Forgot to Extend the Gear Thread
Re: Forgot to Extend the Gear Thread
From TSB.....
C-GKIT, a privately-registered Cessna 337E aircraft, was conducting a local VFR flight from the
Brandon Municipal Airport (CYBR), MB, with the pilot and three passengers. While returning for
landing at CYBR on Runway 32, it was reported that the landing gear selector was placed in the
down position. The pilot did not confirm the down and locked indication prior to touchdown and the
main landing gear collapsed during the landing roll. The aircraft skidded to a stop in the center of
the runway. The aircraft was substantially damaged. There were no injuries.
From TSB.....
C-FTGD, a privately operated Beechcraft C24R Sierra 200, was conducting touch-and-go landings
from Lachute Aerodrome (CSE4), QC, in visual meteorological conditions with only one pilot on board. During landing, the aircraft slid onto its belly because the landing gear was retracted. There were no injuries, and the aircraft sustained structural damage to the fuselage.
From TSB...
C-FAPL, a privately registered Piper PA-31 Navajo, departed Kashechewan Airport (CZKE), ON,
on a flight with another pilot on board. While on short final to Runway 28 at Timmins Victor M.
Power Airport (CYTS), ON, the Flight Service Specialist (FSS) observed that the aircraft’s landing
gear did not appear to be extended. FSS radioed C-FAPL to confirm the gear status, but the
aircraft landed gear-up. The aircraft skidded along Runway 28 through the intersection with
Runway 03/21 before coming to a stop on the runway. There were no reported injuries; however,
the aircraft sustained substantial damage.
From TSB....
C-FAUA, an Insignia College Ltd. Piper PA-34-200T (Seneca II) was performing circuit training,
under visual flight rules, at the Boundary Bay Airport (CZBB), BC, with 1 instructor and 1 student
on board. During the 6th circuit, simulated single engine operations were demonstrated. When the
aircraft settled on Runway 25, the propellers struck the runway, and the aircraft came to an abrupt
halt on the paved surface resting on its belly. The 2 occupants were able to egress without
incident. Post-occurrence, it was determined that the landing gear selector was in the up position.
There were no injuries. The aircraft was substantially damaged.
There was damage to the propellers, flaps, and underside of the aircraft. It was lifted from the
runway and the landing gear was extended normally. The aircraft will be assessed for damage.
From TSB....
C-GCEF, a Diamond DA 42 operated by Journey Air Ltd., was conducting a flight test for licensing
purposes with a student pilot and an examiner on board. The aircraft remained within the Windsor
International Airport (CYQG), ON, area for the duration of the flight. While on approach,
approximately 7–8 NM from the runway, the student was performing a single-engine approach with
one engine set to idle. During the approach, the landing gear remained retracted and the landing
gear warning horn sounded continuously. The aircraft subsequently touched down on Runway
12/30 with the landing gear retracted. The aircraft sustained substantial damage; however, there
were no injuries to either occupant.
From TSB via Google Translate...
C-GQOT, a privately operated Mooney M20C, was conducting a visual flight rules (VFR) flight from St-Mathieu de Beloeil Airport, QC (CSB3) to Joliette Airport, QC (CSG3) with one pilot on board. While on approach to CSG3, power fluctuations were reportedly observed. No emergency was declared, and the pilot made a direct approach to runway 33. The landing gear failed to deploy, and the aircraft belly-landed. The pilot was not injured, and the emergency locator transmitter (ELT) did not activate.
The examiner didnt notice? Holy crap. Or he let it happen to see if the candidate would notice? This is crazy!!pelmet wrote: ↑Wed Nov 26, 2025 7:52 pm From TSB....
From TSB via Google Translate....
C-FZWP, a privately operated Cessna 177RG Cardinal, was conducting a visual flight rules (VFR) flight from Mont-Joli Airport, QC (CYYY) to Montréal/St-Hubert Airport, QC (CYHU) with one pilot on board. During the landing on Runway 24R, the aircraft touched down with the landing gear not extended. The aircraft then slid on its belly until coming to a complete stop on the runway. Upon seeing smoke inside the cockpit, the pilot unfastened his seatbelt and immediately evacuated. A few seconds later, while the fire department was en route, flames appeared in the section of the fuselage beneath the pilot's seat. The fire was quickly brought under control by the airport fire department. Although uninjured, the pilot was nevertheless transported to the hospital for an evaluation.
