.twa22 wrote: ↑Tue Aug 19, 2025 7:17 pmI take it you're trolling, or I hope you are, because CJP isn't, not even in the slightest, wrong... i've heard seasoned captains i've flown with say what CJP said countless times in the last few yearsflieslikeachicken wrote: ↑Tue Aug 19, 2025 7:11 pmI take that as a direct attack on me and I am deeply offended.
Re: Misc Questions
I figuredflieslikeachicken wrote: ↑Tue Aug 19, 2025 7:44 pmYes, it was a joke.twa22 wrote: ↑Tue Aug 19, 2025 7:17 pmI take it you're trolling, or I hope you are, because CJP isn't, not even in the slightest, wrong... i've heard seasoned captains i've flown with say what CJP said countless times in the last few yearsflieslikeachicken wrote: ↑Tue Aug 19, 2025 7:11 pm
Loading...
Re: Misc Questions
Is there many single day pairings out of YVR?
Also how long do the upgrades take from there?
Loading...
flieslikeachicken
Re: Misc Questions
Pilots are given money on their pay cheques to pay for parking. The amount is equivalent to a TTC monthly pass, if they still existed.
YYZ parking costs $136.50 per month and Porter gives their pilots $143.
flyingpilot
Re: Misc Questions
Why is it that porter insists on using hotels that are either right at the airport or in the middle of nowhere for both short and long stays?
flieslikeachicken
Re: Misc Questions
They're cheaper and/or easier logistically.flyingpilot wrote: ↑Tue Jan 06, 2026 11:13 am Why is it that porter insists on using hotels that are either right at the airport or in the middle of nowhere for both short and long stays?
