2026 PIT FLEET AC
Re: 2026 PIT FLEET AC
Most junior AC pilot: 5742
Junior NB FO YVR: 5488
Junior RP YVR: 5094
Most junior YVR pilot was hired in February 2025. The wait was approximately 1 year for YVR base.
Junior RP YVR: 5094
It's hard to say what the future will bring with YVR, but the A220 base is still growing. Rumours are it's expected to be around 180CA/170FO which would add another 60CA/70FO or so. Now will that come out of further reductions from the 737? Hard to say. There is also the 787-10s arriving over the next 24 months that will create an upwards movement as well. All in all if you join AC now I'd say your future to get to YVR if that's your goal is not that far off.
Snipergang
Yeah makes sense. Thanks to all that replied. Short term pain long term gain for those of us wanting to join but are out in the western part of Canada.
kozak_letun
Thank you for the clarification. It’s really helpful.TheStig wrote: ↑Tue Mar 17, 2026 6:52 amThere's always lots of confusion about position freezes.kozak_letun wrote: ↑Tue Mar 17, 2026 2:40 am Does anyone know if you are seat locked if you get RP in PIT? Can you bid NB FO within 2 years?
Positions are grouped. Widebody C, Narrowbody C, WB FO, NB FO, and RP. If you bid to a lower group you are frozen for 36 months in that position, otherwise you are free to bid to a higher groups. Once you start training into a higher rated group you are frozen from bidding within that group or lower for 30 months (from when you are awarded the position).
New hire pilots are frozen for 30 months from bidding into equal or lower grouped positions, with the exception of a one time award to a equal or lower rated position to transfer to a different base, if they do so they then have a new 30 month freeze in that position.
RP is a great place to start because you can bid up to NB FO. Once the 319 position is removed YUL, YYZ and YVR will all have 320,737, and 320 bases. 767FO should be avoided by pilots looking to transfer out of YYZ and 330RP should be avoided for those looking to transfer to YVR. Base transfers are much quicker and easier on the same type than to positions that require training.
Does anyone know what the future holds for the 737 in YYZ with the whole Rouge move? Are they planning to train up a lot of new people? Is it common for people to bid from FO positions on other narrow bodies or RPs onto the 737? I bet they will be doing some really sweet southern stops. My understanding is that everyone currently at mainline 737 has to be retrained once all the jets move to Rouge. I ask because if I would get the chance to join the fleet as a new hire would there be a high probability of being stuck at the bottom fpr a very long time.
Honestly dude I get all the questions, but at the end of the day it's all out of your control as a new hire. Best thing you can do is accept that you'll end up where you end up, and reasses based on seniority after a few years.
No one has a crystal ball.
That said IF I were to guess, YYZ/YUL should see a bit of growth as YVR is shrinking on the 737 front. I am not sure what the current deal is with positions becuase I don't look at bids anymore but there were NH 737 FO positions in YYZ for a long time. And no, not everyone needs to be retrained, there's a OE leg and some ipad work. That's it.
- crystalpizza
You probably have nothing to worry about if you want 737 FO in YYZ as that’s still one of the more junior positions systemwide today. Lots of vacancies left in it as well on the last bid. If you can’t get it in PIT you can try to draw a position at a different base (YUL) if there’s any available and then you’re allowed one base transfer with training as a new hire, to whatever you can then hold in YYZ.
They’ve just started reducing the old YYZ L319 position and seem to be dispersing it between the three ML NBs in YYZ. Movement happens all the time all over the place, including from RP to NB FO and also vice versa.
Comparing the first bid of 2025 to the last, there was a slight movement of overall 737 positions from west to east, IIRC a net loss of less than a dozen CA/FO each overall.
Snipergang
I guess you get what you get. To be honest I’d love 737, but long term who knows how long it be till you could hold a 737 position in YVR. Everyone is going 220 it sounds like. With more and more planes coming who knows why the future holds.
Totally... I was drinking and driving I guess... can't tell which way is up.
Snipergang
Another question for you guys, in the interview I heard before they even start they take your logbook and go through it. Are they pretty picky on it? I heard that pretty much every time you have in there needs to be certified.
Most of your time should be certified. I was FedExing my book around the month before my interview to previous employers getting it signed...Snipergang wrote: ↑Fri Mar 20, 2026 8:49 am Another question for you guys, in the interview I heard before they even start they take your logbook and go through it. Are they pretty picky on it? I heard that pretty much every time you have in there needs to be certified.
My first bunch of time from my first job wasn't signed off because they no longer existed, but I had the old CP as a reference. Also the job I had at the time of my interview wasn't signed off and the interviewers understood why... at the time they said I'd need to get it certified if I got the AC job offer, but it never came up again and I never went back to my old employer to get it signed after I left.
Don't leave things to question... get your stuff verified... try to get written references to bring.in with you... make it easy for them to check the boxes they need to hire you.
Have all your milestones tabbed with labels. If you are missing any signatures from companies, that's OK if you can explain why (way too far away, defunct etc.) and certify it true yourself with a signature (you are basically making a legal statment that they are true). If you want to go an extra step you could notarize a statment/signature. They looked at my logbook for a total of 5 minutes. That said I also had a lot more than the minimum experience and left seat 705 time so perhaps they might be more thourough with someone who is only a 703/704 pilot with 2001 hours.Snipergang wrote: ↑Fri Mar 20, 2026 8:49 am Another question for you guys, in the interview I heard before they even start they take your logbook and go through it. Are they pretty picky on it? I heard that pretty much every time you have in there needs to be certified.
Snipergang
Yeah, my previous employer I called texted and emailed and nothing back in regards to them certifying my logbook. So we’ll see. Everything else I have logged is certified.
TeePeeCreeper
I’m of the opinion that regardless of how you last left your previous employer that it’s poor form on their part to not acknowledge your calls or texts in regards to certifying your logbook. (Just my personal opinion)Snipergang wrote: ↑Fri Mar 20, 2026 10:57 pm Yeah, my previous employer I called texted and emailed and nothing back in regards to them certifying my logbook. So we’ll see. Everything else I have logged is certified.
If I were you, I’d politely ask again and if you still have a refusal, by all means call them out publicly here as a PSA for your fellow pilots.
TPC
Snipergang
Yeah I completely agree, a lot of people I’ve talked to agree too. My next step is I’m going to write up a letter with the time and hours I had there and just have my signature and then a spot for either the ops manager or chief pilot to sign, and then go from there. If they don’t do anything about it or don’t respond I’ll be slandering them everywhere lolTeePeeCreeper wrote: ↑Sun Mar 22, 2026 9:40 pmI’m of the opinion that regardless of how you last left your previous employer that it’s poor form on their part to not acknowledge your calls or texts in regards to certifying your logbook. (Just my personal opinion)Snipergang wrote: ↑Fri Mar 20, 2026 10:57 pm Yeah, my previous employer I called texted and emailed and nothing back in regards to them certifying my logbook. So we’ll see. Everything else I have logged is certified.
TPC
The interview instructions have a bolded/red statement saying that you need at least 2000 hours certified.Snipergang wrote: ↑Fri Mar 20, 2026 8:49 am Another question for you guys, in the interview I heard before they even start they take your logbook and go through it. Are they pretty picky on it? I heard that pretty much every time you have in there needs to be certified.
Anyone know of any calls for a May / June PIT?
I also have heard they have added a few courses for the remaining of the year.
Low hours on the WB is great! Love it.30westpirate wrote: ↑Sat Feb 07, 2026 10:48 pm OT is more rare on the WB side simply due to the limited daily flights. Also being junior WB and getting OT, quite rare. Simply doesn’t get down the list.
Hours on the WB aren’t that great, I’m confident in saying that some month NB CA’s are making more than WB CA’s due to low block hours.
The 900 hour annual pay guarantee likely renders T4’s more in line with hierarchy of equipment based pay rates (excluding O/T).Rooster69 wrote: ↑Wed Apr 15, 2026 7:28 amLow hours on the WB is great! Love it.30westpirate wrote: ↑Sat Feb 07, 2026 10:48 pm OT is more rare on the WB side simply due to the limited daily flights. Also being junior WB and getting OT, quite rare. Simply doesn’t get down the list.
Regardless, no pilot should be complaining about more days off in a CBA that does little to foster work/life balance.
Just heard today, the target is 480 new hires for 2026. Courses every 2 weeks but class sizes can vary a lot from less than 20 to over 30. Training dept and crew planning trying to balance demand and fleet staffing.
Great news! - Seems like that's quite the jump in hires for this year.
Thanks for the info!
flieslikeachicken
What's the average time between interview and job offer these days?
What is the annual date that the 900 hour guarantee is paid out?
I believe it's calculated in Jun or Jul, paid out whenever the company feels like it. Last year some didn't get it till Oct/Nov. Another expertly negotiated article.
