NavCanada's stupid satelite ADSB mandate
Wannafly1
Re: NavCanada's stupid satelite ADSB mandate
Post by Wannafly1 »
I was under the impression that the diversity requirement had been dropped. https://www.navcanada.ca/en/air-traffic ... ments.aspx
an antenna able to broadcast out toward space-based ADS-B receivers emitting 1090 MHz Extended Squitter. This requirement can be met either through antenna diversity (the use of a top and bottom antenna) or with a single antenna that is capable of transmitting both towards the ground and up towards satellites.
This change was partly (mostly?) due to the work of uAvionix which demonstrated that diversity is unnecessary to achieve sufficient performance. https://uavionix.com/wp-content/uploads ... Report.pdf
good for them since they can sell more tailBeaconX. I'll be buying one.
Wannafly1 wrote: Thu Jan 29, 2026 4:19 am I was under the impression that the diversity requirement had been dropped. https://www.navcanada.ca/en/air-traffic ... ments.aspx
That's good to know, thanks for the info!
tazin river
Post by tazin river »
Thanks all
I'll probably stick to this promo since I already have a couple Garmin G5 on the panel.
https://www.aircraftspruce.ca/catalog/a ... 5promo.php
The Uavionics is a good one but I would have to add their dash device in order to use the transponder.
tazin river wrote: Thu Jan 29, 2026 9:34 am Thanks all
Where are you going to put your antenna?
Other than the tailbeacon, I can't find any location that would qualify to receive both space and ground signals.
BGH
Post by BGH »
On our 185 bottom antenna is between the gear,top one is just in front of the rudder.
Daryl
tazin river
Thanks Daryl
This is working file for you? see below
BGH
Post by BGH »
Tazin,link goes to dead end for me.
Daryl
