Yes - pretty much what I posted 3 weeks ago right above your postjpilot77 wrote: ↑Sun Nov 09, 2025 2:56 pm http://smn-news.com/index.php/st-maart ... arten.html
So the TSB is saying not a hard landing. Looks like a broken part that failed.
Westjet 737 Gear collapse in SXM today
Re: Westjet 737 Gear collapse in SXM today
True you did, but the TSB has confirmed.boeingboy wrote: ↑Sun Nov 09, 2025 3:56 pmYes - pretty much what I posted 3 weeks ago right above your postjpilot77 wrote: ↑Sun Nov 09, 2025 2:56 pm http://smn-news.com/index.php/st-maart ... arten.html
Yea - I posted direct from the TSB and even said it was right from them.jpilot77 wrote: ↑Sun Nov 09, 2025 4:02 pmTrue you did, but the TSB has confirmed.boeingboy wrote: ↑Sun Nov 09, 2025 3:56 pmYes - pretty much what I posted 3 weeks ago right above your postjpilot77 wrote: ↑Sun Nov 09, 2025 2:56 pm http://smn-news.com/index.php/st-maart ... arten.html
goldeneagle
So has it been fixed up enough to fly out yet ?
The plane flew home today. Well done to the Tech ops group!
- Daniel Cooper
Impressive stuff. I'm sure the engineers didn't mind working in St. Martin for a couple months instead of Iqaluit.
goldeneagle
I'd be curious, was it WJ staff down there, or did they hire an AOG company...Daniel Cooper wrote: ↑Fri Dec 05, 2025 10:14 pm Impressive stuff. I'm sure the engineers didn't mind working in St. Martin for a couple months instead of Iqaluit.
Heard it was a team from Boeing actually which would make sense since WJ probably wouldn’t have the people to do the engineering signoffs for repairs.goldeneagle wrote: ↑Fri Dec 05, 2025 11:44 pmI'd be curious, was it WJ staff down there, or did they hire an AOG company...Daniel Cooper wrote: ↑Fri Dec 05, 2025 10:14 pm Impressive stuff. I'm sure the engineers didn't mind working in St. Martin for a couple months instead of Iqaluit.
WJ mechanics did the recovery, repairs and inspections. A group of Boeing engineers were on site for about the last month and did some inspections such as checking for a bent airframe. They would also coordinate other more complicated issues and have Westjet execute them. The vast majority of the on-site work was done by WJ.fish4life wrote: ↑Sat Dec 06, 2025 10:01 amHeard it was a team from Boeing actually which would make sense since WJ probably wouldn’t have the people to do the engineering signoffs for repairs.goldeneagle wrote: ↑Fri Dec 05, 2025 11:44 pmI'd be curious, was it WJ staff down there, or did they hire an AOG company...Daniel Cooper wrote: ↑Fri Dec 05, 2025 10:14 pm Impressive stuff. I'm sure the engineers didn't mind working in St. Martin for a couple months instead of Iqaluit.
The aircraft is now back in YYZ
Good to knowplanenuts wrote: ↑Sat Dec 06, 2025 2:49 pmWJ mechanics did the recovery, repairs and inspections. A group of Boeing engineers were on site for about the last month and did some inspections such as checking for a bent airframe. They would also coordinate other more complicated issues and have Westjet execute them. The vast majority of the on-site work was done by WJ.fish4life wrote: ↑Sat Dec 06, 2025 10:01 amHeard it was a team from Boeing actually which would make sense since WJ probably wouldn’t have the people to do the engineering signoffs for repairs.goldeneagle wrote: ↑Fri Dec 05, 2025 11:44 pm
goldeneagle
SXM is not where I would choose to test brand new landing gear.
Tbayer2021
You should let Boeing know. They probably didn't think of that one.
- Daniel Cooper
They used Boeing pilots for the test flight?
I've had AMEs instruct me to do ridiculous things for test flights, and during ground engine run ups. It's up to the pilot to decide what the best course of action is for a flight not the engineers.
That said I don't think doing the test flight and landing in St. Maarten was inherently unsafe. There may have been some legal reason why it couldn't be flown internationally until a test flight was complete. That factor would have to be weighed against the safety of landing on that runway.
Not sure what your getting at.Daniel Cooper wrote: ↑Mon Dec 08, 2025 7:59 pm They used Boeing pilots for the test flight?
First - it was Westjet pilots that did the test flight.
Second the only instructions they had were to do a full thrust takeoff and to check aileron control forces during the flight.
Are not test flights done after some maintenance task is performed?
Therefore it's up to the Engineers not the pilot as to what's to be done on the flight.
The person responsible for an aircraft in-flight is the Pilot in Command. I don't even need multiple choice to know that anymore.
goldeneagle
I'm sure a couple pilots fresh off a deadhead into SXM know full well better what needs to be checked, far better than the folks that have spent a couple months fixing it, and know exactly what systems were touched, and what the ramifications of those may be.Daniel Cooper wrote: ↑Mon Dec 08, 2025 7:59 pm I've had AMEs instruct me to do ridiculous things for test flights, and during ground engine run ups. It's up to the pilot to decide what the best course of action is for a flight not the engineers.
If I were running flight-ops I'd have the guys who flew it in fly it out.
No reason really. Just cuz.
Eric Janson
Normally test flights are performed by Pilots who have been trained for this. Normally they will have taken a course at the manufacturer.
What needs to be done should come from the manufacturer - this should be briefed by all parties involved before a flight is performed.
Do we even know what was required to be done on this post-maintenance check flight(or was it actually a test flight?). Maybe the only thing that was required was to cycle the gear.Eric Janson wrote: ↑Wed Dec 10, 2025 3:42 amNormally test flights are performed by Pilots who have been trained for this. Normally they will have taken a course at the manufacturer.
I have done post-maintenance check flights on several large types and didn't take any course with either manufacturer.
The only test flight I ever did was a gross weight increase where TC issued a certificate that had to be carried on board(and a bunch of instructions) allowing that test flights to be accomplished.
Eric is right - we have dedicated pilots who do all test flights.pelmet wrote: ↑Wed Dec 10, 2025 6:32 amDo we even know what was required to be done on this post-maintenance check flight(or was it actually a test flight?). Maybe the only thing that was required was to cycle the gear.Eric Janson wrote: ↑Wed Dec 10, 2025 3:42 amNormally test flights are performed by Pilots who have been trained for this. Normally they will have taken a course at the manufacturer.
The gear was swung on the ground - no way that would ever be put to a test flight.
As I said earlier - the only requirements were for a full trust takeoff and a check of the aileron control forces during flight. Specific log entries are made detailing the nature of the test flight and exactly what is required to be checked. The pilots then sign off that specific check as either satisfactory or unsatisfactory.
Full thrust takeoff and aileron control force check. Sounds like the time I did a post maintenance check flight on such type. Was just done by regular crews. More in depth checks on one type in the company was done by certain captains only while another type had any line captain/First officer doing it.planenuts wrote: ↑Thu Dec 11, 2025 5:15 amEric is right - we have dedicated pilots who do all test flights.pelmet wrote: ↑Wed Dec 10, 2025 6:32 amDo we even know what was required to be done on this post-maintenance check flight(or was it actually a test flight?). Maybe the only thing that was required was to cycle the gear.Eric Janson wrote: ↑Wed Dec 10, 2025 3:42 am
Do WJ pilots doing these flights take a specific course for this at the manufacturer? Captain and F/O?
