Tower vs Terminal
BlueandYellow
Tower vs Terminal
I'm applying to get into ATC and was wondering about the finer differences between the life of a terminal controller vs tower. Is one more difficult in certain ways? Are there specific skills/personality traits that are better suited to one or the other?
BnY
BnY
If you're falling to your death, be sure to do some tricks on the way down.
Re: Tower vs Terminal
Terminal controllers seem to get yelled at more on here than tower controllers.
goldeneagle
There is one obvious difference, even to a lowly pilot. When I'm arriving at 3am, I am talking to a terminal controller during the descent. When I get close to the airport, I get handed off to the local frequency, where, the tower is closed.BlueandYellow wrote: I'm applying to get into ATC and was wondering about the finer differences between the life of a terminal controller vs tower.
I think shiftwork is a MAJOR component of lifestyle, and there's a lot of towers closed at night, not many terminal sectors close up shop at 8pm.
One thing i should point outthat IFR has 2 disciplines (terminal= approach control) and enroute sector (self explanatory). There is no gaurantee that you will be streamed to terminal, it depends on how you do in the school and where your strengths are. VFR would be more fun in my books, like golden eagle said there are a lot of part time airports so you can have a reassonable normal life and you actually get to see planes instead of a dot or and square surrounded by an octagon (as has been pointed out to me by my egg-head ifr buddies). I have 2 more years and i can apply to cross train meaning i can go from FSS to ATC. I plan on going VFR, its easier to pass and get your license. Eventually i will bid into a center and go ifr but that is much easier once you have a license its just a matter of bidding on a spot when a bid comes up, doing a test and then starting your training. Plus if worse comes to worse and you CT out of the center you can go back to your tower job. I would like to say someday that i have been through every operational discipline in the ATS world.
FSS: puting the Service back in Flight Services....
Having trained for both Tower and Terminal (but only "validated" my Approach ticket, as the Brits would say), my feelings is terminal is much more fun. But like everything in this job, a good tower controller can make a terminal person's life easy just as much as a good terminal controller can for the tower.
I was reading on Squakident they've stopped cross training?? If you apply for FSS you're stuck in FSS, or re-apply do the tests and interview etc. You sure about the cross training?bigfssguy wrote:I have 2 more years and i can apply to cross train meaning i can go from FSS to ATC. I plan on going VFR, its easier to pass and get your license. Eventually i will bid into a center and go ifr but that is much easier once you have a license its just a matter of bidding on a spot when a bid comes up, doing a test and then starting your training. Plus if worse comes to worse and you CT out of the center you can go back to your tower job. I would like to say someday that i have been through every operational discipline in the ATS world.
Still 5 years?
BlueandYellow
Jericho said:
Why do you think there's more fun in Terminal?Having trained for both Tower and Terminal (but only "validated" my Approach ticket, as the Brits would say), my feelings is terminal is much more fun.
Aprx 3 years ago they stopped cross training until "they figured out a different way to do things". They've reopened it requiring at least 5 years in the company, and jump through the hoops declaring your eligibility while the then company picks and chooses the people they like most to get the training.
*hugs and kisses* thanks for the update..hydro wrote:Aprx 3 years ago they stopped cross training until "they figured out a different way to do things". They've reopened it requiring at least 5 years in the company, and jump through the hoops declaring your eligibility while the then company picks and chooses the people they like most to get the training.
The qualification rate for tower is much higher than centre (terminal or otherwise) by about a factor of 10, so that might be one consideration. When I was in Cornwall, my class and just about every class around us lost 50% or more of their people in that first six months. By contrast, at the time, nobody had failed out of the Cornwall segment of the tower program in over 3 1/2 years.
The jobs are totally different, so that's another thing to consider. While both are called "ATC", I wouldn't know where to start if you put me in a tower, and vice-versa.
One thing to consider is location. If you apply at a centre, you will be hired and trained at that centre. In the case of towers, you will be assigned to one of the 42 (?) towers across the country, so you have much less control over where you end up. There can also be a substantial difference in income between towers and tower & centre, if that's a consideration for you.
As stated before, you don't apply to be a terminal controller. You apply to go either IFR (centre) or VFR (tower) and are streamed from there. Where you end up - terminal, en route, high or low level, depends on the centre's staffing needs and which course(s) they happen to be running when you get there.
Generally I think you could argue that ATC is comprised of four disciplines -- tower, terminal, low level, high level (for those areas that have a high/low split). Each area has its own quirks and skill set, and you cannot simply transition from one to the other without several months (6-8 or more) of retraining.
For me, I enjoy radar much more than looking out the window. Getting a good sequence with everything lined up on final 3 miles apart is very satisfying. You also have the chance to get creative in what you do. Plus us terminal guys are all really nice, well balanced peopleBlueandYellow wrote:Why do you think there's more fun in Terminal?
But as I said, I am biased. I once had an enroute guy sit with me on famil and he said there was no way he could do what terminal controllers did. I went and sat next to him a couple of weeks later and there ain't no way I could do enroute (especially that procedural stuff)
- taskforce58
You can add a fifth - oceanic controllers (in Gander ACC).charlie_g wrote:Generally I think you could argue that ATC is comprised of four disciplines -- tower, terminal, low level, high level (for those areas that have a high/low split). Each area has its own quirks and skill set, and you cannot simply transition from one to the other without several months (6-8 or more) of retraining.
- Taskforce 58 / Edmund Hon
In The Stall: http://inthestall.blogspot.com
