WestJet to Integrate Flair soon?
Heard from Flair employees that Onyx planning to buy Flair and Integrate Flair like Sunwing.
Re: WestJet to Integrate Flair soon?
Heard there's a particular username that literally only exists to start random posts like this for a year or two now.
It is funny to see the results though, between some guys that get all wound up, and opinions from others who couldn't even run a lemonade stand.
flieslikeachicken
What possible benefit would WJ have by buying Flair?
Seriously, Flair would only add debt to WJ without any tangible benefit.
flieslikeachicken wrote: ↑Tue Mar 17, 2026 9:09 amWhat possible benefit would WJ have by buying Flair?
flieslikeachicken
Honestly, now that you've put it that way, it does sound like something Onex would do. If they implemented Flair service, it would be an improvement from the current WJ service.
The seniority list integration will be interesting. How many 15-20 year Flair pilots are there that will get to bid the B787 left seat ?
Blackdog0301
safetyfirst123
If this happens, Flair pilots will have the privilege of flying modern 737's like the old 200's. Don't forget to say thank you, Flair pilots. Climb Thrust Level Change!
truecolours
And/or the privilege of flying with former SWG pilots setting some arbitrary N1 settings for go arounds (with no corresponding climb performance numbers).safetyfirst123 wrote: ↑Tue Mar 17, 2026 8:18 pm If this happens, Flair pilots will have the privilege of flying modern 737's like the old 200's. Don't forget to say thank you, Flair pilots. Climb Thrust Level Change!
I heard EIC was looking at adding Flair to their portfolio. Give them better southern canada coverage.
Oh - give it a rest you two. Nobodies perfect.truecolours wrote: ↑Sat Mar 21, 2026 12:06 pmAnd/or the privilege of flying with former SWG pilots setting some arbitrary N1 settings for go arounds (with no corresponding climb performance numbers).safetyfirst123 wrote: ↑Tue Mar 17, 2026 8:18 pm If this happens, Flair pilots will have the privilege of flying modern 737's like the old 200's. Don't forget to say thank you, Flair pilots. Climb Thrust Level Change!
I can come up with all kinds of stupid shit both Westjet and Sunwing crews have done. Just give it a rest.
Flair SOPs are very similar to SWG SOPs.truecolours wrote: ↑Sat Mar 21, 2026 12:06 pmAnd/or the privilege of flying with former SWG pilots setting some arbitrary N1 settings for go arounds (with no corresponding climb performance numbers).safetyfirst123 wrote: ↑Tue Mar 17, 2026 8:18 pm If this happens, Flair pilots will have the privilege of flying modern 737's like the old 200's. Don't forget to say thank you, Flair pilots. Climb Thrust Level Change!
safetyfirst123
I didn't mention anything about Westjet crews, who by the way have been fantastic to work with. But it would be nice if the company didn't pay to get rid of GPWS callouts for exampleplanenuts wrote: ↑Sun Mar 22, 2026 2:52 pmOh - give it a rest you two. Nobodies perfect.truecolours wrote: ↑Sat Mar 21, 2026 12:06 pmAnd/or the privilege of flying with former SWG pilots setting some arbitrary N1 settings for go arounds (with no corresponding climb performance numbers).safetyfirst123 wrote: ↑Tue Mar 17, 2026 8:18 pm If this happens, Flair pilots will have the privilege of flying modern 737's like the old 200's. Don't forget to say thank you, Flair pilots. Climb Thrust Level Change!
QKZXKV
- Location: Nickelbelt/Concrete Jungle/Lobster country...
It's not a payment. It's a simple settings change done by maintenance...safetyfirst123 wrote: ↑Mon Mar 23, 2026 6:31 amI didn't mention anything about Westjet crews, who by the way have been fantastic to work with. But it would be nice if the company didn't pay to get rid of GPWS callouts for exampleplanenuts wrote: ↑Sun Mar 22, 2026 2:52 pmOh - give it a rest you two. Nobodies perfect.truecolours wrote: ↑Sat Mar 21, 2026 12:06 pm
I can come up with all kinds of stupid shit both Westjet and Sunwing crews have done. Just give it a rest.![]()
PittBoss exists because you lot always take the bait and feed the troll. At this point I don't blame him!
80% to 85% N1 is what the SOPs said. One or two presses of the TOGA. It wasn't arbitrary. It always works out fine. Flairs SOPs are very similar to SWG. They even have automated altitude alert callouts. WestJet likes to reinvent the wheel.truecolours wrote: ↑Sat Mar 21, 2026 12:06 pmAnd/or the privilege of flying with former SWG pilots setting some arbitrary N1 settings for go arounds (with no corresponding climb performance numbers).safetyfirst123 wrote: ↑Tue Mar 17, 2026 8:18 pm If this happens, Flair pilots will have the privilege of flying modern 737's like the old 200's. Don't forget to say thank you, Flair pilots. Climb Thrust Level Change!
safetyfirst123
It also came from the Boeing FCTM. If that's arbitrary then I have no words.
truecolours
1st press is GA which commands 1000-2000 FPM.
2nd press is N1.
I don’t see any reference to actual percentages in the FCTM. As we have all learned, Boeing likes to leave stuff out. Do you have a section number for your statement that 80 and 85 are in the FCTM?
2nd press is N1.
truecolours
That’s a trick question. N1 values are not static. They are based on a variety of inputs. Just picking a number doesn’t cut it.
The highest number referenced above (85%) is on the very low end of what a calculated go around N1 would be. It would have to be -47 and an airport 2000 feet below sea level for 85% to be adequate for a full thrust (second press) go around. Ref: performance tables.
The FOM says to advance to full thrust initially.
Then, you adjust it.
So it is whatever you think works.
In the FOM also the PM is supposed to adjust the thrust.
In the FTCM the PF is supposed to do it.
There are a few things that are done online that doesn't match the FTCM.
truecolours
The Boeing FCTM is a guidance document. Operators are under no obligation to have their company procedures follow it directly.
