E2 FO hiring
E2 FO hiring
dustyroads
Re: E2 FO hiring
As of me writing this reply the E2 First Officer position is on Porter Airlines careers page along with Dash 8.squawk2me wrote: ↑Tue May 20, 2025 7:24 pm Noticed that the E2 FO positions must be filled as they finally took down their ad, anyone happen to know if there is any planned hiring on the jet coming up? Was also wondering if it is just better to try and get in a Dash FO position to start. 2000 hrs and 800 multi turbine pic, wondering what the upgrade time on the Dash would be. Cheers!
Speedbrakes
Re: E2 FO hiring
I'm quite confident there will be a ground school every month for the next two years at least based on the amount of tails still to arrive. This is actually a slow year for deliveries and we're still doing a ground school every month.
Re: E2 FO hiring
Hello
Is Porter looking to hire E2 FOs for the remainder of the year and 2027? How much do FOs fly in a year? Are the newer FOs on reserve or can hold a block?
Thank you!
Thank you!
Speedbrakes
Re: E2 FO hiring
The latest from the company was no outside hiring for 2026 but I suspect that won't be (and probably already isn't) the case. I suspect there will be some outside hiring.
FOs flying 400-600 hours a year I believe. New hires can expect to be on reserve for a little while. I think 6-9 months now but I am happy to be corrected.
Orion's Fannypack
Re: E2 FO hiring
They still have an ad up for DEC Jet Captains, is that just filling a pool for the future?Speedbrakes wrote: ↑Tue Apr 21, 2026 7:58 amThe latest from the company was no outside hiring for 2026 but I suspect that won't be (and probably already isn't) the case. I suspect there will be some outside hiring.
Re: E2 FO hiring
They still have an ad for 2 bases that are about to close.Orion's Fannypack wrote: ↑Tue Apr 21, 2026 9:10 amThey still have an ad up for DEC Jet Captains, is that just filling a pool for the future?Speedbrakes wrote: ↑Tue Apr 21, 2026 7:58 amThe latest from the company was no outside hiring for 2026 but I suspect that won't be (and probably already isn't) the case. I suspect there will be some outside hiring.
Have Pratts - Will Travel
Re: E2 FO hiring
Re: E2 FO hiring
Last year it was under 3 months. Who knows now… supposedly external hiring is set to resume for the E2 shortly but there’s probably quite the candidate pool now.
Re: E2 FO hiring
markpilote
Re: E2 FO hiring
Wondering how reserve works at PD:Speedbrakes wrote: ↑Tue Apr 21, 2026 7:58 amThe latest from the company was no outside hiring for 2026 but I suspect that won't be (and probably already isn't) the case. I suspect there will be some outside hiring.
- if everyone regardless of seniority does a few reserve days reserve very month, or is it a full-month for the most junior
- if there is a minimum call-out time they have to give
Speedbrakes
Re: E2 FO hiring
Once you can hold a line you don't do reserve unless you bid for it. The minimum call-out is two hours.
Re: E2 FO hiring
Full-month for the most junior.markpilote wrote: ↑Sat May 23, 2026 1:57 pm Wondering how reserve works at PD:
Minimum call-out 2 hours.
Working rules for reserve aren't great atmo, lots of extensions, nothing is protected, you're essentially the company's slave during your RSV string. Hopefully we see some improvement on our first ever negotiated contract.
Re: E2 FO hiring
For line holders in general, how many days of work are being scheduled per month? Is there the option to drop or trade shifts ? Also is it easy to have a schedule where half of the month is scheduled work and the other half is off?fliter wrote: ↑Sat May 30, 2026 4:47 pmFull-month for the most junior.markpilote wrote: ↑Sat May 23, 2026 1:57 pm Wondering how reserve works at PD:
Re: E2 FO hiring
12 days off are guaranteed per month (well, per bidding period technically; sometimes they bleed over into another month by like a day to even out shorter vs longer months). Whether you'll get more depends on your seniority and how you bid. If you can hold all high-credit single days like YYZ-YVR-YYZ, you could work 10-12 days a month, but that's not the reality for most people.
Dropping isn't really a thing. In theory there is language for it (I think...) but almost no one tries to do it, and those who try almost never succeed. Trading is possible and sometimes done, but there really isn't a culture for it. I think that's due to the absolute shitty software that Porter uses: for the longest time the software was literally unable to process trades, so trading had to be done manually, and because of that there were restrictions on how many trades you could do per month, and you had to actually find a willing trade partner first and submit your request to crew scheduling with a certain amount of lead time... it was a nightmare. (I am not even sure if it's still like that or not, I've kinda given up on trading, and also my seniority lately has allowed me to hold what I really need to hold as far as days off etc.) So the default option for avoiding pairings you really hate is just booking off them.
If your seniority allows for it, you could try to build the half-and-half schedule you are describing, but it won't be exactly half-month-on, half-month-off. The work-heavy part of the month will have to have some days off because of CARS, so that leaves fewer days off for the lighter part of the month, and you're only guaranteed 12 to begin with.
Re: E2 FO hiring
Just got offered Aug 4 GS for E2 FO. Interviewed in October and been on the wait list since with a reach out from hiring for updated resume in May
Re: E2 FO hiring
Hello, I just got a reply from them saying that I should apply for the Dash8 instead. I have 1000 Turbine Time. Any thoughts please? Thank you
CaptDukeNukem
Re: E2 FO hiring
Disregard?
Why?
They are moving lots of dash pilots to the E2. The path to the jet seems to be shifting from external to internal. Get a seniority number and stick with it. Porter isn’t encore, a number is a number. Just get in.
If you can’t do 2-3 years on the dash with 1000 turbine before going to the jet then you’re just impatient. Learn the operation, learn the culture and you’ll still slot in appropriately with your seniority number.
Why?
weshtcoste54321
Re: E2 FO hiring
CaptDukeNukem wrote: ↑Sun Jul 26, 2026 12:41 am Disregard?
Why?
Why would someone already on a turbine go sit 2-3 years on another turbine? There are plenty of jet jobs out there.
Porter is an entry level jet gig bro, if they want to make you sit in a dash for 3 years to fly an Embraer, don't waste your time. Stick it out where you're at and just go straight mainline AC or WJ.
Re: E2 FO hiring
Thank you. I understand, I just thought there would be enough spots for the E2.CaptDukeNukem wrote: ↑Sun Jul 26, 2026 12:41 am Disregard?
Why?
Wonderfulpilot
Re: E2 FO hiring
Anybody still waiting to hear back after applied for the E2? It’s been a month now
BetterLateThanNever
Re: E2 FO hiring
Applied about a month ago and nothing so far.
Since people always ask: ATPL, 1900 hrs, 1000 turbine, 500+ hrs 705 on a Dash 8.
Re: E2 FO hiring
Any updates on the hiring ?
Is there a hiring pool atm or are they filling spots for the next GS?
CaptDukeNukem
Re: E2 FO hiring
Ground schools running every month on the E2. Mixed between Some transfers from dash and outside hires. Pretty sure the dash hiring is going strong as well.
15 new dash hires starting this Monday.
