Westjet 737 Gear collapse in SXM today
RoAF-Mig21
Post by RoAF-Mig21 »
RoAF-Mig21
Re: Westjet 737 Gear collapse in SXM today
Looks like the PR guy that used to work for AC now works for Westjet.
According the the CBC.....WJ is calling the accident a 'Hard Landing'.
https://www.msn.com/en-ca/news/canada/w ... 072d&ei=16
BrassCraft
Post by BrassCraft »
pelmet wrote: ↑Sun Sep 07, 2025 4:14 pm Looks like the PR guy that used to work for AC now works for Westjet.
Well it’s a French pilot sooo… hard landing tracks.
boeingboy
Post by boeingboy »
Really???
I mean what else are you going to say? Even though this wasn't a hard landing (that broke it at least). It's most likely a trunnion pin failure like we've seen before. It would take a near crash to break the gear on a 737.
Gear Jerker
Post by Gear Jerker »
lol come on now. CFIT into a localizer building and approach lighting short of the runway where the aircraft skids from off the runway and comes to a rest on it heavily damaged and totally written off after taking out most of the lead in lights, vs what at first glance looks like a pretty normal firm touchdown in a gusty crosswind. Absolutely not the same thing.
Look, it's f***in Patrick Swayze and Reveen!
Gear Jerker wrote: ↑Sun Sep 07, 2025 6:33 pm
But it is still a hard landing.
boeingboy
Post by boeingboy »
pelmet wrote: ↑Sun Sep 07, 2025 6:34 pm
How do you know? you have access to the FDR?
daedalusx
Post by daedalusx »
Everyone that called the Alaska air landing into SNA a hard landing had to eat crow when it came out that it was only 1.7G and the collapse happened due to improper maintenance
https://aviationweek.com/mro/safety-ops ... r-collapse
boeingboy wrote: ↑Sun Sep 07, 2025 6:51 pm
I was referring to the AC flight(but admittedly was not clear about that).
boeingboy
Post by boeingboy »
pelmet wrote: ↑Sun Sep 07, 2025 7:32 pm
Apologies.
safetyfirst123
Post by safetyfirst123 »
BrassCraft wrote: ↑Sun Sep 07, 2025 5:15 pm
This was an experienced crew who are now dealing with difficult circumstances, and it could have happened to any one of us. I hope they are given all the courtesy and respect going forward by the company, and colleagues whether from Westjet or anywhere else. Let's see what the data shows and maybe learn from it.
Stu Pidasso
Post by Stu Pidasso »
Talk about a clueless tower controller, how about you get your eyes out the window sweetheart.
Eric Janson
Post by Eric Janson »
Stu Pidasso wrote: ↑Mon Sep 08, 2025 7:58 am Talk about a clueless tower controller, how about you get your eyes out the window sweetheart.
The tower is located on the left and behind where the aircraft stopped. Don't think the controller could see that anything abnormal was going on.
https://avherald.com/h?article=52ca435b&opt=0
Nothing unusual in the weather reports - normal tropical conditions. Wind almost straight down the runway.
That will be quite the repair job if they don’t scrap it. No hangars there and a lot of structural repairs…..
Pacqing
Post by Pacqing »
Scrap it?? If KBA can go to the Antarctic and do that nose replacement on a turbo 3 then I'm sure a crew can jack and bolt on some angle iron for a ferry flight . A bit more than that I know but I'm sure it will be ferried out.
Donald
Post by Donald »
Another example of poor radio work.
If you need the trucks, start with "Pan-Pan Pan-Pan Pan-Pan".
It's really not hard, and it gets the message across clearly. Especially if there's any language barrier.
planenuts
Post by planenuts »
WS 2276....
planenuts
Post by planenuts »
ASA 1288....
Pacqing wrote: ↑Mon Sep 08, 2025 10:50 am Scrap it?? If KBA can go to the Antarctic and do that nose replacement on a turbo 3 then I'm sure a crew can jack and bolt on some angle iron for a ferry flight . A bit more than that I know but I'm sure it will be ferried out.
True dat, but a DC3 is a much rarer an irreplaceable aircraft. Tons of older 737-800s will be going to the boneyard soon as newer ones arrive.
Eric Janson
It needs a new right engine as well as structural repairs - that's a complex repair. They will need to build a temporary hangar and bring in teams of people plus parts.
It will come down to the cost of repairs vs. the residual value of the airframe.
The PAL Q400 that had the gear collapse in YHZ was scrapped. That was a few hundred feet from their hangar. All depends on what the airframe value vs. repair is.
Donald wrote: ↑Mon Sep 08, 2025 12:25 pm Another example of poor radio work.
I can't even understand the Westjet pilot when he speaks. Is there an English proficiency issues with some of their pilots?
nohojob
Post by nohojob »
Maybe, just maybe he was slightly nervous ?
safetyfirst123
pelmet wrote: ↑Mon Sep 08, 2025 6:52 pm I can't even understand the Westjet pilot when he speaks. Is there an English proficiency issues with some of their pilots?
Disrespectful comment. Consider that listening to LiveATC transmissions like what we heard is not like being in the tower or airplane. From the info that we have right now, the situation was handled very well by the crew.
