reducing throttle after take-off - IO-520
Moderators: Sulako, North Shore, sky's the limit, sepia, Rudder Bug
Bede
Post by Bede »
For those of you that fly C185 & C206 with the IO-520, why does everyone reduce the throttle after take-off? I understand the prop, but I have never got a good justification why the throttle also needs to be reduced. It's not in the POH.
porcsord
Re: reducing throttle after take-off - IO-520
Post by porcsord »
The AFM in looking at says:
Normal Climb:
2. Power -- 25"Hg or FULL THROTTLE (which ever is less)
And
Maximum Performance Climb
2. Power -- Full Throttle and 2700 RPM
Why don't the Boeings always takeoff at full rated power, and climb at full rated power? Engine longevity, fuel consumption, etc etc. same same
Bede
Post by Bede »
porcsord wrote: Thu Jan 08, 2026 10:50 am Why don't the Boeings always takeoff at full rated power, and climb at full rated power? Engine longevity, fuel consumption, etc etc. same same
See that's what I always thought too but they make a turbo version of the exact same engine that climbs out at 38" every day, so leaving at full throttle at 28" isn't going to make a difference.
porcsord
Post by porcsord »
But, is there more maintenance or wear on the engine than a naturally aspirated version - disclaimer: I don't know, just speculating.
The Continental Operators Manual for the IO 520 has charts which show the MP vs RPM limits. It allows 29in at RPM as low as 1800 RPM. Personally I have always climbed at the POH recommended cruise climb of 25 in and 2550 RPM. which I go to as soon as I am safely off the water.
If I need more climb performance to get over obstacles than full throttle and 2700 RPM until clear and then cruise climb
If I am lighter and noise is going to be an issue I will do the takeoff at 2700 RPM and full throttle instead of 2850.
Post by ahramin »
Hi Bede,
I fly a 180 and a 210 with IO-520s, we do not reduce throttle after takeoff, only RPM. The 210's engine has 2100 hours and 18 years since last overhaul, no issues so far. The 180's engine is new but it flies lots year round so we're planning on getting 3000+ hours out of it.
sunk
Post by sunk »
so do you leave the MP at full throttle for the trip and just roll back the rpm? Or do you reduce MP in cruise?
Bede
Post by Bede »
sunk wrote: Thu Jan 08, 2026 7:46 pm so do you leave the MP at full throttle for the trip and just roll back the rpm? Or do you reduce MP in cruise?
I know guys that fly like that, albeit not on an IO-520.
goingnowherefast
Post by goingnowherefast »
Bede wrote: Thu Jan 08, 2026 11:57 am
Is it the exact same engine? I bet the pistons are different for a different compression ratio. I'd hazard a guess and say a lot of the engine internals are slightly different. What's the published TBO for both engines? I'd bet the turbocharged engine has a slightly lower TBO. Sure, one could run their non-turbo engine really hard and not break anything, but it's life will be closer to that of the turbocharged engine.
Also consider what the 38" means to a turbo engine. We already know the cylinder compression ratio is lower. We also know there's back pressure in the exhaust system from driving the turbocharger turbine. That means lesser exhaust scavenging. The 38" in the turbo engine is the same equivalent work being done by the pistons as a much lower manifold pressure on a non-turbo engine. I don't know the actual answer, but I'll guess it's pretty close to 25-29".
I'll put it this way. If one wants to make 270hp (approximate climb power), the turbo engine needs a noticeably higher manifold pressure to make that power. This is due to exhaust back pressure from the turbo itself, and lower piston compression ratio.
Bede
Post by Bede »
goingnowherefast wrote: Fri Jan 09, 2026 5:37 am
Excellent answer. Thank you.
Post by ahramin »
Full throttle from takeoff to top of descent. Small power reduction after takeoff by reducing the rpm, large power reduction in cruise by reducing rpm and fuel flow.
Post by ahramin »
It occurs to me that I should give some additional information. During climb I keep the mixture very rich, only leaning enough to keep the EGTs about where they are after takeoff. At all times the CHTs stay below 400. A little hot for a continental but the floatplane is draggy and the 210 doesn't have the best cooling with a 520. We accept the small extra wear and tear for good climb performance.
In cruise I'm running lean-of peak. Very cool CHTs.
The turbocharging comments reminded me of the Stihl guy who won at Reno last time I was there. He was racing his Lancair around the course at something like 70" of MP and then flying the same plane around the country the rest of the year with no worries about his engine. Air cooled Lycoming and Continental engines are very robust as long as you don't overheat them and as long as you don't get them into detonation territory (which is almost impossible with a 520).
TeePeeCreeper
Post by TeePeeCreeper »
It’s not rocket science.
25/23 respectively squared and cross checked by FF. Is the engine GAMI’ed?
TPC
goldeneagle
Post by goldeneagle »
Bede wrote: Thu Jan 08, 2026 11:57 am See that's what I always thought too but they make a turbo version of the exact same engine that climbs out at 38" every day, so leaving at full throttle at 28" isn't going to make a difference.
C-421 has the GTSIO-520. It is in not 'the same engine' as the 185 or such, but the core is essentially the same. I have a fair amount of time flying the 421. Manuals call for a power reduction once airborne. The fuel control unit puts extra fuel into the cylinders for extra cooling at full throttle during takeoff on that airplane, so your 'dollars per minute' fuel flow guage winds up to the top. Once airborne with gear up and over trees, throttles come back to climb settings, mixture back to set a fuel flow. When the throttle comes back, fuel control unit no longer injects extra fuel for cooling, and this is the reason all takeoffs should be full throttle on that airplane, even if you have a 2 mile runway. The extra fuel is to provide cooling at low speed before there is enough airflow for air cooling.
Dunno if the other variants have the same system, there's a lot of stuff on the GTSIO variant that's not on the other variants.
Post by ahramin »
goldeneagle wrote: Fri Jan 16, 2026 12:32 pm
Further reinforcing the idea that the MP is not what is wearing out the engine, the CHTs are. As long as your CHTs are 380 or below, reducing MP is not going to increase longevity.
goingnowherefast
MP creates cylinder pressure, which pushes the rings harder into the cylinder walls. An engine that spends it's time cruising around at 60% power will last longer than one that flies around at 75% (everything else being equal).
That's a long term wear thing though. 3 minutes for takeoff is inconsequential (unless you're doing circuits for the whole life or the turbo engine). A lot of engines, and especially turbo engines have full throttle (and full rich) fuel enrichment features.
Takeoff is high power, low cooling air flow. So get it over with ASAP. Takeoff manifold pressure and RPM also creates the highest combustion temperature. Pistons basically don't have direct cooling. They're cooled by the intake stroke with cool air. That air isn't exactly cold, because it was compressed by a hot turbo. Some engines have piston oil squirters to put oil on the bottom of the piston, but that only does so much too. The extra fuel at takeoff power helps reduce the combustion temperature and thus reduce piston heat.
So, unless one plans to take off at cruise power, use proper takeoff power. The takeoff roll at cruise power would probably take so long that the cylinders would get cooked from the lack of appropriate airflow. It would also be dangerous due to the lack of performance.
rigpiggy
Post by rigpiggy »
The Navajo has a similar setup the last inch of travel increases the fuel flow during takeoff. After 400' power back to 38" 2400 rpm, and 30 gph. In cruise 2200/32" /16gph
I'm not sure that operating procedures for geared turbocharged engines are very relevant to help decide how to operate an IO 520 :smt031
goingnowherefast
Haha, good point. Still a -520, but with many goodies added to it. At least that's the justification some are using. I'm sure there aren't many common parts anywhere between a GTSIO-520 and the IO-520 used in the 185 and 206.
Just a quick browse on a parts website. The cylinders aren't even the same across the different models of IO-520. They are different again for TSIO-520, and aren't the same across all the turbo engines. The GTSIO-520 has 2 different cylinder options again. Lots of visual differences in head design, intake flange, base flange thickness, etc.
So no. I do not recommend running a IO-520 hard because a TSIO-520 can handle that manifold pressure. Certainly don't spin up the prop governor to 3000rpm because a GTSIO can handle it.
goldeneagle
ahramin wrote: Fri Jan 16, 2026 6:08 pm Further reinforcing the idea that the MP is not what is wearing out the engine, the CHTs are. As long as your CHTs are 380 or below, reducing MP is not going to increase longevity.
Depends, what failure modes are you seeing when the engine 'wears out'. An interesting tidbit I picked up at FliteSafety regarding the GTSIO-520H. They left the factory with a 1200 tbo, and early on they were rarely going that long before cylinders were cracking, airplane developed a bad rep for cracked cylinders. Cessna went back to Continental asking 'why do these crack before 1200, yet a 185 goes forever?'. Continental did some digging into the issue, and came up with an interesting answer.
The difference is the mission profiles. 185 tends to do a lot of short hops, mostly off the water, and flies at low level. 421 mission tends to be 2 to 3 hours and up to the flight levels. During that time, all the gas in the tanks gets cold soaked. then the airplane comes barrelling down the hill, and on short final the checklist says 'mixture rich'. Now you suddenly have a whole bunch of cold soaked fuel splashing on the piece of metal between the injector and spark plugs, one of the hottest and most fragile parts of the cylinder. That's where the cracks typically showed up.
Two solutions offered. Behind door number one, slowly bump up mixture during the descent, so that when you get to the point at short final, the checklist answer is 'already there'. Behind door number two, dont put on full rich on short final, move that to the 'on overshoot' items. Then you are not always shocking the cylinders, only doing so in the rare case it's really needed. They took these concepts to an operator that had a significant fleet of the airplane, introduced the new procedure there, and voila, cracked cylinders went away, ultimately leading to tbo going up to 1600, depending on which cylinders were on it. If memory serves correctly, the difference between the two variants was aluminum vs steel, but I may have that part wrong, it was 25 years ago I did that course.
